Hi
I am using a datagrid which gets its data from an xml file.
One of the columns is using a field which I would like to use
within Actionscrip so that I can use the strchar function (to
select just a part of the text in that field) and then back to the
datagrid.
How do I do this? Normally, with an itemrenderer i would use
"source={data.fieldname}" to get the data. But when I open an
actionscript instance, I am unable to turn that into a string so
that I can use it.
Another problem I am having with actionscript is that every
single example code I try to use that has "var" and "trace" code
lines returns errors. Even those copied from tutorials, which
should work. Do I need to set up something?
Source Code
MXML File
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"layout="absolute" width="100%" height="100%"
creationComplete="catalog.send()">
<mx:HTTPService url="data/catalog_BCA.xml"
useProxy="false" id="catalog" />
<mx:DataGrid
dataProvider="{catalog.lastResult.Import.Auction}" width="100%"
height="100%" x="0" bottom="0">
<mx:columns>
<mx:DataGridColumn headerText=""
itemRenderer="TipoLeilaoRenderer" width="70"/>
<mx:DataGridColumn headerText="Tipo de Leilão"
dataField="SaleTypeName"/>
<mx:DataGridColumn headerText="Data"
dataField="SaleDate"/>
<mx:DataGridColumn headerText="Date"
itemRenderer="DateFormatter"/>
<mx:DataGridColumn headerText="Local"
dataField="BranchName"/>
</mx:columns>
</mx:DataGrid>
</mx:Application>
ITEMRENDERER
<mx:Box xmlns:mx="
http://www.adobe.com/2006/mxml">
<mx:Script >
<![CDATA[
var str:String = {data.SaleCode};
trace(str.slice(0,3));
</mx:Script>
</mx:Box>
XML FILE
<?xml version="1.0" encoding="UTF-8"?>
<Import>
<Auction>
<CountryCode>PT</CountryCode>
<SaleCode>880</SaleCode>
<BranchCode>01</BranchCode>
<BranchName>LISBOA</BranchName>
<SaleDate>2008-01-31T18:00:00</SaleDate>
<SaleTypeName>GE-Direct</SaleTypeName>
<SaleDescription>GE-Direct LISBOA Jan 31
200</SaleDescription>
<SaleCancelled>false</SaleCancelled>
</Auction>
<Auction>
<SaleCode>881</SaleCode>
<SaleDate>2008-01-31T10:15:00</SaleDate>
<SaleTypeName>Online</SaleTypeName>
<SaleDescription>Online LISBOA Jan 31
</Auction>
</Import>
Can anyone help me with this? Would the code I am trying to
use
Thank you
