2 Replies Latest reply on Aug 28, 2012 1:42 AM by Ruytero
    custom process step
    Ruytero
      Hi
      I'm trying to create a proces flow that uses a custom process step and I'm facing some problems:
      "Only a type can be imported. org.apache.felix.scr.annotations.Component resolves to a package StoreFile.java /ws08-idatest_4502_00cc1fe5-0060-4282-9490-85140078d3f5/WebContent/apps/idamf/src/Store/s rc/main/java/com/idamf/io/Store line 4"
      OR
      Component cannot be resolved to a type StoreFile.java /ws08-idatest_4502_00cc1fe5-0060-4282-9490-85140078d3f5/WebContent/apps/idamf/src/Store/s rc/main/java/com/idamf/io/Store line 25" "
      • When I implement the WotkflowProcess, I cannot seem to get my code to work in a 'Process Step' step in my workflow. The class created, does not show up in the list of selectable processes. When I implement the JavaProcessExt, it does show up in the list.
      • When I create a dialog for my custom process step, I am not able to edit it in my workflow. So I am not able to set the arguments for my process step
      My WorkflowProcess implementation in StoreFile.java, just some very simple code outputting some lines to the log.
      * @author
      @Component
      @Service
      @Properties({
          @Property(name=Constants.SERVICE_DESCRIPTION, value="A sample process step to try and store a file to file system"),
          @Property(name=Constants.SERVICE_VENDOR, value="IDAMF"),
          @Property(name="process.label", value="Store File")
      public class StoreFile implements WorkflowProcess {
        protected final Logger log = LoggerFactory.getLogger(StoreFile.class);
          public void execute(WorkItem arg0, WorkflowSession arg1, MetaDataMap arg2)
                  throws WorkflowException {
              // TODO Auto-generated method stub
           log.info("************** EXECUTING STORE FILE ********************");
      Anybody have an idea what goes wrong?
      thanks&regards
        • 1. Re: custom process step
          Sham HC Level 7
          Please make sure that your .bnd file have two line[1].  After that right click on the .bnd file and click the "Build Bundle" under "Tool" option.Now, you should not get any error while building the bundle for a custom workflow step using your sample code.
          [1]
          Import-Package: *
          Private-Package: *
          • 2. Re: custom process step
            Ruytero Level 1
            Hi Sham
            Thanks for the reply.
            I placed the @Component, @Service, ... outside the comments again.
            The bnd file looks as followed:
            #Export-Package: *
            Import-Package: *
            Private-Package: *
            # Include-Resource:
            Bundle-Name: Store
            Bundle-Description: Store
            Bundle-SymbolicName: Store
            Bundle-Version: 1.0.0-SNAPSHOT
            Bundle-Activator: com.idamf.io.Store.Activator
            This time with the 'Export-Package' in comment, before it was not in comment.
            Still get the errors when compileing and when building, screenshot is attached.
            Grz
            Ronny
