5 Replies Latest reply on Aug 26, 2012 11:02 PM by Trevorׅ
    restoring findGrepPreferences
    Vamitul Level 4
      hello!
      i have something like this:
      var old_fCGOpts=app.findChangeGrepOptions;
      var old_fGPref=app.findGrepPreferences;
      var old_cGPref=app.changeGrepPreferences;
      app.findChangeGrepOptions=NothingEnum.NOTHING;
      app.findGrepPreferences=NothingEnum.NOTHING;
      app.changeGrepPreferences=NothingEnum.NOTHING;
      // do some stuff
      // trying to restore the preferences
      app.findChangeGrepOptions=old_fCGOpts;
      app.findGrepPreferences=old_fGPref;
      app.changeGrepPreferences=old_cGPref;
      I get the folowing error:
      Invalid value for set property "findChangeGrepOptions". Expected NothingEnum enumerator, but recived FindChangeGrepOption.
      Help! It's driving me nuts.
        • 1. Re: restoring findGrepPreferences
          drerol74 Level 2
          Hello Vamitul,
          i think you cannot set all the properties in this way.
          But try this for findChangeGrepOptions:
          with (app) {
              with (findChangeGrepOptions) {
                var _userIncludeFootnotes = includeFootnotes;
                var _userIncludeHiddenLayers = includeHiddenLayers;
                var _userIncludeLockedLayersForFind = includeLockedLayersForFind;
                var _userIncludeLockedStoriesForFind = includeLockedStoriesForFind;
                var _userIncludeMasterPages = includeMasterPages;
              //  do some stuff
                includeFootnotes = _userIncludeFootnotes;
                includeHiddenLayers = _userIncludeHiddenLayers;
                includeLockedLayersForFind = _userIncludeLockedLayersForFind;
                includeLockedStoriesForFind = _userIncludeLockedStoriesForFind;
                includeMasterPages = _userIncludeMasterPages;
          or this:
          app.findChangeGrepOptions.properties = { includeFootnotes:_userIncludeFootnotes, ... };
          app.findGrepPreferences has over 200 properties! For this you can use a loop and ".reflect.properties".
          Best regards
          Roland
          • 2. Re: restoring findGrepPreferences
            Trevorׅ Adobe Community Professional
            Hi Vamital
            This is what you were looking for!
            old_cGPref = app.changeGrepPreferences.properties;
            app.changeGrepPreferences = NothingEnum.NOTHING;
            properties = old_cGPref;
            You needed to add "properties".
            BTW a little sort cut
            app.findChangeGrepOptions = app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.NOTHING;
            Trevor
            • 3. Re: restoring findGrepPreferences
              Vamitul Level 4
              thanks Trevor.
              It worked.
              I know about the shortcut (i actually learned it looking through some of your and Marc's scripts). i'm trying as hard as i can not to use any such shortcuts, as my coding is already very very messy, unindented, with poorly named variables etc. and i often come to the situation when i have to modify a script after 3-4 months, and i end up rewriting it because i can't remember that the .... i was doing in it. Actually this shortcut is easy and straightforward, but.. using them is just like cigarettes... just one more..
              • 4. Re: restoring findGrepPreferences
                Vamitul Level 4
                ok.. another question:
                how tho check if selection is any kind of text:
                    if (app.documents.length != 0 && app.selection.length != 0 &&
                      (app.selection[0].constructor.name=="Text"||app.selection[0].constructor.name=="Paragraph"))
                but sometimes selection is "textStyleRange", sometimes is "character" etc. is there any shortcut to check everything at once?
                • 5. Re: restoring findGrepPreferences
                  Hi Vamitul
                  Start another thread.
                  This question is a little bit off the topic
                  Trevor
