1 Reply Latest reply on Aug 28, 2012 10:37 AM by Milky_au
    How can I prevent a swf file from playing too fast in Director 11.5?
    DanEdmonds
      Hello,
      I've inserted a swf file as a "Flash movie..." media element in Director 11.5 and I've checked "DTS". The video in the swf file is playing very fast while the audio plays normal. From what I understand, checking "DTS" is supposed to control this, no?
      Why does this happen? How can I play the swf file normally?
      Thank you in advance!!
        • 1. Re: How can I prevent a swf file from playing too fast in Director 11.5?
          Milky_au Level 3
          G’Day Daedmonds,
          Whenever I get this problem – I set the ‘Frame Properties: Tempo’ to the same as the playing flash movies fps.
          It sounds like you have your director frame tempo set to 30fps (default) while your flash movie has a lower fps tempo.
          (the sound plays at the right speed - but the animation plays too quick)
          You can add a tempo for each frame, via the top line of the Effects Channels.
          I hope this helps.
          Milky.
