25 Replies Latest reply on Sep 23, 2016 6:57 AM by madduck85
    Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
    Ken Nielsen Level 1
      I know Photoshop quit, or should quit without an error message popping up every time I close the program. This has been going on for the last 5 years, through all the versions since Tiger, through the PowerBook and now the new MacBook Pro, with all software and system updated with every update and upgrade. I'm currently using CS5 And Photoshop extended. Now this is happening with both Photoshop and Lightroom. I've lived with it because it is not stopping my workflow, but it is an error and it would be nice to find the source of the problem and fix it.
      Any Ideas?
      TIA,
      Ken
        • 1. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
          KimberlyGabriel Level 1
          I can't answer your question, so sorry, but I can tell you that that happened to me for about a year and then it stopped. I really wish I could tell you what made it stop, but just letting you know that for me, at least, there was an answer. Like you, I just sort of lived with it. Annoying but wasn't life threatening. I really hope someone knows what is going on.
          • 2. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
            c.pfaffenbichler Level 8
            I can only offer generic advice …
            Boilerplate-text:
            Are Photoshop and OS fully updated?
            As with all unexplainable Photoshop-problems you might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed) by keeping command-alt-shift pressed on starting the program or starting from a new user-account.
            System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
            http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
            Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
            http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.html
            If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
            • 3. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
              Noel Carboni Level 8
              To reinforce what C.Pfaffenbichler has said, memory corruption in Photoshop during the time you're using it could result in a crash on quit.
              What's changed on your system since it worked?  Have you installed any new plug-ins or begun to use features that you didn't use before?
              -Noel
              • 4. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                Level 7
                We know of some OS bugs that can sometimes cause crashes on quit.
                And we know of bugs in some third party plugins that can cause crashes on quit when they are installed.
                But we don't know of anything in Photoshop itself that causes frequent crashes on quit.
                • 5. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                  Ken Nielsen Level 1
                  Yes to all of those. I am a meticulous updater, maintenance, and clean system operator since my first Mac in 1984. This persistes in being a mystery in spite of all precautions and stable operating proceedures in place.
                  • 6. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                    Ken Nielsen Level 1
                    -Noel
                    After 5 years, most everything has changed, including computer upgrade, so it's hard to pinpoint any change because no change has altered the behavior which seems to be set in stone with Photoshop, even through all the Photoshop upgrades. It just suddenly appeared one night and never went away.
                    • 7. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                      Ken Nielsen Level 1
                      This is where I am with it. I learned to completely delete Font Agent Pro and use the Apple compatible Font Book as a way to eliminate strange font behaviors on-screen in Safari. There must be something that I must delete. The scientific way would be to buy a new computer and set it aside for this test. Install Photoshop only. Test. if Ok, install something else and test. Keep going, install and test until the problem arises. Keep full notes on installs for each day so history can be corroberated.
                      • 8. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                        Level 5
                        When I experienced the crash on quit issue on my Mac some years ago, it turned out to be caused by a corrupted saved custom workspace.  Can't remember any other details, sorry.
                        • 9. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                          Ken Nielsen Level 1
                          I don't save a custom workspace, I really work quite conservatively, because I work with a large volume and diverse 'type' of jobs running a full-service advertising agency. Photoshop is at the center of quite a bit of the graphics work which includes photography. It only surprised me the other night as I shut down that now Lightroom gave the same error message 'quit unexpectedly.' I can live with this, nothing is affected adversely really, it's just annoying because it shouldn't be, yet it is.
                          Thanks for all of the comments here, sometimes a comment will make all the difference and lead to a solution. I'll be pondering all of the advice and comments given here, and I thank each of you,
                          Ken
                          • 10. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                            Ken Nielsen Level 1
                            Here's the expanded message upon 'Photoshop Quit Unexpectedly' message:
                            Process:         Adobe Photoshop CS5.1 [337]
                            Path:            /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/MacOS/Adobe Photoshop CS5.1
                            Identifier:      com.adobe.Photoshop
                            Version:         12.1 (12.1x20110328.r.145] [12.1)
                            Code Type:       X86 (Native)
                            Parent Process:  launchd [162]
                            User ID:         501
                            Date/Time:       2012-09-03 22:39:19.229 -0700
                            OS Version:      Mac OS X 10.8.1 (12B19)
                            Report Version:  10
                            Interval Since Last Report:          153190 sec
                            Crashes Since Last Report:           4
                            Per-App Interval Since Last Report:  107566 sec
                            Per-App Crashes Since Last Report:   4
                            Anonymous UUID:                      0BAB0374-336E-4AA5-94D0-4A04C1758AE6
                            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                            Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                            Exception Codes: KERN_INVALID_ADDRESS at 0x0000000080000020
                            VM Regions Near 0x80000020:
                                MALLOC_SMALL           0000000072ef3000-0000000073000000 [ 1076K] rw-/rwx SM=ZER
                                __TEXT                 000000008ed4a000-000000008f58c000 [ 8456K] r-x/rwx SM=COW  /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                            Application Specific Information:
                            objc_msgSend() selector name: release
                            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                            0   libobjc.A.dylib                         0x93e67c07 objc_msgSend + 23
                            1   com.apple.CoreFoundation                0x9001009b CFRelease + 171
                            2   com.apple.CoreFoundation                0x9004af85 __CFBundleDeallocate + 517
                            3   com.apple.CoreFoundation                0x9001039a CFRelease + 938
                            4   ???                                     0x0fe1d500 0 + 266458368
                            5   dyld                                    0x8fec70ed ImageLoaderMachO::doTermination(ImageLoader::LinkContext const&) + 169
                            6   dyld                                    0x8feb4eb8 dyld::runTerminators(void*) + 67
                            7   libsystem_c.dylib                       0x94b02edb __cxa_finalize + 184
                            8   libsystem_c.dylib                       0x94b05dd5 exit + 23
                            9   com.adobe.Photoshop                     0x0000392f 0x1000 + 10543
                            Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                            0   libsystem_kernel.dylib                  0x96bf59ae kevent + 10
                            1   libdispatch.dylib                       0x979a5cc5 _dispatch_mgr_invoke + 993
                            2   libdispatch.dylib                       0x979a57fd _dispatch_mgr_thread + 53
                            Thread 2:
                            0   libsystem_kernel.dylib                  0x96bf48e2 __psynch_cvwait + 10
                            1   libsystem_c.dylib                       0x94acd289 _pthread_cond_wait + 938
                            2   libsystem_c.dylib                       0x94b5ab08 pthread_cond_wait + 48
                            3   com.adobe.amt.services                  0x06707274 C_AMTUISwitchSuppressUpdates + 16864
                            4   com.adobe.amt.services                  0x06700074 C_EULA_SetState + 2166
                            5   com.adobe.amt.services                  0x067072da C_AMTUISwitchSuppressUpdates + 16966
                            6   libsystem_c.dylib                       0x94ac8557 _pthread_start + 344
                            7   libsystem_c.dylib                       0x94ab2cee thread_start + 34
                            Thread 3:
                            0   libsystem_kernel.dylib                  0x96bf27d2 mach_msg_trap + 10
                            1   libsystem_kernel.dylib                  0x96bf1cb0 mach_msg + 68
                            2   com.apple.CoreFoundation                0x90038cc9 __CFRunLoopServiceMachPort + 185
                            3   com.apple.CoreFoundation                0x9003e6af __CFRunLoopRun + 1247
                            4   com.apple.CoreFoundation                0x9003dd6a CFRunLoopRunSpecific + 378
                            5   com.apple.CoreFoundation                0x9004d781 CFRunLoopRun + 129
                            6   com.apple.DVCPROHDMuxer                 0x10435507 AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 285
                            7   libsystem_c.dylib                       0x94ac8557 _pthread_start + 344
                            8   libsystem_c.dylib                       0x94ab2cee thread_start + 34
                            Thread 4:: com.apple.CoreAnimation.render-server
                            2   com.apple.QuartzCore                    0x94d06e24 CA::Render::Server::server_thread(void*) + 441
                            3   com.apple.QuartzCore                    0x94d97836 thread_fun + 29
                            4   libsystem_c.dylib                       0x94ac8557 _pthread_start + 344
                            5   libsystem_c.dylib                       0x94ab2cee thread_start + 34
                            Thread 5:
                            0   libsystem_kernel.dylib                  0x96bf50ee __workq_kernreturn + 10
                            1   libsystem_c.dylib                       0x94acb04c _pthread_workq_return + 45
                            2   libsystem_c.dylib                       0x94acae19 _pthread_wqthread + 448
                            3   libsystem_c.dylib                       0x94ab2cca start_wqthread + 30
                            Thread 6:
                            Thread 7:
                            Thread 0 crashed with X86 Thread State (32-bit):
                              eax: 0x0a421f70  ebx: 0xd0a4225e  ecx: 0x928d2a80  edx: 0x80000000
                              edi: 0x9000fffe  esi: 0x0a421f70  ebp: 0xbffffb88  esp: 0xbffffb28
                               ss: 0x00000023  efl: 0x00010202  eip: 0x93e67c07   cs: 0x0000001b
                               ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                              cr2: 0x80000020
                            Logical CPU: 0
                            Binary Images:
                                0x1000 -  0x23c1fff +com.adobe.Photoshop (12.1 - 12.1x20110328.r.145] [12.1) <620F0F74-C4FF-006C-BDBB-59B126BEB60C> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/MacOS/Adobe Photoshop CS5.1
                            0x2e82000 -  0x2ef2feb +com.adobe.adobe_caps (adobe_caps 4.0.42.0 - 4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                            0x2efd000 -  0x2f03fff  org.twain.dsm (1.9.4 - 1.9.4) <A001BEFA-F163-340E-BB1A-C2905F9FC65B> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                            0x2f0b000 -  0x30f1ff7 +com.adobe.linguistic.LinguisticManager (5.0.0 - 11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                            0x317f000 -  0x32fffe7 +com.adobe.owl (AdobeOwl version 3.0.93 - 3.0.93) <03A8114E-EF8E-FFA2-1DEF-DF2E9CA90E1B> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                            0x3367000 -  0x373fff7 +AdobeMPS (1) <36BB5D09-B87A-77AB-C171-E988910367F8> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                            0x386e000 -  0x3b63fe7 +AdobeAGM (1) <3E69B52D-C887-B153-5313-FBA9E252407F> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                            0x3c16000 -  0x3f00ff7 +AdobeCoolType (1) <7FCAAAB7-EFCC-6D62-D96D-ACEAC622D649> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                            0x3f84000 -  0x3fa5ff7 +AdobeBIBUtils (1) <63FC9304-CFD2-694B-B772-329087F12562> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                            0x3fb1000 -  0x3fd7ff6 +AdobeAXE8SharedExpat (0) <A5A71903-F2F8-CB16-76C0-ACCD05F1C736> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedEx pat
                            0x3fe8000 -  0x4120fe7 +WRServices (0) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                            0x4162000 -  0x41bffef +aif_core (0) <20A1379B-4F9C-E21A-ECE7-B33F95BC6289> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                            0x41dc000 -  0x41effff +data_flow (0) <AF659FB7-5D0F-2150-75A8-059ED7F7F3E4> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                            0x4207000 -  0x4299fff +image_flow (0) <4EED2290-702B-BAB2-8D71-9A3483BA6070> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                            0x430c000 -  0x4326ff7 +image_runtime (0) <F844CFE0-4FFB-B380-179A-7E6478EA6B3D> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                            0x4343000 -  0x4574ffb +aif_ogl (0) <DBCA6AC7-94E7-3B26-ED7C-B1CF2D45F4AE> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                            0x4660000 -  0x46eafef +AdobeOwlCanvas (1) <3B9B9050-7F74-EBBA-99E1-4202D49B321A> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
                            0x470c000 -  0x4a29fef +com.adobe.dvaui.framework (dvaui version 5.0.0 - 5.0.0.0) <57907A7F-6D01-C35F-29B4-28C2DFE35157> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                            0x4b8d000 -  0x4d08fe7 +com.adobe.dvacore.framework (dvacore version 5.0.0 - 5.0.0.0) <ED2C7256-FDB7-63CD-23F8-1748AA53D397> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                            0x4da3000 -  0x50ebfff +com.adobe.dvaadameve.framework (dvaadameve version 5.0.0 - 5.0.0.0) <18ABE6DC-26AD-2C95-D68F-4E8E1306D4E2> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                            0x521f000 -  0x5334fff +AdobeACE (1) <BFF50B9A-8BCA-08D1-0260-FF251DA05EC7> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                            0x5357000 -  0x5371fff +AdobeBIB (1) <C77AD4A4-5C74-95C3-B012-E82FDF8A91AB> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                            0x537a000 -  0x53e8ffb +com.adobe.amtlib (amtlib 4.0.0.21 - 4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                            0x53ff000 -  0x5402ffc +com.adobe.ape.shim (adbeape version 3.1.74.12761 - 3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                            0x5409000 -  0x5476fef +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5.0 -i 33 [debug] - 64.140949) <B92E33A8-902E-FFAD-569A-D762D04C9330> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                            0x5491000 -  0x54e9ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.0 -c 61 - 64.140949) <0EF6395B-99B0-A7E6-30BA-24E87D3E7B49> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                            0x54f8000 -  0x5957fe7 +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/Cg.framework/Cg
                            0x5d3f000 -  0x5d92ffb +com.adobe.headlights.LogSessionFramework (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                            0x5dda000 -  0x5dfbffe +adobepdfsettings (1) <935615E5-C4BA-E18B-A9C9-178BCC4D8126> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
                            0x5e30000 -  0x5e34ffc +com.adobe.AdobeCrashReporter (3.0 - 5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                            0x5e3a000 -  0x5fb4fe3 +com.adobe.PlugPlug (2.5.0.232 - 2.5.0.232) <04C90B5C-DC6D-A2B5-BE9B-193466222BE7> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                            0x605d000 -  0x6108fff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
                            0x614c000 -  0x6162ff9 +libtbb.dylib (0) /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/libtbb.dylib
                            0x6172000 -  0x6176ffd +libtbbmalloc.dylib (0) /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/libtbbmalloc.dylib
                            0x617d000 -  0x6184ff2 +com.adobe.boost_threads.framework (boost_threads version 5.0.0 - 5.0.0.0) <37374715-2FC3-B77B-EFD8-9403A80C7F70> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                            0x618c000 -  0x61c8ff7  com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                            0x6384000 -  0x6385ffd  com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                            0x66e2000 -  0x674dfe7 +com.adobe.amt.services (AMTServices 4.0.0.21 [BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00] - 4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservices
                            0x678d000 -  0x679affb  com.apple.Librarian (1.1 - 1) <C8D82AA3-AE5E-3B6D-A8D1-847856057186> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                            0x67c7000 -  0x67d5fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                            0x67d9000 -  0x67ebffd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                            0x7695000 -  0x7697fff  libCoreFSCache.dylib (24.4) <A089ED2E-0156-3937-BE32-5BED76DF4066> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                            0x769c000 -  0x769dff8  ATSHI.dylib (341) <3A73E02F-0EDA-32F8-A768-17C9E417C82C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                            0x76c7000 -  0x76cfff2  libcldcpuengine.dylib (2.1.16) <61717F57-9AAC-31B4-8894-27A1BF7987B9> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                            0x76f3000 -  0x76fbfff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
                            0xa5fe000 -  0xa5ffff5 +cl_kernels (???) <8DF6D5F5-EC22-41A3-A374-487EDF273077> cl_kernels
                            0xa60c000 -  0xa60cff7 +cl_kernels (???) <D5D7177C-47A8-4CDC-8158-B5DF0DAED3DC> cl_kernels
                            0xa60e000 -  0xa6a0ff7  unorm8_bgra.dylib (2.1.16) <0F63B53F-4A0A-3485-9645-200572D265F5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                            0xa6c0000 -  0xa6c1ff1 +cl_kernels (???) <FA4F7633-669B-4FA1-9D0A-CDA3B8103240> cl_kernels
                            0xa6c7000 -  0xa6c7ffd +cl_kernels (???) <9170C28F-EA82-4872-9100-288712848723> cl_kernels
                            0xa7f4000 -  0xa7f5ffd +cl_kernels (???) <EA0BDBF7-CA8E-4D45-9E03-17A40849F4B0> cl_kernels
                            0xe87b000 -  0xe87cfff +com.google.GoogleNotifierQuickAddCMPlugin (1.10.5 - 1.10.5.778) <51896589-0C02-EB69-2463-7C6E8455CDE4> /Users/USER/Library/Contextual Menu Items/Google Notifier Quick Add CM Plugin.plugin/Contents/MacOS/Google Notifier Quick Add CM Plugin
                            0xeca8000 -  0xecadfff  com.apple.audio.AppleHDAHALPlugIn (2.3.0 - 2.3.0f2) <D971DBC9-B1D6-3F20-A6EA-B165C32A4E69> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                            0xefaf000 -  0xf0fbffb +com.adobe.coretech.adm (3.10x16 - 3.1) <75AEFCB0-BFD1-70F9-BE2F-35A8B0D0B77A> /Applications/Adobe Photoshop CS5.1/*/AdobeADM.bundle/Contents/MacOS/AdobeADM
                            0xf729000 -  0xf729fff +jp.co.canon.scangear.sgutility2.framework (2.0.0 - 2.0.0) /Library/Application Support/Canon/*/SGUtility.framework/Versions/A/SGUtility
                            0xf759000 -  0xf75cfef  com.apple.LiveType.component (2.1.3 - 2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
                            0xf761000 -  0xf7c6fde  com.apple.LiveType.framework (2.1.3 - 2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
                            0xf7e6000 -  0xf853fff +com.DivXInc.DivXDecoder (6.6.0 - 6.6.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
                            0xf8b1000 -  0xf8b3ffb +jp.co.canon.ScanGearMP.CalcToneframework (1.2.0 - 1.2.0) /Library/Application Support/Canon/*/CalcTone.framework/Versions/A/CalcTone
                            0xf8f8000 -  0xf8f9fff +com.ecamm.pluginloader (Ecamm Plugin Loader v1.0.5 - 1.0.5) /Library/InputManagers/*/Ecamm Plugin Loader.bundle/Contents/MacOS/Ecamm Plugin Loader
                            0xfa40000 -  0xfa4cffb  libGPUSupport.dylib (8.5) <DCEDB13E-6E2C-3D14-965E-70522403723B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport .dylib
                            0xfa5d000 -  0xfa6cfff +jp.co.canon.ScanGearMP.SGCommonUInterfaceframework (1.4.0 - 1.4.0) /Library/Application Support/Canon/*/SGCommonUInterface.framework/Versions/A/SGCommonUInterface
                            0xfa7c000 -  0xfaaf007 +jp.co.canon.scangear.sgsm3.framework (1.3.1 - 1.3.1) /Library/Application Support/Canon/*/SGSM3.framework/Versions/A/SGSM3
                            0xfac0000 -  0xfd5bfe7 +jp.co.canon.ScanGearMP.SGUserInterfaceframework1310 (1.1.4 - 1.1.4) /Library/Application Support/Canon/*/SGUserInterface1310.framework/Versions/A/SGUserInterface1310
                            0x10322000 - 0x103e0ff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                            0x10424000 - 0x1046bfef  com.apple.DVCPROHDMuxer (1.2 - 1.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
                            0x11a00000 - 0x11c33fff +com.adobe.PSAutomate (12.1 - 12.1) <1093524B-17BB-F62D-6034-9B793A9AFE37> /Applications/Adobe Photoshop CS5.1/*/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
                            0x11e10000 - 0x11ea8fff +com.adobe.AdobeExtendScript (ExtendScript 4.1.28 - 4.1.28.12764) <8BB26FD8-9D3B-1DE3-6FB3-E71F970718D3> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                            0x11f09000 - 0x11f96ff7 +com.adobe.AdobeScCore (ScCore 4.1.28 - 4.1.28.12764) <410AEFDB-A716-D200-E889-BFCB3CCC17A9> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                            0x12100000 - 0x12129fef +com.adobe.ape (adbeapecore version 3.1.74.12761 - 3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                            0x12600000 - 0x1345dfeb +com.adobe.adobeswfl (2.0.0.11360) <3E243C12-18DB-469A-DFA9-B0AE4A1C620F> /Library/Application Support/Adobe/*/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/AdobeSWFL
                            0x1381c000 - 0x1386efc3  com.apple.DVCPROHDAudio (1.2 - 1.2) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
                            0x14800000 - 0x14839ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 2.0.0.15 - 2.0.0.15) <3A9CF871-6678-90BB-3770-CDBF56AF21D5> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/updaternotifications.framework/Versions/a/UpdaterNotificati ons
                            0x14849000 - 0x1486cfe7 +ServiceManager-Launcher.dylib (236) <F2933B29-0CC1-00B4-1778-BF44110851F8> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
                            0x1487a000 - 0x15a3bfeb +com.adobe.CameraRaw (6.7 [339] - 6.7.0f339) <EFED284E-C613-1300-F53D-96C3AB726436> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
                            0x18570000 - 0x185a5fef +com.adobe.pip (5.5.0.1265) <660E209C-F595-AB0B-FB5E-C8FC1527CF4D> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                            0x18610000 - 0x1879cff8  GLEngine (8.5) <23C1BECF-D0EF-339D-B312-EFACB26C5983> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                            0x187d3000 - 0x18924ff7  libGLProgrammability.dylib (8.5) <27E2DAE2-DECE-364C-A1C2-138735A3869E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                            0x1ac40000 - 0x1ac6cffa  GLRendererFloat (8.5) <1E69D3D7-1782-3FF8-AB52-3F23DC4F617B> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                            0x1b800000 - 0x1bb56ff3  com.apple.driver.AppleIntelHDGraphicsGLDriver (8.0.51 - 8.0.0) <361EB242-64CF-3816-A027-9690167B29C8> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelH DGraphicsGLDriver
                            0x40000000 - 0x400d1fe7 +AdobeJP2K (0) <688BEA6A-50D2-D875-62BA-8D8611FA57E9> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                            0x47800000 - 0x47b45fef +com.adobe.standard.multiplugin (12.0.2 - 12.0.2) <6819E340-004D-A325-727F-ED8EEDF6DA86> /Applications/Adobe Photoshop CS5.1/*/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
                            0x49019000 - 0x4903cfff +com.stuffit.StuffItCM (11.0.2 - 11.0.2) /Library/Contextual Menu Items/StuffItCM.plugin/Contents/MacOS/StuffItCM
                            0x49057000 - 0x4909efe3 +com.stuffit.sdk (11.0.2 - 11.0.2) /Library/Frameworks/StuffIt.framework/Versions/B/StuffIt
                            0x490fc000 - 0x49196fdb +com.stuffit.stuffitcore (11.0.2 - 11.0.2) /Library/Frameworks/StuffItCore.framework/Versions/A/StuffItCore
                            0x49273000 - 0x4929cff7  com.apple.datadetectors (4.0 - 199.0) <664C00F7-1E59-33F8-9401-DB4784A189B6> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                            0x492b3000 - 0x493d1ff3  com.apple.WebKit (8536 - 8536.25) <5365AA39-A1A7-315D-AA1C-0C564909C0E0> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                            0x49481000 - 0x4a10bff3  com.apple.WebCore (8536 - 8536.24) <06F7EC1E-A7F2-37F1-ADC6-687284E661D8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                            0x8ed4a000 - 0x8f58bffb  com.apple.GeForceGLDriver (8.0.51 - 8.0.0) <6558382E-52E4-37C5-BC83-9A73E656167C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                            0x8feb3000 - 0x8fee5e57  dyld (210.2.3) <23516BE4-29BE-350C-91C9-F36E7999F0F1> /usr/lib/dyld
                            0x90007000 - 0x901eeffb  com.apple.CoreFoundation (6.8 - 744) <A2BB4949-264A-302B-897E-713860894FE6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                            0x901ef000 - 0x90222ff3  com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                            0x90223000 - 0x904e0ff3  com.apple.security (7.0 - 55178.0.1) <EB90D52E-27EC-3874-BA15-C69976F1067A> /System/Library/Frameworks/Security.framework/Versions/A/Security
                            0x904e1000 - 0x9050effe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
                            0x9050f000 - 0x9054eff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                            0x9054f000 - 0x9064bff3  com.apple.DiskImagesFramework (10.8 - 344) <98C16F91-9D3E-3FD0-A30B-BD49EE4ED9A4> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                            0x9064c000 - 0x90744ff2  libsqlite3.dylib (138) <AA00F27E-B72D-31DE-8EE4-985227CC9912> /usr/lib/libsqlite3.dylib
                            0x90745000 - 0x90880ff7  libBLAS.dylib (1073.3) <804B5AF7-2646-31D1-8875-FCCF158476D4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                            0x90881000 - 0x9096aff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
                            0x9096b000 - 0x90972ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                            0x90973000 - 0x90d05ff3  com.apple.MediaToolbox (1.0 - 926.37) <6B111039-22B1-3ED0-9E1B-E4810B6BC23E> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                            0x90d46000 - 0x90d88fff  libcurl.4.dylib (69.2) <8CC566A0-0B25-37E8-A6EC-30074C3CDB8C> /usr/lib/libcurl.4.dylib
                            0x90d89000 - 0x90e11fff  com.apple.PDFKit (2.7 - 2.7) <D65CBEF8-4BEF-38E4-8622-ECEA79C66F7F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                            0x90e12000 - 0x91069fff  com.apple.JavaScriptCore (8536 - 8536.24) <361AF27F-4E6B-3D86-B363-95DED1D56981> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                            0x9106a000 - 0x91093ff7  libRIP.A.dylib (322) <48626D20-EFD2-3F8C-B458-30514DDD7984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                            0x91094000 - 0x910f8ff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
                            0x910f9000 - 0x910fbfff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
                            0x910fc000 - 0x910ffffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
                            0x91100000 - 0x91257ff7  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <6856CA9B-BF08-341B-AEE9-91CC258D4534> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                            0x91258000 - 0x91258fff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                            0x91259000 - 0x912b2ffb  com.apple.ImageCaptureCore (4.0 - 4.0) <29FC269A-79E8-3FBD-A462-F2621485D4BB> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                            0x912b3000 - 0x912bfff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
                            0x912c0000 - 0x91335ff7  com.apple.ApplicationServices.ATS (332 - 341) <472F564A-BD46-30C3-92F5-87273A512910> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                            0x91336000 - 0x9134bfff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                            0x9134c000 - 0x9137cff3  libtidy.A.dylib (15.10) <F2F4E000-E305-3089-91E6-3DB0ED07E74A> /usr/lib/libtidy.A.dylib
                            0x9137d000 - 0x913a2ff7  com.apple.quartzfilters (1.8.0 - 1.7.0) <F6A88D89-AB4A-3217-9D65-C2C259B5F09B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                            0x913e0000 - 0x913f9fff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                            0x913fa000 - 0x91403ffe  com.apple.aps.framework (3.0 - 3.0) <75A60380-46BE-31FA-8267-9DE6A32D6FC0> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                            0x91404000 - 0x91431ffb  com.apple.CoreServicesInternal (153 - 153) <DB105788-CCF5-3678-88C5-65A7267DC581> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                            0x91432000 - 0x9143effd  com.apple.CrashReporterSupport (10.8.1 - 412) <9BBEBED1-DEDD-3258-A8CC-F46EC5CDD4F7> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                            0x9143f000 - 0x91454fff  com.apple.speech.synthesis.framework (4.1.10 - 4.1.10) <20E394D6-D9BA-3C1D-993A-533B60EF3B63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                            0x91455000 - 0x91570ff7  com.apple.desktopservices (1.7.1 - 1.7.1) <0039FBAA-BB0B-36B7-962F-BDAC8E3D1C58> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                            0x91dee000 - 0x91df2fff  com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                            0x91df3000 - 0x91e5bfe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                            0x91e5c000 - 0x91e5dffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                            0x91e5e000 - 0x91e61ff9  libCGXType.A.dylib (322) <2090D588-49DD-3DB6-A296-8E7B0FF1482A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                            0x91e62000 - 0x91ebdfff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                            0x91ebe000 - 0x91ef4ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                            0x91ef5000 - 0x91ef5fff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                            0x91f25000 - 0x92adefff  com.apple.AppKit (6.8 - 1187) <5E13B150-4096-3B61-9DC0-6ABA48F6515B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                            0x92adf000 - 0x92c9bffd  libicucore.A.dylib (491.11.1) <DB04A8FD-9BBE-3CBC-869F-8FA855FB43D2> /usr/lib/libicucore.A.dylib
                            0x92c9c000 - 0x930deff3  com.apple.CoreGraphics (1.600.0 - 322) <2E04AAAD-8403-3819-BD6C-9836D42F58B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                            0x930e1000 - 0x931feff3  com.apple.MediaControlSender (1.4.1 - 141.23) <D2B3E1AC-AB2B-3811-B1EC-E794ECA81C81> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                            0x931ff000 - 0x93256ff3  com.apple.Suggestions (2.0 - 102.1) <AA369EDE-913D-3C0D-8CE1-92C1C171CCA7> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                            0x93257000 - 0x932eefff  com.apple.ink.framework (1.4 - 110) <C01F2572-E7E4-3A6C-B4F2-2F97B4AD43D5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                            0x932ef000 - 0x932f1fff  libCVMSPluginSupport.dylib (8.5) <9043B315-4E68-3262-A310-76E64F0409C9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                            0x932f2000 - 0x933d3fff  libcrypto.0.9.8.dylib (47) <D4EFFCFB-206D-3E3D-ADB5-CBAF04EB8838> /usr/lib/libcrypto.0.9.8.dylib
                            0x933d8000 - 0x933e0fff  com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                            0x933e1000 - 0x934f1ffb  com.apple.QuickTimeImporters.component (7.7.1 - 2599) <CF2ACD4E-EC81-371A-82B8-EB812DB195D8> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
                            0x934f2000 - 0x93783fff  com.apple.AddressBook.framework (7.0 - 1143) <689FB192-FFE0-3B3A-A407-FA618E6AED85> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                            0x93784000 - 0x937d0fff  libcorecrypto.dylib (106) <FAAD1A30-0D84-3A17-AC40-288EF0F529AA> /usr/lib/system/libcorecrypto.dylib
                            0x937d1000 - 0x93813ff7  com.apple.RemoteViewServices (2.0 - 80.3) <EE36AF6C-E574-3F48-9AC3-E8C8295739FF> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                            0x93814000 - 0x93814ffe  com.apple.AOSMigrate (1.0 - 1) <4EA0829E-6AE5-3877-A5B6-032AFDF28D39> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
                            0x93815000 - 0x9383fff9  com.apple.framework.Apple80211 (8.0 - 800.15) <DC1EC5B5-7021-3CFC-8C32-FD515F1F9C58> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                            0x93840000 - 0x938baff7  com.apple.securityfoundation (6.0 - 55115.4) <A959B2F5-9D9D-3C93-A62A-7399594CF238> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                            0x938bb000 - 0x93a07ff3  com.apple.CFNetwork (596.1 - 596.1) <DE5FA267-6E01-388E-9ADA-8764BE469C35> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                            0x93a08000 - 0x93a24ff7  libPng.dylib (843) <43C3DD20-4BB2-3429-A40A-7FF9BC50E5FB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                            0x93a25000 - 0x93d42fff  com.apple.Foundation (6.8 - 945) <B6F00754-C3F7-3E33-B708-CCEA2AA3E969> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                            0x93d43000 - 0x93d78ff7  com.apple.framework.internetaccounts (2.0 - 200) <AA6349FE-B029-3755-9DF5-90CD13CFB5A0> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
                            0x93d79000 - 0x93daefff  libTrueTypeScaler.dylib (84.5) <2598F930-5E6B-37D7-B1E6-18181A972C6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                            0x93daf000 - 0x93dc6fff  com.apple.GenerationalStorage (1.1 - 132.1) <4E0F0C47-7796-3152-A77D-F6456287498A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                            0x93dc7000 - 0x93de4fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
                            0x93de5000 - 0x93e61ffb  com.apple.Metadata (10.7.0 - 707.1) <E18350AD-CAA9-3323-BDE9-63A688792C6C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                            0x93e62000 - 0x93f6f15f  libobjc.A.dylib (532) <9663A040-F232-3E2A-8318-AA40B940AF6F> /usr/lib/libobjc.A.dylib
                            0x93f70000 - 0x941eaff3  com.apple.RawCamera.bundle (3.14.2 - 644) <3A5383AC-F30A-3674-88F4-DF82ADE8D73E> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                            0x941eb000 - 0x94299ff3  com.apple.CoreText (260.0 - 275.14) <3CC31B7F-5560-364A-ADFC-31861C3C2328> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                            0x9429a000 - 0x9460fff3  com.apple.FinderKit (1.1 - 1.1) <9C671FF8-21F1-3F31-8179-1E493D370165> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                            0x94610000 - 0x946aafff  com.apple.CoreSymbolication (3.0 - 87) <6A27BBE5-6EF0-3D5D-A485-2145826B9796> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                            0x94745000 - 0x9474cfff  libsystem_dnssd.dylib (379.27.1) <B5CD3F39-7039-30CF-877D-FDF38A659E46> /usr/lib/system/libsystem_dnssd.dylib
                            0x9474f000 - 0x94758fff  com.apple.DisplayServicesFW (2.6 - 352.4.2) <96F5E1F9-395F-3695-80E9-F3803BCD6576> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                            0x94765000 - 0x94766fff  libDiagnosticMessagesClient.dylib (7) <B2BC685E-C129-3F6B-9222-AF3CF4F186AC> /usr/lib/libDiagnosticMessagesClient.dylib
                            0x94767000 - 0x9476aff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
                            0x9476b000 - 0x949d4ff7  com.apple.imageKit (2.2 - 660) <66EE23B9-3562-3888-833B-DDB732603C14> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                            0x949d5000 - 0x949e0ffb  com.apple.DirectoryService.Framework (10.8 - 151.10) <234F4A14-60ED-300B-93B2-D5052878558F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                            0x949e1000 - 0x94a81ff7  com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                            0x94a82000 - 0x94ab1ff7  com.apple.securityinterface (6.0 - 55024.3) <64FA808A-4DBE-3F7B-AEA8-369C70B77DB8> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                            0x94ab2000 - 0x94b6fffb  libsystem_c.dylib (825.24) <7D90CAC5-EC98-35F8-A52E-81B54F0C7DCC> /usr/lib/system/libsystem_c.dylib
                            0x94b70000 - 0x94b7cffc  libkxld.dylib (2050.9.2) <301804CB-55F1-3A9B-BC45-DEB020C22C6F> /usr/lib/system/libkxld.dylib
                            0x94b7f000 - 0x94b83fff  com.apple.IOSurface (86.0.2 - 86.0.2) <BDF93CE4-9F14-3747-9CD5-FFE71D488BDA> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                            0x94b84000 - 0x94b84fff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                            0x94c3d000 - 0x94db5ff5  com.apple.QuartzCore (1.8 - 304.0) <0B0EC55A-9084-3E28-9A84-1813CE3FAA9B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                            0x94db6000 - 0x94dc4ff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
                            0x94dc5000 - 0x954ccff0  libclh.dylib (4.0.3 - 4.0.3) <6B247540-E9FC-3DA9-9311-9246EA863E03> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                            0x954cd000 - 0x954cdffd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <B688A998-93B5-3D9B-BAE4-E49947AA82B4> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                            0x954ce000 - 0x954d8fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                            0x954d9000 - 0x9556bffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                            0x9556c000 - 0x955aeff7  libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
                            0x955af000 - 0x95c3bfeb  com.apple.CoreAUC (6.16.00 - 6.16.00) <654A0AB8-F24F-3489-8F70-F0A22414FE08> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                            0x95c3c000 - 0x95c59fff  libxpc.dylib (140.37) <F61095FA-B2CF-3CD8-9088-9D9FC18B38BC> /usr/lib/system/libxpc.dylib
                            0x95c5a000 - 0x95c6aff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                            0x95d4c000 - 0x95d5afff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
                            0x95d5b000 - 0x95d6dfff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
                            0x95d6e000 - 0x95da5ffa  com.apple.LDAPFramework (2.4.28 - 194.5) <AA8CC981-78EF-38F0-9959-83DEF9E418DC> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                            0x95da6000 - 0x961c3ff3  FaceCoreLight (2.0.1) <3EF03B25-C361-31A6-8704-3FBFFBD0E10B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                            0x961c4000 - 0x96204fff  com.apple.MediaKit (13 - 658) <2CF2116F-EA07-31BB-A702-5B6C77F9D68B> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                            0x96205000 - 0x962afff7  com.apple.LaunchServices (539 - 539) <4C026504-5420-35D7-912E-A584C6F9FFC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                            0x962b0000 - 0x962c6fff  com.apple.CFOpenDirectory (10.8 - 151.10) <56C3F276-BD1F-3031-8CF9-8F4F481A534E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                            0x962c7000 - 0x963dfff7  com.apple.coreavchd (5.6.0 - 5600.4.16) <F024C78B-4FAA-38F1-A182-AD0A0A596CBE> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                            0x963e0000 - 0x96447ff7  com.apple.framework.IOKit (2.0 - 755.9.7) <CB976A7C-2601-3054-BC41-C3AD6896327C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                            0x96448000 - 0x965a5ffb  com.apple.QTKit (7.7.1 - 2599) <78806D5A-A983-3C4C-A151-2AEF28779358> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                            0x965a6000 - 0x965a9ffd  libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                            0x965aa000 - 0x965b8fff  com.apple.opengl (1.8.5 - 1.8.5) <AA14FBC0-8AF3-3CCB-A390-C8F9AE81E1E9> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                            0x965c3000 - 0x965eefff  com.apple.shortcut (2.2 - 2.2) <FA94F2BF-37E1-3F16-9085-7BCCB815BAE9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                            0x965ef000 - 0x96655fff  com.apple.print.framework.PrintCore (8.0 - 387) <84DFC4F0-3186-3C59-9EBD-9EF2C3561A43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                            0x96656000 - 0x96656fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                            0x96657000 - 0x96657ffd  libOpenScriptingUtil.dylib (148) <6B34E8E4-EE31-3E2B-AEB3-8714C3102AED> /usr/lib/libOpenScriptingUtil.dylib
                            0x9665a000 - 0x96667ff7  com.apple.HelpData (2.1.3 - 84) <D62F7C48-AA6C-3B3A-B5A4-52330A4F361F> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                            0x96668000 - 0x966b7ff6  libTIFF.dylib (843) <AA81BA16-8026-35DA-8193-2C8715ACD435> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                            0x966b8000 - 0x96701ff3  com.apple.framework.CoreWLAN (3.0 - 300.9) <0C5A2604-2185-3D71-950C-D5E93239419A> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                            0x96702000 - 0x96703ffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
                            0x96704000 - 0x9675dff7  com.apple.AE (645 - 645) <D4919967-EF16-36BA-9E8A-DA110DE8BB4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                            0x9675e000 - 0x9675efff  libSystem.B.dylib (169.3) <81C58EAB-0E76-3EAB-BDFD-C5A6FE95536F> /usr/lib/libSystem.B.dylib
                            0x9675f000 - 0x9678bff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
                            0x9678c000 - 0x9678cfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
                            0x9678d000 - 0x967e8ff7  com.apple.AppleVAFramework (5.0.18 - 5.0.18) <4BA2AAEA-4936-375C-B4D8-4BBE2EDC7FF5> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                            0x967e9000 - 0x96858ffb  com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                            0x96864000 - 0x96889ff7  com.apple.CoreVideo (1.8 - 99.0) <7A90C337-4493-3393-9C56-75EB52112D75> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                            0x96890000 - 0x96891fff  libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
                            0x96892000 - 0x968effff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                            0x968f0000 - 0x96909ffb  com.apple.frameworks.preferencepanes (15.0 - 15.0) <5F610D7F-8AAC-300B-9331-FD95701D3304> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
                            0x9690a000 - 0x96961ff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                            0x96962000 - 0x9696eff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                            0x9696f000 - 0x96976fff  liblaunch.dylib (442.21) <349330F8-1BBF-3B78-AFB2-4F32413CE971> /usr/lib/system/liblaunch.dylib
                            0x96977000 - 0x96985ff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
                            0x96986000 - 0x9698afff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                            0x9698b000 - 0x9699bff7  libsasl2.2.dylib (166) <D9080BA2-A365-351E-9FF2-7E0D4E8B1339> /usr/lib/libsasl2.2.dylib
                            0x9699c000 - 0x969a6ffc  com.apple.bsd.ServiceManagement (2.0 - 2.0) <D3112172-D3A7-3C9A-825D-5630D47327D1> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                            0x969a7000 - 0x969a7fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                            0x969a8000 - 0x969d1fff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
                            0x969d2000 - 0x96a57ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                            0x96a58000 - 0x96a9dff5  com.apple.opencl (2.1.17 - 2.1.17) <921C1549-637A-33D7-A891-834FB9F582C7> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                            0x96aed000 - 0x96bc1ff7  com.apple.backup.framework (1.4 - 1.4) <12123FB8-B42D-38B0-8463-6BA375C3C643> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                            0x96bc2000 - 0x96bdffff  com.apple.openscripting (1.3.5 - 148) <3460338D-B686-3C33-B322-DC8391668F8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                            0x96be0000 - 0x96bfaffc  libsystem_kernel.dylib (2050.9.2) <C6BA5A9F-08BB-3544-9A36-070DEDE92279> /usr/lib/system/libsystem_kernel.dylib
                            0x96bfb000 - 0x96c1dff3  libc++abi.dylib (24.2) <4C064BFE-B8B4-35CA-AB3C-F6A47D47A0F2> /usr/lib/libc++abi.dylib
                            0x96c1e000 - 0x96c3eff7  com.apple.ChunkingLibrary (2.0 - 132) <172C3F7F-CB49-323F-932F-35340999979E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                            0x96c45000 - 0x96c63ffb  com.apple.Ubiquity (1.2 - 234.2) <BEFF43DE-CF72-3E66-90C8-CAECAFD5F3ED> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                            0x96c64000 - 0x96c65fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
                            0x96c66000 - 0x96c67fff  libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
                            0x96c68000 - 0x96c8cfff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                            0x96c8d000 - 0x96cdbffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                            0x96cdc000 - 0x96cdcfff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                            0x96d0e000 - 0x96d64ff3  com.apple.HIServices (1.20 - 416) <B23E2C58-A6A5-32B6-811C-0F0551E14483> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                            0x96d65000 - 0x96e18ff7  com.apple.coreui (2.0 - 181) <4F071012-F857-367D-B0B8-EAD088A05740> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                            0x96e19000 - 0x96e1dffc  libGIF.dylib (843) <355B672B-D07D-36FE-B6B9-142406ACFBA2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                            0x96e1e000 - 0x96e22ff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
                            0x96e23000 - 0x96e64ff7  com.apple.framework.CoreWiFi (1.0 - 100.10) <944B3FAE-F901-3276-A676-9D52295DA817> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                            0x96e65000 - 0x96ecbffc  com.apple.ISSupport (1.9.8 - 56) <D2AC4E10-0B3C-3194-AEB7-1E9964CBC0D0> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
                            0x96ecc000 - 0x96f2efff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
                            0x96f2f000 - 0x96f33ffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
                            0x96f34000 - 0x96f7bff3  com.apple.CoreMedia (1.0 - 926.37) <9F458B7C-9F81-3CCF-939D-2E58FE93B86A> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                            0x96f7c000 - 0x97266fff  com.apple.AOSKit (1.05 - 148) <9F077C87-CDC2-308E-83A1-06A9662482F9> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
                            0x97267000 - 0x9727aff9  com.apple.MultitouchSupport.framework (235.27 - 235.27) <75D9C0FD-6A40-3A9E-8861-C74DBE137CF3> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                            0x9727b000 - 0x9750cffb  com.apple.CoreImage (8.0.17 - 1.0.1) <CE54EC11-1C41-3857-B82D-F8B7D1798F42> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                            0x9750d000 - 0x9750fffb  libRadiance.dylib (843) <6C2B92DB-A537-3618-9E68-F006DF427D2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                            0x97510000 - 0x97541ff7  com.apple.DictionaryServices (1.2 - 184) <9199E88F-2477-3596-9F56-B8E317A7164D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                            0x97542000 - 0x97542fff  com.apple.Carbon (154 - 155) <604ADD9D-5835-3294-842E-3A4AEBCCB548> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                            0x97543000 - 0x97584ff7  libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
                            0x97585000 - 0x97590fff  libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
                            0x975a0000 - 0x9761cffb  libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
                            0x9761d000 - 0x9761dfff  com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                            0x9761e000 - 0x97624fff  com.apple.phonenumbers (1.1 - 47) <DD22B3D1-DA4B-3794-9D73-E90D49A1F88E> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                            0x97625000 - 0x9762dfff  com.apple.DiskArbitration (2.5 - 2.5) <E49427B0-5317-3DFD-B12E-117402BB19CB> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                            0x9762e000 - 0x97634ffc  libCGXCoreImage.A.dylib (322) <85B27BF1-8CCA-3C26-92D6-6C44B4A3C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                            0x97635000 - 0x9763effd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                            0x9763f000 - 0x9783fffb  com.apple.CoreData (106 - 407.5) <B4386286-5C67-3134-A5BD-852447DA696E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                            0x97845000 - 0x978ddff7  com.apple.CoreServices.OSServices (557 - 557) <219C11A8-8446-336E-B518-F52D1571420F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                            0x978de000 - 0x9799cff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                            0x979a1000 - 0x979b3ff7  libdispatch.dylib (228.18) <833C83BE-278C-353E-AC6D-9B85FAC50A1D> /usr/lib/system/libdispatch.dylib
                            0x979b4000 - 0x979e7ff5  libssl.0.9.8.dylib (47) <3224FBB3-3074-3022-AD9A-187703680C03> /usr/lib/libssl.0.9.8.dylib
                            0x979e8000 - 0x97ad9ffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
                            0x97b00000 - 0x97b24ff2  com.apple.framework.familycontrols (4.0 - 400) <A313D83E-5A03-3174-A213-1F7D379040D1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                            0x97b25000 - 0x97b6aff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                            0x97b6b000 - 0x97bb9ffb  com.apple.SystemConfiguration (1.12 - 1.12) <F3C87D17-D5F3-39D3-B6F1-1DF3DBECCBDE> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                            0x97bba000 - 0x97bbcfff  com.apple.securityhi (4.0 - 55002) <62E3AE75-61CB-341E-B2A0-CFC985A2BF7F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                            0x97bbd000 - 0x97f9fff7  com.apple.HIToolbox (2.0 - 624) <04C20B6A-FE3D-396E-BCAF-AC4DBAB3747E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                            0x97fa0000 - 0x97ff0ff7  com.apple.CoreMediaIO (301.0 - 4147) <F13FA9D4-BD1D-3297-BDD5-5858B231D738> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                            0x97ff1000 - 0x97ff4ffb  com.apple.TCC (1.0 - 1) <C1B2A1EB-9EA2-3340-8611-F788C87A951F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                            0x97ff5000 - 0x98d2dfef  com.apple.QuickTimeComponents.component (7.7.1 - 2599) <1AE9A55E-3486-3A90-A95D-3F5E1C6AF457> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
                            0x98d2e000 - 0x98d52fff  libJPEG.dylib (843) <04383F74-067F-3E98-882F-21F5B9578984> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                            0x98d53000 - 0x98dacfff  com.apple.QuickLookFramework (4.0 - 555.0) <291276B2-7A40-3D68-98ED-7FBD1F601D84> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                            0x98dad000 - 0x98db7fff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
                            0x98db8000 - 0x98dbefff  libGFXShared.dylib (8.5) <D2D214E8-A243-3FFD-BA70-D695FF5BD040> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                            0x98dbf000 - 0x99177ffa  libLAPACK.dylib (1073.3) <0F813868-D84F-365D-8A7B-67FDA169F19C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                            0x99178000 - 0x9917bfff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                            0x9917c000 - 0x99182fff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                            0x99183000 - 0x9918affe  com.apple.agl (3.2.1 - AGL-3.2.1) <8E0411D3-19F7-30E1-92A2-337F7F0EBCDA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                            0x9918b000 - 0x9918cfff  libdnsinfo.dylib (453.16) <6441AEC9-3916-3BF6-BE54-9C25E2BE61E1> /usr/lib/system/libdnsinfo.dylib
                            0x9918d000 - 0x991aaff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
                            0x991ab000 - 0x991b8ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                            0x991b9000 - 0x992b7ff7  libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                            0x992b8000 - 0x9931cfff  com.apple.datadetectorscore (4.0 - 269.1) <4D155F09-1A60-325A-BCAC-1B858C2C051B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                            0x9931d000 - 0x994a6ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                            0x994fe000 - 0x9950bfff  libGL.dylib (8.5) <930067EA-F131-336E-BE31-49DD7F6DFB81> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                            0x9950c000 - 0x995e2fff  com.apple.DiscRecording (7.0 - 7000.2.4) <C14E99B9-DEFA-3812-89E5-464653B729F4> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                            0x995e3000 - 0x9961efe7  libGLImage.dylib (8.5) <E5F2D8DE-3053-361A-982B-9BB2AE73E324> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                            0x9961f000 - 0x99924fff  com.apple.CoreServices.CarbonCore (1037 - 1037) <92494ADA-2ED1-3141-81B9-23F2C27E779C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                            0x99925000 - 0x9997ffff  com.apple.Symbolication (1.3 - 93) <684ECF0D-D416-3DF8-8B5B-3902953853A8> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                            0x99980000 - 0x99a8dffb  com.apple.ImageIO.framework (3.2.0 - 843) <4BFEFB05-3EE3-36A7-891D-CE03D1DF8125> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                            0x99a8e000 - 0x99cbefff  com.apple.QuartzComposer (5.1 - 281) <F52C0922-7E0C-36B1-A055-96E0FDB00F14> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                            0x99cbf000 - 0x9a0bbfe3  com.apple.VideoToolbox (1.0 - 926.37) <268DD75A-153C-39A0-98B1-439374DA1144> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                            0x9a0bc000 - 0x9a100fff  libGLU.dylib (8.5) <E4F932FD-A644-354D-8D4E-F337C93AAFC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                            0x9a101000 - 0x9a1f5fff  com.apple.QuickLookUIFramework (4.0 - 555.0) <457CB3C3-5049-3F98-9C6E-EFEBC09A7653> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                            0x9a1f6000 - 0x9a1ffff9  com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                            0x9a200000 - 0x9a207ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
                            0x9a208000 - 0x9a20bff3  com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                            0x9a20c000 - 0x9a214fff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
                            0x9a215000 - 0x9a22cff4  com.apple.CoreMediaAuthoring (2.1 - 914) <37C0A2C7-73B3-39BC-8DE1-4A6B75F115FC> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                            0x9a22d000 - 0x9a22efff  libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
                            0x9a22f000 - 0x9a33aff7  libJP2.dylib (843) <D8FE1E1C-D4DC-3465-95C4-AEADD6C2611C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                            0x9a33b000 - 0x9a5b7ff7  com.apple.QuickTime (7.7.1 - 2599) <C1EAA16D-C51E-3A85-B114-6C7DDCEC864C> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                            0x9a5b8000 - 0x9a5b8fff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
                            0x9a5b9000 - 0x9a632ff0  com.apple.CorePDF (2.0 - 2) <BEB48187-261E-3263-8CD9-6CD3057B5108> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                            0x9a633000 - 0x9a63dfff  libCSync.A.dylib (322) <CD2707A0-48EB-30C5-8431-460663D44A91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                            0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework (1.6.0.20 - 1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                            0xba300000 - 0xba301fff  libCyrillicConverter.dylib (61) <76630B89-A9CE-376B-B836-B55D8543717B> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                            0xba500000 - 0xba501ffd  libGreekConverter.dylib (61) <8420F227-2783-36D9-997E-39110328F77C> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
                            0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                            0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                            0xbad00000 - 0xbad01fff  libLatin2Converter.dylib (61) <5893A6EA-B555-3635-8D03-66FA478CD304> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
                            0xbaf00000 - 0xbaf01fff  libLatin5Converter.dylib (61) <E9E8057A-2240-3721-A8A5-7258096B00E8> /System/Library/CoreServices/Encodings/libLatin5Converter.dylib
                            0xbb100000 - 0xbb103ffd  libLatinSuppConverter.dylib (61) <A1318F1F-8E3E-3A9B-92A1-4749F4CBCE1B> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
                            0xbb300000 - 0xbb301fff  libSymbolConverter.dylib (61) <D5BA0C69-5E55-3A07-97DF-DDFAEFD0D774> /System/Library/CoreServices/Encodings/libSymbolConverter.dylib
                            0xbb500000 - 0xbb500fff  libThaiConverter.dylib (61) <3EE5ABD4-2C9C-3E95-A990-EBE4C715AFF1> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
                            External Modification Summary:
                              Calls made by other processes targeting this process:
                                task_for_pid: 21
                                thread_create: 0
                                thread_set_state: 0
                              Calls made by this process:
                                task_for_pid: 0
                                thread_create: 0
                                thread_set_state: 0
                              Calls made by all processes on this machine:
                                task_for_pid: 929
                                thread_create: 0
                                thread_set_state: 0
                            VM Region Summary:
                            ReadOnly portion of Libraries: Total=363.8M resident=224.0M(62%) swapped_out_or_unallocated=139.8M(38%)
                            Writable regions: Total=1.1G written=954.2M(82%) resident=1.0G(86%) swapped_out=0K(0%) unallocated=159.3M(14%)
                            REGION TYPE                      VIRTUAL
                            ATS (font support)                 33.1M
                            CG backing stores                  6800K
                            CG image                           2092K
                            CG raster data                      116K
                            CG shared images                    192K
                            CoreAnimation                         4K
                            CoreServices                       3876K
                            IOKit                               812K
                            MALLOC                            120.4M
                            MALLOC guard page                    48K
                            Memory tag=240                     2588K
                            Memory tag=242                       12K
                            Memory tag=249                      192K
                            Memory tag=35                      1412K
                            OpenCL                               52K
                            OpenGL GLSL                         896K
                            Stack                              67.6M
                            VM_ALLOCATE                       990.8M
                            __DATA                             37.1M
                            __DATA/__OBJC                       364K
                            __IMAGE                             528K
                            __IMPORT                            340K
                            __LINKEDIT                         59.7M
                            __OBJC                             3500K
                            __OBJC/__DATA                       100K
                            __PAGEZERO                            4K
                            __TEXT                            304.1M
                            __UNICODE                           544K
                            mapped file                        71.6M
                            shared memory                      46.6M
                            TOTAL                               1.7G
                            Model: MacBookPro6,2, BootROM MBP61.0057.B0F, 2 processors, Intel Core i7, 2.66 GHz, 8 GB, SMC 1.58f16
                            Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
                            Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
                            Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                            Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                            AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.81.21)
                            Bluetooth: Version 4.0.9f8 10405, 2 service, 18 devices, 1 incoming serial ports
                            Network Service: AirPort, AirPort, en1
                            Serial ATA Device: ST9500420ASG, 500.11 GB
                            Serial ATA Device: MATSHITADVD-R   UJ-898
                            USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
                            USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
                            USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8218, 0xfa113000 / 7
                            USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa130000 / 4
                            USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0xfa120000 / 3
                            USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
                            USB Device: USB 2.0 Hub, 0x050d  (Belkin Corporation), 0x0016, 0xfd130000 / 5
                            USB Device: XD-0405-U, 0x056a  (WACOM Co., Ltd.), 0x0041, 0xfd132000 / 7
                            USB Device: Mass Storage Device, 0x058f  (Alcor Micro, Corp.), 0x6362, 0xfd133000 / 6
                            USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
                            USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0xfd110000 / 3
                            FireWire Device: Hard Drive FW/USB, LaCie, 400mbit_speed
                            FireWire Device: d2 quadra (button), LaCie, 800mbit_speed
                            FireWire Device: d2 Quadra v3, LaCie, 800mbit_speed
                            • 11. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                              Level 7
                              That's being caused by a plugin or driver, but it's already unloaded when it crashes.  The DLL was loaded very close to your Canon ScanGear driver, and is probably part of that driver.
                              Try disabling all your third party plugins and see if the error goes away.
                              Then try removing the Canon ScanGear drivers and see if the problem goes away.
                              • 12. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                Ken Nielsen Level 1
                                Thanks Chris, I think you nailed it. I will now begin the process. I had a Canon 'all-in-one' printer/scanner and I'm thinking that's the one.
                                Good Detective Work Chris!
                                Ken
                                • 13. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                  Ken Nielsen Level 1
                                  Canon ScanGear driver removal did not affect the problem but EazelAcquire plug-in removal fixed the problem.
                                  EazelAcquire plugin - I no longer have the problem without it.
                                  Ken
                                  • 14. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                    Level 5
                                    Ken Nielsen wrote:
                                    …but EazelAcquire plug-in removal fixed the problem.
                                    EazelAcquire plugin - I no longer have the problem without it…
                                    In a futile attempt to learn what that plug-in is or does, I googled "eazelacquire" and got pages and pages of hits describing Photoshop issues.
                                    Apparently its only purpose is to cause grief to Photoshop users.  That's all I learned.
                                    • 15. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                      Ken Nielsen Level 1
                                      It's an 'aquire' plug-in for the iPad app called 'Eazel.' The thing I wonder is that I've been having this problem long before the first iPad was ever introduced, let alone the thing called Eazel. Chris Cox found the problem area and that is enough. My Photoshop quietly quits now with no extra fanfare. That is all I wanted.
                                      • 16. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                        Level 5
                                        Thank you, Ken.  Never having used an iPad, it's natural that I hadn't heard of it.
                                        • 17. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                          Level 7
                                          That's weird, the Eazel import plugin does nothing until invoked from the eazel iPad application.  It's just a simple, minimal file import plugin.
                                          • 18. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                            Noel Carboni Level 8
                                            Just to be clear, you've removed both the scanner driver and the Eazel plug-in?
                                            -Noel
                                            • 19. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                              Ken Nielsen Level 1
                                              It's really unexplainable then. All I know is I removed plug-in's, first all, and the problem went away. After removing one at a time with no change in the problem, removing the Eazel plug-in resulted in Photoshop quitting properly and it still is working fine today.
                                              • 20. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                Ken Nielsen Level 1
                                                -Noel
                                                Yes, I did remove the scanner driver, but that made no change in the behavior of photoshop quiting with an error message. Removing the Eazel plug-in definitely changed the quitting behavior of Photoshop, then, putting the Eazel plug-in back into the Plug-ins folder caused Photoshop to quit with an error message. Taking the Eazel plug-in back out of the plug-ins folder caused the problem to go away again.
                                                • 21. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                  That seems pretty definite.  Good job sleuthing and making very sure you found the culprit.
                                                  -Noel
                                                  • 22. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                    Ken Nielsen Level 1
                                                    If I were a History Detective, I would have now put the since trashed scanner driver back into place, just to be sure it had no influence on the outcome. I can tell you the problem is fixed and Photoshop works like a charm. Very nice to have this resolved after all this time, but it still makes no sense that deleting something that is fairly new would affect a problem that has been going on for at least five years. Absolutely does not make sense.
                                                    • 23. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                      I wonder whether some preference or cache got rewritten as a result of the investigation somehow, and whether it might work even if you put everything back.
                                                      Keep in mind that disabling things that are part of the Photoshop installation will probably break the automatic updating process next time there's a Photoshop update released.  You might want to leave yourself a note with instructions how to undo what you've done.
                                                      -Noel
                                                      • 24. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                        Ken Nielsen Level 1
                                                        We may never know in this particular instance. I went through like a garbage truck, not knowing fully what I was doing, deleting everything that said Canon on it, mostly print drivers because my old Canon printer was a all-in-one with a scanner built in. Then I called my service shop and they told me that most likely I was supposed to delete Photoshop plug-ins and not all plug-ins on the computer. Good thing they stopped me and gave me focus. Other than the Canon drivers, the only thing I touched was the Photoshop Plug-ins folder. I use Cocktail to maintain caches so that works weekly in the same way. I really didn't get into too much other than what I mentioned. The only thing I could put back would be the Eazel plug-in and I'm not about to do that.
                                                        • 25. Re: Upon 'Quit' Photoshop message: "Photoshop Quit Unexpectedly"
                                                          madduck85 Level 1
                                                          Freaking press OPT+CMD+SHIFT while starting Photoshop! It will delete the preference files!
