3 Replies Latest reply on Sep 11, 2012 9:17 PM by Yuvayu
    Data Retrieve Issue
    Yuvayu
      Hi
      For my last post I haven't got any reply I think no one got my issue.
      So I am posting exactly what I am doing and what I am getting.
      Expecting some solution from someone.
      In my views package I have LoginForm.mxml
      Here I am dispatching the event the method I have used goes like this.
      [Bindable]
      public var user:User;
      private function checkUser():void{
          var uId:Number = 4;
          user.userId = uId;
          var event:UserEvent = new UserEvent(UserEvent.LOGIN);
          event.userId = uId;
          dispatchEvent(event);
      My User.as contains
      [Bindable]
      public class User
          public var userId:Number;
          public var userName:String;
          public var userPhone:String;
          public var userGuest:int;
          public var userDate:String;
          public var userTime:String;
      My UserEvent.as contains
      public class UserEvent extends Event
          public static const LOGIN:String = "login";
          [Bindable]
          public var userGuest:Number;
          public function UserEvent(type:String)
              super(type,true);
      In my maps package I have MainEventMap.mxml, which contain.
      <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          <ns:Debugger level="{Debugger.ALL}" />
          <ns:EventHandlers type="{UserEvent.LOGIN}" debug="true">
              <ns:WebServiceInvoker wsdl="MY URL?WSDL"
                        method="GetUserProfile"
                        arguments="{[4]}"
                        debug="true">
                  <ns:resultHandlers>
                      <ns:CallBack method="handleUser" arguments="{resultObject}" />
                  </ns:resultHandlers>
                  <ns:faultHandlers>
                      <ns:CallBack method="handleFault" arguments="{fault.faultDetail}" />
                  </ns:faultHandlers>
              </ns:WebServiceInvoker>
          </ns:EventHandlers>
          <ns:Injectors target="{LoginForm}">
              <ns:PropertyInjector targetKey="user" source="{User}" />
          </ns:Injectors>
      </fx:Declarations>
      MY URL result file contain method "GetUserProfile" to which I am passing argument "4" as "Number".
      And I am getting the output as.
      <NewDataSet>
          <userProfile>
              <UserId>4</UserId>
              <UserDetailId>4</UserDetailId>
              <UserName>ravi</UserName>
              <EmailId>ravi@example.com</EmailId>
              <FirstName>ravi</FirstName>
              <Occupation>Flex Developer</Occupation>
              <Country>India</Country>
              <State>Andhra Pradesh</State>
              <City>Vijayawada</City>
              <MobileNumber>+9100000000</MobileNumber>
              <LandLine>111111111</LandLine>
          </userProfile>
      </NewDataSet>
      In the "handleUser" method which is in LoginForm.mxml I wrote
      public function handleUser(returnText:Object):void
          for(var i in returnText){
              Alert.show(i);
      I am trying to alert the result I am geeting.
      NewDataSet
      Please help me to get out of this.
      Thank you.
        • 1. Re: Data Retrieve Issue
          John Hall Level 4
          A couple questions. Did you include an instance of the map in the main application? I would expect something like:
          <ns:MainEventMap /> to make sure the map is instantiated and the global dispatcher is created.
          With Mate, I'd be sure to bubble any custom events. Something like
          public function UserEvent( type : String, bubbles : Boolean = true, cancelable : Boolean = false ) {
                                        super( type, bubbles, cancelable );
                              override public function clone () : Event {
                                        return new UserEvent( type );
          • 2. Re: Data Retrieve Issue
            John Hall Level 4
            Whoops. Looks like you do have bubbles turned on. How about the instance of the mainEventMap at toplevel?
            • 3. Re: Data Retrieve Issue
              Yuvayu Level 1
              Thank you John for giving your time to my issue.
              Yes I do have added map instance in main application as,
              <fx:Declarations>
                   <maps:MainEventMap />
              </fx:Declarations>
              And to my custom event I did change like,
              I have tried to alert the result but I am getting the same thing,
              NewDataSet
              If you can provide me any running example related to my issue then I will be very thankful to you.
              Please mail me to paragbansod@yuvayu.com
              And if you want to see what exactly what I have done with the code I can send the files.
              It will be helpful because I am working on MATE first time and dnt have much idea about it.
              Thank you once again.
