4 Replies Latest reply on Aug 31, 2012 2:27 PM by fewremain
    Desktop AIR Application installs fine on Mac... crashes on PC
    fewremain
      Hey guys,
      I ran into an issue that has be pulling my hair out. I have a very simple AIR application that was built with Flash CS6 on a Mac. The published app installs and runs perfectly on my Mac. Installation goes just fine on a PC, but the app will not launch! The window starts to come up and immediately crashes. I just finished making a desktop app in the last version of AIR and it ran perfect on PC.
      Has anyone else experienced this issue? So much fun using a Mac when most clients use PC lol!
        • 1. Re: Desktop AIR Application installs fine on Mac... crashes on PC
          adobe_paul Adobe Employee
          It's hard to say what the problem is without seeing the code. The best advice I can offer is to look for things that might be platform specific, such as hard-coded file paths and Mac-specific apis (like the dock icon/menu).
          Paul Robertson
          Adobe Developer Relations
          • 2. Re: Desktop AIR Application installs fine on Mac... crashes on PC
            fewremain Level 1
            It's actually quite a tiny app. Tiny enough that I'm just coding in Flash CS6 in the first frame noob style LOL. I published another AIR app like this recently and it worked just fine on PC.
            Here is literally all of the code that runs the app. I am using the File class to access the desktop directory for some files, but my understanding is that it should access the desktop the same on PC and Mac.
            Thanks for the time and help... I could have a friend publish on a PC, but it would be much more convenient if I could get it to work correctly .
            import flash.display.MovieClip;
            import flash.display.SimpleButton;
            import flash.events.MouseEvent;
            import flash.filesystem.File;
            import flash.display.Loader;
            import flash.ui.MouseCursor;
            // START VARIABLE DECLARATION
            var XMLDirectory:File = File.desktopDirectory;
            XMLDirectory = XMLDirectory.resolvePath("missing_person/results.xml");
            var myXML:XML;
            var imageDirectory:File = File.desktopDirectory;
            imageDirectory = imageDirectory.resolvePath("missing_person/images/");
            var screen_saver:MovieClip;
            var part1_mc:MovieClip;
            var part2_mc:MovieClip;
            var rightBtn:SimpleButton = part2_mc.right_btn;
            var leftBtn:SimpleButton = part2_mc.left_btn;
            var heightOpt:MovieClip = part1_mc.height_options_mc;
            var heightBtn:SimpleButton = part1_mc.height_btn;
            var genderOpt:MovieClip = part1_mc.gender_options_mc;
            var genderBtn:SimpleButton = part1_mc.gender_btn;
            var ageOpt:MovieClip = part1_mc.age_options_mc;
            var ageBtn:SimpleButton = part1_mc.age_btn;
            var searchBtn:SimpleButton = part1_mc.search_btn;
            var resetBtn:SimpleButton = header_mc.restart_btn;
            var searchingDB:MovieClip = part1_mc.searching_mc;
            var startArray:Array = [[],[]];
            var ageStr:String = "";
            var heightStr:String = "";
            var genderStr:String = "";
            // KEEPS OVER STATES FOR BUTTONS
            var heightState = heightBtn.upState;
            var genderState = genderBtn.upState;
            var ageState = ageBtn.upState;
            var searchState = searchBtn.upState;
            // LOAD AND PARSE XML
            var myLoader:URLLoader = new URLLoader();
            myLoader.load(new URLRequest(XMLDirectory.url));
            myLoader.addEventListener(Event.COMPLETE, processXML);
            function processXML(e:Event):void
                myXML = new XML(e.target.data);
                for (var i:int = 0; i < myXML.result.length(); i++)
                    startArray[i] = [(imageDirectory.url + "/" + myXML.result[i].image), myXML.result[i].name, myXML.result[i].age, myXML.result[i].gender, myXML.result[i].height, myXML.result[i].description, myXML.result[i].features];
                    trace(startArray[i][0]);
            //CODE FOR BUTTON RESET
            resetBtn.addEventListener(MouseEvent.MOUSE_DOWN, resetAll);
            function resetAll(event:MouseEvent):void
                enableButtons();
                heightOpt.visible = false;
                genderOpt.visible = false;
                ageOpt.visible = false;
                searchingDB.visible = false;
                part1_mc.height_txt.text = "";
                part1_mc.gender_txt.text = "";
                part1_mc.age_txt.text = "";
                part2_mc.visible = false;
                part2_mc.removeChild(resultContainer);
            //BEGIN INITIALIZATION ;
            function init():void
                part1_mc.visible = false;
                screen_saver.visible = true;
            init();
            heightBtn.addEventListener(MouseEvent.MOUSE_DOWN, showHeights);
            genderBtn.addEventListener(MouseEvent.MOUSE_DOWN, showGenders);
            ageBtn.addEventListener(MouseEvent.MOUSE_DOWN, showAges);
            function showHeights(event:MouseEvent):void
                heightOpt.visible = true;
                disableButtons();
                //ADD EVENT LISTENERS FOR HEIGHT OPTIONS
                heightOpt.opt_1.addEventListener(MouseEvent.MOUSE_DOWN, setHeight1);
                heightOpt.opt_2.addEventListener(MouseEvent.MOUSE_DOWN, setHeight2);
                heightOpt.opt_3.addEventListener(MouseEvent.MOUSE_DOWN, setHeight3);
                heightOpt.opt_4.addEventListener(MouseEvent.MOUSE_DOWN, setHeight4);
                heightOpt.opt_5.addEventListener(MouseEvent.MOUSE_DOWN, setHeight5);
                heightOpt.opt_6.addEventListener(MouseEvent.MOUSE_DOWN, setHeight6);
            function showGenders(event:MouseEvent):void
                genderOpt.visible = true;
                disableButtons();
                genderOpt.opt_1.addEventListener(MouseEvent.MOUSE_DOWN, setGender1);
                genderOpt.opt_2.addEventListener(MouseEvent.MOUSE_DOWN, setGender2);
                genderOpt.opt_3.addEventListener(MouseEvent.MOUSE_DOWN, setGender3);
            function showAges(event:MouseEvent):void
                ageOpt.visible = true;
                disableButtons();
                ageOpt.opt_1.addEventListener(MouseEvent.MOUSE_DOWN, setAge1);
                ageOpt.opt_2.addEventListener(MouseEvent.MOUSE_DOWN, setAge2);
                ageOpt.opt_3.addEventListener(MouseEvent.MOUSE_DOWN, setAge3);
                ageOpt.opt_4.addEventListener(MouseEvent.MOUSE_DOWN, setAge4);
                ageOpt.opt_5.addEventListener(MouseEvent.MOUSE_DOWN, setAge5);
                ageOpt.opt_6.addEventListener(MouseEvent.MOUSE_DOWN, setAge6);
            function disableButtons():void
                heightBtn.upState = heightBtn.downState;
                heightBtn.enabled = false;
                genderBtn.upState = genderBtn.downState;
                genderBtn.enabled = false;
                ageBtn.upState = ageBtn.downState;
                ageBtn.enabled = false;
                searchBtn.upState = searchBtn.downState;
                searchBtn.enabled = false;
            function enableButtons():void
                heightBtn.upState = heightState;
                heightBtn.overState = heightState;
                heightBtn.hitTestState = heightState;
                heightBtn.enabled = true;
                genderBtn.upState = genderState;
                genderBtn.overState = genderState;
                genderBtn.hitTestState = genderState;
                genderBtn.enabled = true;
                ageBtn.upState = ageState;
                ageBtn.overState = ageState;
                ageBtn.hitTestState = ageState;
                ageBtn.enabled = true;
                searchBtn.upState = searchState;
                searchBtn.overState = searchState;
                searchBtn.hitTestState = searchState;
                searchBtn.enabled = true;
            //ASSORTED FUNCTIONS TO SET THE TEXT FOR THE HEIGHT OPTION
            function setHeight1(event:MouseEvent)
                part1_mc.height_txt.text = "135-145cm";
                enableButtons();
            function setHeight2(event:MouseEvent)
                part1_mc.height_txt.text = "145-155cm";
                enableButtons();
            function setHeight3(event:MouseEvent)
                part1_mc.height_txt.text = "155-165cm";
                enableButtons();
            function setHeight4(event:MouseEvent)
                part1_mc.height_txt.text = "165-175cm";
                enableButtons();
            function setHeight5(event:MouseEvent)
                part1_mc.height_txt.text = "175-185cm";
                enableButtons();
            function setHeight6(event:MouseEvent)
                part1_mc.height_txt.text = "Unknown";
                enableButtons();
            function setGender1(event:MouseEvent)
                part1_mc.gender_txt.text = "Male";
                enableButtons();
            function setGender2(event:MouseEvent)
                part1_mc.gender_txt.text = "Female";
                enableButtons();
            function setGender3(event:MouseEvent)
                part1_mc.gender_txt.text = "Unknown";
                enableButtons();
            function setAge1(event:MouseEvent)
                part1_mc.age_txt.text = "20-30 years old";
                enableButtons();
            function setAge2(event:MouseEvent)
                part1_mc.age_txt.text = "31-40 years old";
                enableButtons();
            function setAge3(event:MouseEvent)
                part1_mc.age_txt.text = "41-50 years old";
                enableButtons();
            function setAge4(event:MouseEvent)
                part1_mc.age_txt.text = "51-60 years old";
                enableButtons();
            function setAge5(event:MouseEvent)
                part1_mc.age_txt.text = "71-80 years old";
                enableButtons();
            function setAge6(event:MouseEvent)
                part1_mc.age_txt.text = "Unknown";
                enableButtons();
            screen_saver.addEventListener(MouseEvent.CLICK, hideScreenSaver);
            function hideScreenSaver(event:MouseEvent):void
                screen_saver.visible = false;
                part1_mc.visible = true;
            //START EXECUTING SEARCH
            searchBtn.addEventListener(MouseEvent.MOUSE_DOWN, startSearch);
            var resultContainer:MovieClip;
            var resultCount:int = 0;
            var position:int = 1;
            function startSearch(event:MouseEvent):void
                resultContainer = new MovieClip;
                part2_mc.addChild(resultContainer);
                disableButtons();
                ageStr = part1_mc.age_txt.text;
                heightStr = part1_mc.height_txt.text;
                genderStr = part1_mc.gender_txt.text;
                searchingDB.visible = true;
                part2_mc.visible = true;
                rightBtn.visible = false;
                leftBtn.visible = false;
                createResults();
            rightBtn.addEventListener(MouseEvent.MOUSE_UP, moveRight);
            leftBtn.addEventListener(MouseEvent.MOUSE_UP, moveLeft);
            function moveRight(event:MouseEvent):void
                if (position < Math.ceil(resultCount/3))
                    resultContainer.x = resultContainer.x - 1680;
                    position++;
                else
                checkRight();
            function moveLeft(event:MouseEvent):void
                if (position > 1)
                    resultContainer.x = resultContainer.x + 1680;
                    position--;
                else
                checkLeft();
            function checkRight():void
                else
                    if (position > 1)
                        leftBtn.visible = true;
            function checkLeft():void
                if (position > 1)
                else
                        rightBtn.visible = true;
            function createResults():void
                var resultY = 250;
                var startX = 175;
                resultCount = 0;
                trace(ageStr.substr(0,2), ageStr.substr(3,2));
                trace(startArray[i][2]);
                for (var i:int=0; i < startArray.length; i++)
                    if ((parseInt(startArray[i][2]) >= parseInt(ageStr.substr(0,2)) && parseInt(startArray[i][2]) <= parseInt(ageStr.substr(3,2))) || ageStr == "" || ageStr == "Unknown")
                        if ((startArray[i][4] >= heightStr.substr(0,3) && startArray[i][4] <= heightStr.substr(4,3)) || heightStr == "" || heightStr == "Unknown")
                            if (genderStr == "" || genderStr == startArray[i][3] || genderStr == "Unknown")
                                var resultItem = new result_item();
                                resultItem.name = "r_" + i;
                                resultItem.name_txt.text = startArray[i][1];
                                resultItem.gender_txt.text = "Gender: " + startArray[i][3];
                                resultItem.height_txt.text = "Height: " + startArray[i][4] + "cm";
                                resultItem.age_txt.text = "Age: " + startArray[i][2];
                                resultItem.description_txt.text = "                                " + startArray[i][5];
                                resultItem.features_txt.y = (resultItem.description_txt.y + resultItem.description_txt.height) + 20;
                                resultItem.features_txt.text = "Distinguishing Features: " + startArray[i][6];
                                var l=new Loader();
                                l.x = l.y = 0;
                                l.load(new URLRequest(startArray[i][0]));
                                resultItem.image_holder.addChild(l);
                                resultItem.y = resultY;
                                resultItem.x = startX;
                                if ((resultCount+1)%3 == 0)
                                    startX = startX + 780;
                                else
                                    startX = startX + 450;
                                resultContainer.addChild(resultItem);
                                resultCount++;
                                if (resultCount > 3)
            • 3. Re: Desktop AIR Application installs fine on Mac... crashes on PC
              Several months ago I worked on an app where I ran into a similar issue. A coworker (who uses Windows) wrote code that loaded an XML file using a URLLoader. Presumably it worked on his machine, but on my Mac it didn't work. I was never able to figure out exactly what the issue was -- it's probably a platform difference in the File.url property.
              In any case, for working with AIR it's best to use the FileStream class to read the contents of a file, rather than using URLLoader. The simplest way to do that is to replace this code:
              Substitute it with this instead:
              var fileStream:FileStream = new FileStream();
              fileStream.open(XMLDirectory, FileMode.READ);
              var myXML:XML = XML(fileStream.readUTFBytes(fileStream.bytesAvailable));
              fileStream.close();
              (Adapted from "Example: Reading an XML file into an XML object" in the documentation -- you'll find more info there.)
              HTH,
              Paul
              Adobe Developer Relations/Documentation
              • 4. Re: Desktop AIR Application installs fine on Mac... crashes on PC
                fewremain Level 1
                Awesome! Thank you so much! I do believe with the previous project I was not parsing any XML so this is probably it. I'll let you know if this solves my problem, but I'm fairly certain you nailed it.
                Thanks again!
