This content has been marked as final.
Show 2 replies
1. Re: Installing PS Extended over PS standard
Mylenium Aug 28, 2012 7:25 AM (in response to charles badland)There is no way to install two Photoshops. It's either one or the other. Extended will simply superceed/ replace Standard. Uninstalling beforehand will do zero to help matters along. It's simply a serial number thing that turns Standard into Extended even though you will need to run the installer again to bend the licensing in place for the new serial number. Beyond that it will simply use whatever prefs and settings are already in place.
Mylenium
2. Re: Installing PS Extended over PS standard
charles badland Aug 28, 2012 7:28 AM (in response to Mylenium)Excellent. Thank you.
