2 Replies Latest reply on Aug 24, 2012 2:49 AM by SBidd
    Call a Field in a Javascript
    SBidd
      I am trying to call a form field in a javascript that sends an email of the form.
      I would also like to final email to be a standard PDF not a form. Is this possible and if so what is the script.
      I currently have the following:
      var cToAddr = "sbiddlecombe@xxxxx.co.uk";
      var cCCAddr = "sbiddlecombe@xxxxx.co.uk";
      var cBody = "Thank you for submitting your form.\n" + "Please retain this mail attachment for your own records";
      var cSubLine = "Production Instructions ";
      this.mailDoc({
      bUI: true,
      cTo: cToAddr,
      cCc: cCCAddr,
      cSubject: cSubLine,
      cMsg: cBody
      This works great but now I would like to improve it further?
      Simon
        • 1. Re: Call a Field in a Javascript
          George_Johnson MVP & Adobe Community Professional
          Do you want to get the value of a form field and use it in a parameter of the mailDoc method? If so, you could do something like:
          var sText = getField("text1").valueAsString;
          var cBody = sText + " other test goes here.";
          You can't flatten a form - which converts the field appearances to regular page contents - with Reader, but you can set the fields to read-only:
          getField("text1").readonly = true;
          • 2. Re: Call a Field in a Javascript
            SBidd Level 1
            Thanks George This works perfectly.
            I have now added a print and send button to my form that Prints to the default printer, makes all fields read only and then sends the mail.
            My final question is can I set a close without saving option to this as I want the form to be used over and over again?
            If I just close the document when I open it again all fields are read only (as expected)
            Thanks Again
            Simon
