Every time I put a quiz in a presentation when I publish it, the quiz does not appear in the Flash video.
Does anyone have an idea what is going on?
Can I confirm that it's Presenter 8 in PowerPoint that you're talking about?
Sorry, I should have noted I am using Presenter 7, Office 2007, and Windows 7.
What version of Presenter 7?
G'day Nealdog,
could you tell me a bit more about the process you're using as I can't understand why it's not working. If you've got your P'Point presentation and you click on the Adobe Presenter tab to create and manage your quiz, I can see no reason why it wouldn't publish properly EXCEPT, if after you create your quiz you try to move the slides around in the presentation - that may break the linking between the questions in the quiz causing it to not work.
Just need to confirm, when you publish you see no questiions at all - that's correct?
Cheers
Hi
Can you please confirm one thing.
Are you copying slides from one presentation to another are you just inserting the quiz slides via Presenter Quiz Manage?
In case you are copying the quiz slides then the quiz slides will not appear in the published output.
Mahesh Nayak
