3 Replies Latest reply on Aug 28, 2012 11:59 AM by ageofem
    Text No Longer Editable
    Mastov1 Level 1
      An on-off problem seems to be occuring. Sometimes text is not editable. Functions are grayed out. Half the grayed out functions work, half don't. For example I can alter size and color but everything else doesn't work.
        • 1. Re: Text No Longer Editable
          groove25 Level 4
          Do you have a screenshot for this?
          This sounds very unusual, and I can't think of a reason why it would occur. What's especially odd is that you say that functions are grayed out, and yet half of those grayed out functions work! (Typically a grayed out function cannot be interacted with in any way.)
          A text object would be uneditable if it were locked within the Layers panel, or if it had been converted to paths (using Text > Convert to Paths). Other than that, I can't think of an explanation.
          Is this happening within a single document only? Or across multiple documents?
          • 2. Re: Text No Longer Editable
            Mastov1 Level 1
            Yes it is unusual. If it was just grayed out and didn't work, it would still be a problem. The fact that it's grayed out but also works just makes it downright stranger.
            It happened in one document for about 10 minutes. After I minimized the window and reopened it all the unfunctions became ungray and usable again.
            So the problem is resolved for now. But I'll screenshot it in the future if it happens again.
            • 3. Re: Text No Longer Editable
              ageofem Level 1
              What version of fireworks are you using ?
              Try reinstalling fireworks or check on your fonts ( "there might be corrupted fonts") or try disabling some extensions
