0 Replies Latest reply on Aug 23, 2012 1:26 PM by txxchange
    Connection issue w/ FMS teleconferencing app
    txxchange
      I have a Flex based application which is using Flash Media Server (FMS) server (version 4.0)  for live video streaming between two users (i.e. a one to one teleconferencing service). This streaming is one-to-one, as defined by business rules, so that no third person can join a teleconference. Either person can start the video stream via a browser-based Flex client and communication gets established once the second user joins. Validation for connecting the streams of the two users is implemented on the FMS server (as server side scripting defined in main.asc). I am facing three critical problems with our teleconferencing solution.
      1.Often times, full communication can not be established between the two users. One user can not usually see or hear the other user. There is a client side 'refresh' button that when clicked, attempts to establish a connection via the server side script. This sometimes works. Before implementing our current server side script, I tried establishing a stream by using methods found here: http://forums.adobe.com/thread/905613
      I think the method below may work as it would give me an array of subscribers to the stream.
      getLiveStreamStats(appInst:String, stream:String) : Object
      But the problem is that server returns the following:
      <result>
      <level>error</level>
      <code>Admin.API.MethodNotAllowed</code>
      <description>getlivestreams - Method not allowed!</description>
      <timestamp>8/7/2012 10:05:38 AM</timestamp>
      </result>
      Question - Do I need to do anything different with the client or is it a server setting that needs modification?
      Thanks for the ideas...
