1. Re: My numbers and punctuation glitching on Photoshop. Help?
c.pfaffenbichler Aug 28, 2012 12:26 AM (in response to Cheddarman1)http://forums.adobe.com/thread/419981?tstart=0
Please explain in more detail.
Boilerplate-text:
Are Photoshop and OS fully updated and have you performed the usual trouble-shooting routines (trashing prefs by keeping command-alt-shift/ctrl-alt-shift pressed while starting Photoshop after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed, 3rd party plug-ins deactivation, system maintenance, cleaning caches, font validation, etc.)?
2. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 1:46 AM (in response to c.pfaffenbichler)Right. If I was trying to write "The year 1995", when typing the first number, it would automatically go to the front of the text and look like "1995 The year". The same rules apply for any punctuation I use at the end of sentences.
Also, if I was trying to highlight all of the text, what would be highlighted would either be "1995", "The year" or the space inbetween "1995" and "The". It isn't possible to highlight every word in the text. Another thing is that the blinking line where the text should type is always at the beginning of the text unless I hold the right arrow key.
Please ask any questions.
3. Re: My numbers and punctuation glitching on Photoshop. Help?
c.pfaffenbichler Aug 28, 2012 1:54 AM (in response to Cheddarman1)That happens when using the Type Tool to create Point Type and Paragraph Type both?
Have you trashed the prefs yet?
You could also try checking out:
http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.html
4. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 3:32 AM (in response to c.pfaffenbichler)"That happens when using the Type Tool to create Point Type and Paragraph Type both?"
Yes, both.
"Have you trashed the prefs yet?"
I just did so but it came to no avail.
I'll try the more time cosuming things on the list later when I have more time but nothing worked yet.
5. Re: My numbers and punctuation glitching on Photoshop. Help?
c.pfaffenbichler Aug 28, 2012 3:51 AM (in response to Cheddarman1)Sounds strange indeed.
Are other programs affected?
6. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 4:09 AM (in response to c.pfaffenbichler)Every other program seems fine.
7. Re: My numbers and punctuation glitching on Photoshop. Help?
c.pfaffenbichler Aug 28, 2012 4:12 AM (in response to Cheddarman1)It seems unlikely, but are any Scripts linked to events in File > Scripts > Script Events Manager?
8. Re: My numbers and punctuation glitching on Photoshop. Help?
PECourtejoie Aug 28, 2012 4:49 AM (in response to Cheddarman1)Hi! did you reset the type tool (right-click the tool on the option bar)
Does it happen with all fonts, or just one?
9. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 11:02 PM (in response to c.pfaffenbichler)No scripts are linked to events.
10. Re: My numbers and punctuation glitching on Photoshop. Help?
Jeff Arola Aug 28, 2012 11:13 PM (in response to Cheddarman1)in photoshop are your type options under Preferences>Type set to Middle Eastern or East Asian?
11. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 11:16 PM (in response to PECourtejoie)"did you reset the type tool (right-click the tool on the option bar)"
No, but I just did and it didn't work.
"Does it happen with all fonts, or just one?"
All fonts.
Something I just noticed was when the text starts centred on the right, the blinking line that should be telling me where my text will be coming up moves backwards when I press the spacebar; then when backspacing, the line goes fowards.
Sorry if that last sentence didn't make sense...it's early.
12. Re: My numbers and punctuation glitching on Photoshop. Help?
Cheddarman1 Aug 28, 2012 11:24 PM (in response to Jeff Arola)1 person found this helpfulYou got it! It was set to Middle Eastern and changing it to East Asian fixed the problem. Thank you.
13. Re: My numbers and punctuation glitching on Photoshop. Help?
Jeff Arola Aug 28, 2012 11:36 PM (in response to Cheddarman1)It's strange that resetting the photoshop cs6 preferences didn't cure that if your using an version of photoshop not localised for a middle eastern region.
14. Re: My numbers and punctuation glitching on Photoshop. Help?
Tom Lippitsch May 15, 2013 3:30 AM (in response to Cheddarman1)I still have the problem that all punctuation is appearing on the left side of my text. What makes most of my documents useless.
Recreating them from scratch is NOT an option due to high complexity.
I am Cloud member and Photoshop is up to date.
What is the solution to fix that problem now?
- I tried switching between Middle Eastern and East Asian text engines.
- I tried to delete styles, resetting paragraphs, etc
- I deleted Photoshop preferences
Nothing helped yet.
Punctuation always appears on the left side instead after text.
What's also strange is that after deleting the preferences, creating a new document and writing text - the text is by default aligned right instead left.
Does that mean my documents, which I have built up over years/months, are irreversibly skrewed?
15. Re: My numbers and punctuation glitching on Photoshop. Help?
torenchuk Jun 16, 2013 1:13 PM (in response to Cheddarman1)2 people found this helpfulHighlight your text and select 'Paragraph'.
Select the icon in the very top right corner so a menu pops open.
Select:
Adobe Single-line Composer
and
Right-to-Left Paragraph Direction
That should do it!
16. Re: My numbers and punctuation glitching on Photoshop. Help?
Jump Start Agency Group Jul 9, 2013 6:35 PM (in response to torenchuk)My photoshop, also cloud just started this today and NOTHING seems to work. I just tried this trick...still doing it.
17. Re: My numbers and punctuation glitching on Photoshop. Help?
lilithtwin Jul 29, 2013 3:19 AM (in response to torenchuk)Hi guys!
I use CC 14.0 and I can't seem to figure out the type tool. it types right to left and i tried all the solutions above. In the paragraph panel there's no left to right or right to left option and all the other options that may work out for me are greyed out and i can't select them.
What should I do next?
18. Re: My numbers and punctuation glitching on Photoshop. Help?
station_two Jul 29, 2013 3:34 AM (in response to lilithtwin)1 person found this helpfulYou have your Text Engine in Photoshop set to "Middle Eastern".
Go back to Photoshop Preferences and change the Type Engine Option to "East Asian" (don't ask me why Adobe has chosen that terminology ).
19. Re: My numbers and punctuation glitching on Photoshop. Help?
lilithtwin Jul 29, 2013 4:17 AM (in response to station_two)Thanks a lot station_two!! This fixed my issue but now I have a problem with symbols like " or } as they seem to move to the begining of the line randomly.
20. Re: My numbers and punctuation glitching on Photoshop. Help?
Xenil Nov 6, 2013 1:52 PM (in response to station_two)4 people found this helpfulHey there.
I've been browsing and looking for an answer everywhere in order to fix my problems.
I think I've found a solution, but just to clarify, this was my problem:
If I was to type the this:
Cat, dog and mouse were smoking it all up.
The sentence would come out, like this:
.,Cat dog and mouse were smoking it all up
Or something alike, anyway.
But I've fixed it with a click of a button, or two.
This is what you do:
NOTE: THIS DOES INCLUDE HAVING MIDDLE EASTERN SET, BUT ISN'T THE FIX ITSELF!
1. Go to 'Type' through the menu, or (preferences on mac) and make sure type set is set to Middle Eastern.
There, wasn't so hard, was it? =]
2. Now, do this:
3.
4.
5. This may set back and forth if you have a certain text layer selected, so make sure you're doing this independently of any layers.
Hope this helps.
21. Re: My numbers and punctuation glitching on Photoshop. Help?
robbie.digital Jan 29, 2014 2:06 PM (in response to Xenil)I don't see that option in my photoshop CS6 (Version 13 x64), not Cloud. But, I am experiencing the same exact thing you mention. What are those buttons labeled. Any idea where I can find it in the non-Creative Cloud version of the software?
22. Re: My numbers and punctuation glitching on Photoshop. Help?
Xengulai Feb 6, 2014 1:31 PM (in response to robbie.digital)1 person found this helpfulIn order to get the option for "left to right" and "right to left" you have to click Type -> Language Options -> Middle Eastern Features and it will add a row of options to the Paragraph panel. This solved it for me.
23. Re: My numbers and punctuation glitching on Photoshop. Help?
oö Apr 1, 2014 2:11 PM (in response to Cheddarman1)I've got the solution:
- Type > Panels > Paragraph Styles Panel.
- Create new (Create new paragraph style), the button left to the delete option.- Double click on the new "Paragraph Style +1"
- Make the changes you want and save- Use the new paragraph style ("Basic Paragraph" is the one making problem)
24. Re: My numbers and punctuation glitching on Photoshop. Help?
Carl4 May 5, 2014 11:24 PM (in response to Cheddarman1)This is the only solution that would fix it for me:
25. Re: Re: My numbers and punctuation glitching on Photoshop. Help?
c0ward May 13, 2014 11:19 PM (in response to Carl4)Carl4's link did the trick. Nothing else in this thread worked. Thanks Carl!
26. Re: My numbers and punctuation glitching on Photoshop. Help?
hl-jaxxon Jul 2, 2014 10:12 AM (in response to Carl4)Looks like this option is gone in cc 2014
27. Re: My numbers and punctuation glitching on Photoshop. Help?
ceriseghost Jul 12, 2014 8:04 PM (in response to hl-jaxxon)I had this problem too and I just selected
Type > Language Options > Left-to-right Character Direction.
Hope this helps.
28. Re: My numbers and punctuation glitching on Photoshop. Help?
nikitaamarie Jul 19, 2014 10:35 AM (in response to Cheddarman1)This worked for me. This is what I did..
Type>Language Options> Set to Middle Eastern Features> Click Left-to-right Character Direction.
And in order to enable the "Left-to-right character direction" tab, you actually HAVE to set your language option to Middle Eastern.
Good Luck. This has bothered me for months! smh.
30. Re: My numbers and punctuation glitching on Photoshop. Help?
713slidewayz Aug 9, 2014 1:15 AM (in response to Carl4)I find no option to change this to Middle Eastern...please help...really annoyed
31. Re: My numbers and punctuation glitching on Photoshop. Help?
Jeff Arola Aug 9, 2014 3:51 AM (in response to 713slidewayz) -
32. Re: My numbers and punctuation glitching on Photoshop. Help?
rizzojn Sep 21, 2014 2:37 PM (in response to Carl4)Carl's option worked for me as well. Thanks for a glitchy program Photoshop . I hope they correct this with a patch so people won't have to use this odd workaround! Good luck everyone.
33. Re: My numbers and punctuation glitching on Photoshop. Help?
sdesign47 Mar 20, 2015 2:37 PM (in response to Cheddarman1) -
34. Re: My numbers and punctuation glitching on Photoshop. Help?
junicorn Jul 6, 2015 5:32 PM (in response to Cheddarman1)1 person found this helpfulIf the language trick doesn't work, go to your PARAGRAPH>RESET PARAGRAPH
It did the trick for me!
35. Re: My numbers and punctuation glitching on Photoshop. Help?
startup_design Aug 18, 2015 3:48 PM (in response to Carl4)Fixed it for me even with Photoshop CC 2015 1.01
36. Re: My numbers and punctuation glitching on Photoshop. Help?
kathrynm17082359 Sep 8, 2015 12:58 PM (in response to c0ward)Yes! Carl's explanation worked! TY so much. How awful of Adobe to release it this way --even on the latest upgrade it isn't fixed. Ridiculous.
37. Re: My numbers and punctuation glitching on Photoshop. Help?
amytreacle Sep 14, 2015 8:08 AM (in response to Carl4)Thank you so much for this. I've had my brain wrapped around this problem for over an hour trying all sorts of diagnostics recommended by folk. You're a life saver.
38. Re: My numbers and punctuation glitching on Photoshop. Help?
crezzysue Dec 3, 2015 4:10 AM (in response to Xenil)Thanks @xenil for the visuals and explanation - this fixed the issue for me
39. Re: My numbers and punctuation glitching on Photoshop. Help?
ta2laroo Dec 13, 2015 7:30 PM (in response to Carl4)Thanks Carl4!! This is the link that saved me as well, I tried everything else and nothing had worked.
