3 Replies Latest reply on Jan 26, 2013 5:54 PM by lancedolan
    How to acquire instance of AssetStore or AssetHandler?
    lancedolan Level 1
      How do I acquire an instance of AsseStore or AssetHandler? My end goal is to use them to create a new rendition, for example:
      Resource imageResource = resourceResolver.getResource(pathInDam);
      Asset asset = imageResource.adaptTo(Asset.class);
      AssetHandler handler = AssetStore.getAssetHandler(asset.getMimeType());
      ThumbnailConfig myConfig = new ThumbnailConfig(){
          public boolean doCenter() {return true;}
          public int getHeight() {return 95;}
          public int getWidth() {return 95;}
      List<ThumbnailConfig> configs = new ArrayList<ThumbnailConfig>();
      configs.add(myConfig);
      handler.createThumbnails(asset, configs);
      The missing piece to the puzzle is on the 3rd line: AssetStore.getAssetHandler is not a static method and I've just spent 2 hours decompiling half the jars in sling trying to figure out how the WorkFlowProcess class gets its instance to the class so that I can do the same.... I'm hoping there's either a factory I'm not familiar with or else a registered service I just can't find.
      Cheers and thanks
      -Lance Dolan
      CITYTECH Inc
        • 1. Re: How to acquire instance of AssetStore or AssetHandler?
          lancedolan Level 1
          Ah, I found that it is in fact registered as a service... should have checked this first.
          solution:
          SlingBindings bindings = (SlingBindings) req.getSlingRequest().getAttribute(SlingBindings.class.getName());
          SlingScriptHelper slingScriptHelper = bindings.getSling();
          AssetStore store = slingScriptHelper.getService(AssetStore.class);
          My next hurdle is figuring out why the rendition isn't persisted into CRX after the method successfully runs:
          If I log.debug() all renditions after running this, I see that the rendition is added to the Asset's renditions list, with the correct path and name, but the rendition doesn't exist in CRX afterwards. Hmm.
          • 2. Re: How to acquire instance of AssetStore or AssetHandler?
            JS Bournival Level 1
            Hi Lance,
            Have you been successful on this issue.  I'm having the same problem:  my asset seem to have the newly created renditions, I can even get a link to it.  But, as you might guess, the link throws a 404 since the rendition isn't in the CRX repo.
            I would be glad to read what you have done to make it work.
            Thank you.
            • 3. Re: How to acquire instance of AssetStore or AssetHandler?
              lancedolan Level 1
              It's been 6 months, so I don't recall much except that I solved it shortly after posting the comment. Probably grabbed an underlying Session instance and called the save() method?
