3 Replies Latest reply on Aug 26, 2012 12:47 PM by beh_gras_beh
    Choose resolution
    beh_gras_beh
      Dear Indesign Scripters,
      With below script users can export each page to JPG with a pre-defined resolution.
      My question is how can i make the script that users can choose the resolution.
      The quality of the JPG I'm going to try to build myself because I also trying to learn something.
      The script:
      var myDoc = app.documents[0];
      app.scriptPreferences.version = "6.0"
      if(app.documents.length != 0){
          var myFolder = Folder.selectDialog ("Choose a Folder");
          if(myFolder != null){
              myExportPages(myFolder);
      else{
          alert("Please open a document and try again.");
      function myExportPages(myFolder){
          var myDocument = app.activeDocument;
          var myDocumentName = myDocument.name;
      app.jpegExportPreferences.resolution = 72;
      app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.maximum;
      app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.exportRange;
      app.scriptPreferences.version = "7.0"
      app.jpegExportPreferences.jpegColorSpace = JpegColorSpaceEnum.CMYK;
      app.activeDocument.sections.everyItem().includeSectionPrefix = false;
      p = app.activeDocument.pages.everyItem().getElements();
      for (i = 0; i < p.length; i++)
      f = File (myFolder + "/" + p[i].textFrames.item ('script_label').contents + ".jpg");
      app.jpegExportPreferences.pageString = p[i].name;
      app.activeDocument.exportFile (ExportFormat.jpg, f );
      alert('Done!');
      Greetings from Holland
        • 1. Re: Choose resolution
          Muppet Mark Level 5
          You need to look at Peter's scriptUI for dummies pdf that will show you how to add dialogs with control objects to your scripts… You probably just need a dropdownlist and a slider… Links are in the featured content of this forum…
          • 2. Re: Choose resolution
            Harbs. Level 6
            A simple InDesign dialog with a text input should be adequate for requesting the resolution.
            You script displays a very bad practice of changing the script version without changing it back. That could mess up future scripts.
            When changing the script version, always wrap the script in a try/finally:
            try{
            //script...
            finally {
              app.scriptPreferences.version = parseFloat(app.version);
            You can optionally catch the error too...
            Harbs
            • 3. Re: Choose resolution
              beh_gras_beh Level 1
              Thanks Harbs!
              Very usefull!
              I'm still learning, struggeling with the dropdownlist now.
              So I hope it wil work.
              Greetings!
