0 Replies Latest reply on Aug 26, 2012 5:35 PM by markerline
    XML data (image and accompanying filename)?
    markerline Level 4
      I just recently viewed some video tuts and read some Flex material so I'm a little more comfortable with all of its syntaxes and such.
      However one thing that eludes me when I tried to do this on my own was calling an XML file in mxml and having Flash Builder display the filename and the appropriate image (a jpg file).
      I have an XML file that I automatically created using a shell command which is a shortened version of a directory listing of the jpg files on my hard drive in a specific folder.  I manually cut out everything but the first entry so that I could save time since that folder has lots of jpgs.
      Now, what am I doing wrong that I can't get the XML data to display both the jpg as a visual image object and the filename pulled from one of the attributes in the XML file?
      I'm not posting any code yet in hopes that I can get a direct answer with a code example.  Some of the code seems rather long for me to post here before getting some insight.
      Thanks in advance,
      markerline
      P.S.  This first example is for a web application, not an Adobe AIR runtime.
