Having difficulty installing Flash player. At first it would not register despite. Permissions seemed OK. After trying to adjust security settings, I am getting Script error-- Object not found -- after which I am prompted on whether or not to continue running the script. Despite the answer, the script apparently goes into a loop and returns the original error screen. I practically have to reboot to recover. What is the likely problem?
We might be running into a permission issue here. Could you try running through the steps in this FAQ?
Moving this discussion to the Installing Flash Player forum.
Please download Flash Player from the following link. http://helpx.adobe.com/content/help/en/flash-player/kb/installation-problems-flash-player-windows.ht...
Close browsers and run the installer.
Sunil
Thanks, this got me past the first problem, but Flash will still not register. I am logged on as an administrator.
Much gratitude and Many thanks-- this seems to have done the trick.
