22 Replies Latest reply on Sep 13, 2012 8:13 AM by fschreiner
    Captivate 5.5 - recording does not work
    fschreiner
      I tried to do a screen recording - but it does not work.
      What I did:
      I opened Captivate and a new blank project.
      The I selected File and Record new project.
      Then I drop out of Captivate - which stays open in the background - and the following message appears:
      And all I can do is shut down Captivate.
      Whats wrong with the program?
      Thanks for help.
      Regards, Florence
        • 1. Re: Captivate 5.5 - recording does not work
          VikramGaur Adobe Employee
          Hello Florence,
          Welcome to Adobe Forums.
          Were you able to do Screen Recording with Adobe Captivate 5.5 ?
          Do you have Windows or MAC ?
          Did you tried launching and Recording with Adobe Captivate 5.5 on a new user account ?
          Please share the screen shot of Error Message.
          Vikram
          • 2. Re: Captivate 5.5 - recording does not work
            fschreiner Level 1
            Hi Vikram,
            yes, I could record. It is just a couple of month I didn't use this feature.
            I am working in a Windows 7 environment.
            Here follows the error message.
            The first means "Adobe Captivate (no answer)" and the second "Close Program" or "Wait for answer of program..".
            What do you mean with launching/recording on a new user account?
            Regards, Florence
            • 3. Re: Captivate 5.5 - recording does not work
              Hello Florence,
              If you don't have any customized setting for Adobe Captivate 5.5, then you can try this :
              1) Close Adobe Captivate 5.5
              2) Go to C:\Users\[user name]\AppData\Local\Adobe
              3) Rename "Captivate 5.5" to "1234"
              4) Launch Adobe Captivate 5.5 and check does it record now.
              Vikram
              • 4. Re: Captivate 5.5 - recording does not work
                fschreiner Level 1
                Hi Vikram,
                I did as described, Captivate starts as it was the first time, but the recording still doesn't work - same error message appears!
                Regards, Florence
                • 5. Re: Captivate 5.5 - recording does not work
                  Hello,
                  If it is possible, try creating a new User account :
                  Start -> Control Panel -> User Accounts -> Manage User Account and Add a new user.
                  Log off from your user account and login with the new user.
                  Note : If you are on  a Domain (Office Network) then you IT will help you.
                  Launch Captivate 5.5 and try to record.
                  Vikram
                  • 6. Re: Captivate 5.5 - recording does not work
                    fschreiner Level 1
                    Hi Vikram,
                    doesn't work either!
                    Regards, Florence
                    • 7. Re: Captivate 5.5 - recording does not work
                      Hello,
                      Do you see any logs for the Captivate 5.5 Crash in Eventviewer ?
                      Start -> Run -> Eventvwr (application logs)
                      If yes, Which .dll file is the faulting module ?
                      Vikram
                      • 8. Re: Captivate 5.5 - recording does not work
                        fschreiner Level 1
                        Hi Vikram,
                        that's what I found:
                        Protokollname: Application
                        Quelle:        Windows Error Reporting
                        Datum:         23.08.2012 23:01:22
                        Ereignis-ID:   1001
                        Aufgabenkategorie:Keine
                        Ebene:         Informationen
                        Schlüsselwörter:Klassisch
                        Benutzer:      Nicht zutreffend
                        Computer:      FLO
                        Beschreibung:
                        Fehlerbucket 34065454, Typ 4
                        Ereignisname: APPCRASH
                        Antwort: Nicht verfügbar
                        CAB-Datei-ID: 0
                        Problemsignatur:
                        P1: SMSvcHost.exe
                        P2: 4.0.30319.1
                        P3: 4ba1f4ec
                        P4: PCTLsp64.dll
                        P5: 1.0.111.0
                        P6: 4d92bfb0
                        P7: c0000005
                        P8: 0000000000017a50
                        P9:
                        P10:
                        Angefügte Dateien:
                        Diese Dateien befinden sich möglicherweise hier:
                        C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_SMSvcHost.exe_4bd2a659149b3ba4 e9de73654ab6a5e201da9c2_040830d0
                        Analysesymbol:
                        Es wird erneut nach einer Lösung gesucht: 0
                        Berichts-ID: 96d4aa63-ed63-11e1-898b-ee8646eafe83
                        Berichtstatus: 0
                        Ereignis-XML:
                        <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
                          <System>
                            <Provider Name="Windows Error Reporting" />
                            <EventID Qualifiers="0">1001</EventID>
                            <Level>4</Level>
                            <Task>0</Task>
                            <Keywords>0x80000000000000</Keywords>
                            <TimeCreated SystemTime="2012-08-23T21:01:22.000000000Z" />
                            <EventRecordID>113217</EventRecordID>
                            <Channel>Application</Channel>
                            <Computer>FLO</Computer>
                            <Security />
                          </System>
                          <EventData>
                            <Data>34065454</Data>
                            <Data>4</Data>
                            <Data>APPCRASH</Data>
                            <Data>Nicht verfügbar</Data>
                            <Data>0</Data>
                            <Data>SMSvcHost.exe</Data>
                            <Data>4.0.30319.1</Data>
                            <Data>4ba1f4ec</Data>
                            <Data>PCTLsp64.dll</Data>
                            <Data>1.0.111.0</Data>
                            <Data>4d92bfb0</Data>
                            <Data>c0000005</Data>
                            <Data>0000000000017a50</Data>
                            <Data>
                            </Data>
                            <Data>
                            </Data>
                            <Data>
                            </Data>
                            <Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_SMSvcHost.exe_4bd2a6591 49b3ba4e9de73654ab6a5e201da9c2_040830d0</Data>
                            <Data>
                            </Data>
                            <Data>0</Data>
                            <Data>96d4aa63-ed63-11e1-898b-ee8646eafe83</Data>
                            <Data>0</Data>
                          </EventData>
                        </Event>
                        Is it the "PCTLsp64.dll" file?
                        Regards, Florence
                        • 9. Re: Captivate 5.5 - recording does not work
                          fschreiner Level 1
                          or this:
                          Quelle:        Application Error
                          Datum:         23.08.2012 22:50:24
                          Ereignis-ID:   1000
                          Aufgabenkategorie:(100)
                          Ebene:         Fehler
                          Computer:      FLO
                          Beschreibung:
                          Name der fehlerhaften Anwendung: SMSvcHost.exe, Version: 4.0.30319.1, Zeitstempel: 0x4ba1f4ec
                          Name des fehlerhaften Moduls: PCTLsp64.dll, Version: 1.0.111.0, Zeitstempel: 0x4d92bfb0
                          Ausnahmecode: 0xc0000005
                          Fehleroffset: 0x00000000000043ac
                          ID des fehlerhaften Prozesses: 0x2c0c
                          Startzeit der fehlerhaften Anwendung: 0x01cd8170e9b222f0
                          Pfad der fehlerhaften Anwendung: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\SMSvcHost.exe
                          Pfad des fehlerhaften Moduls: C:\Program Files (x86)\Common Files\PC Tools\Lsp\PCTLsp64.dll
                          Berichtskennung: 2900dad9-ed64-11e1-898b-ee8646eafe83
                          Ereignis-XML:
                            <System>
                              <Provider Name="Application Error" />
                              <EventID Qualifiers="0">1000</EventID>
                              <Level>2</Level>
                              <Task>100</Task>
                              <TimeCreated SystemTime="2012-08-23T20:50:24.000000000Z" />
                              <EventRecordID>113211</EventRecordID>
                              <Security />
                            </System>
                            <EventData>
                              <Data>00000000000043ac</Data>
                              <Data>2c0c</Data>
                              <Data>01cd8170e9b222f0</Data>
                              <Data>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\SMSvcHost.exe</Data>
                              <Data>C:\Program Files (x86)\Common Files\PC Tools\Lsp\PCTLsp64.dll</Data>
                              <Data>2900dad9-ed64-11e1-898b-ee8646eafe83</Data>
                            </EventData>
                          </Event>
                          • 10. Re: Captivate 5.5 - recording does not work
                            Hello,
                            Thank you for the information
                            Do you see and Captivate 5.5 crash logs under Windows Logs -> Application (In Eventviewer)?
                            Vikram
                            • 11. Re: Captivate 5.5 - recording does not work
                              fschreiner Level 1
                              Hi Vikram,
                              that's what I see:
                              And that's the content of one of the error logs:
                              Programm AdobeCaptivate.exe, Version 5.5.0.257 kann nicht mehr unter Windows ausgeführt werden und wurde beendet. Überprüfen Sie den Problemverlauf in der Wartungscenter-Systemsteuerung, um nach weiteren Informationen zum Problem zu suchen.
                              Prozess-ID: 2c1c
                              Startzeit: 01cd81723bc87f3d
                              Endzeit: 10
                              Anwendungspfad: C:\Program Files (x86)\Adobe\Adobe Captivate 5.5\AdobeCaptivate.exe
                              Berichts-ID: 3754ec23-ed66-11e1-898b-ee8646eafe83
                              I just run the setup.exe of the eLearningsuite, to see if that helps.
                              Regards, Florence
                              • 12. Re: Captivate 5.5 - recording does not work
                                fschreiner Level 1
                                The setup.exe did'nt change anything!
                                • 13. Re: Captivate 5.5 - recording does not work
                                  Hello,
                                  When you wrote : "The setup.exe didn't change anything"
                                  Did you try uninstalling and reinstalling Captivate 5.5 ?
                                  Vikram
                                  • 14. Re: Captivate 5.5 - recording does not work
                                    RodWard Adobe Community Professional & MVP
                                    Can you please take screenshots of what you see in the Preference dialog under General > Default Locations, and also a screenshot of what you see at Recording > FMR > Working Folder?
                                    • 15. Re: Captivate 5.5 - recording does not work
                                      Hi there
                                      In addition to what Rod asked, I'll add this.
                                      And after you take the screen captures, please post them here for folks to see. Use the web interface to reply and post the images by clicking the camera icon above where you type the reply.
                                      Cheers... Rick
                                      Helpful and Handy Links
                                      Captivate Wish Form/Bug Reporting Form
                                      Adobe Certified Captivate Training
                                      SorcerStone Blog
                                      Captivate eBooks
                                      • 16. Re: Captivate 5.5 - recording does not work
                                        fschreiner Level 1
                                        in the meantime I did a complete deinstallation and reinstallation of the eLearning Suite, and it still doesn't work.
                                        Are these the screenshots Rod asked me to paste?
                                        Regards, Florence
                                        • 17. Re: Captivate 5.5 - recording does not work
                                          Your default location are set up correctly.
                                          Have you set Captivate to launch using Run As Administrator?
                                          • 18. Re: Captivate 5.5 - recording does not work
                                            Hi there
                                            One thing you may wish to try would be to create a folder on the root of your C drive named "Projects". Then create a folder inside that for each project. Given the fact your initial screen shot listed a different language, I'm wondering if perhaps there is maybe some odd character Captivate is balking at.
                                            In addition to the project location, I might also suggest trying to specify the "Projects" folder as well for the Cache and Publish folders just to see if anything changes. If it works, there's your answer. But there's no harm in trying!
                                            Cheers... Rick
                                            SorcerStone Blog
                                            Captivate eBooks
                                            • 19. Re: Captivate 5.5 - recording does not work
                                              fschreiner Level 1
                                              Hi there,
                                              sorry, I was a away for a while.
                                              The problem still persists.
                                              I do not run Captivate as an Administrator and if I do, there is no change concerning the recording.
                                              I also created these projects-folders Rick suggestet, and still this doesn't change anything!
                                              So what other solution could it be? Could there be an intereference with another program?
                                              I already did a complete deinstall and reinstall!
                                              Thanks, Florence
                                              • 20. Re: Captivate 5.5 - recording does not work
                                                fschreiner Level 1
                                                Hi again,
                                                I just did the following:
                                                I started my computer in the safe mode (without and with network connection) - and the recording worked perfectly!
                                                Then I restarted the computer normally, opened Captivate quit fast (the loading of all processes etc. was maybe still ongoing), and the recording window appeared! But as soon as I clicked the red recording button, the program blocked again and now it still doesn't work.
                                                Has anyone an idea, what could bother the system in the background?
                                                Thanks for further help,
                                                Florence
                                                • 21. Re: Captivate 5.5 - recording does not work
                                                  Hi Florence
                                                  I've seen it happen in certain classroom situations where the computers were locked down. I seem to recall one of the Antivirus or other protection applications stopping the process because it saw the Captivate recorder as a "key logger". (an application that silently runs and captures keystrokes in order to obtain passwords and logins without you knowing)
                                                  So possibly you need to add Captivate to the "white list" for your antivirus?
                                                  Cheers... Rick
                                                  SorcerStone Blog
                                                  Captivate eBooks
                                                  • 22. Re: Captivate 5.5 - recording does not work
                                                    fschreiner Level 1
                                                    Hi Rick,
                                                    problem is solved!
                                                    Captivate was already on the white list of my Antivirus programm.
                                                    The next step I took: I startet my computer in the safe mode with network connection and copied the list of processes and services in the task manager. Then I returned to the normal mode and started to compare and end processes, one after the other. After every step I tried the recording with Captivate.
                                                    Then I discovered a TV tuner software - I deinstalled it and now it works again!!
                                                    Thanks for all your ideas and help, step by step the problem was surrounded and finally solved.
                                                    Best regards, Florence
