2 Replies Latest reply on Aug 23, 2012 9:08 PM by flaming1
    Changing units in MakeGrid script
    flaming1 Level 2
      Hi
      This should be fairly simple but I am struggling with it all the same.
      In the Applescript version of the MakeGrid script that comes with Indesign I want to make the default values for the Column Gutter and Row Gutter 2mm. This is a value that I use many times a day so it is simpler if it can be in there as a default.
      I have identified the lines in the script that define these fairly easily, but even though I am able to change the units to 'millimeters', I seem to have to put in the value in points. So I end up with the value of 5.669pts to equate to 2mm - as follows:
      set myColumnGutterField to make measurement editbox with properties {edit value:5.669, edit units:millimeters}
      This works just fine, but I just wonder why I cant enter the value as 2 if the units are millimeters.
      It's not a big issue, I'm just curious to know why I'm not able to do it.
