2 Replies Latest reply on Aug 29, 2012 5:43 AM by rbyond
    Sum one Field based on another's input
    rbyond
      I have a question. Is it possible to have a specific field populated with specific number based on the input of antother field. Example.  In Field #10  I have to input a number.  If the number is 1-365 it's an ( F) If the number is 366- 392 it's an ( D) if it's 393-460 its an (C) if it's 461-500 it's an ( B) if 501-700 it's an (A).  So In Field  #11  I want that to populate the Letter based on the input of the number input in field#10.  Is that possible in Javascript or How?
      Thank You in Advance
        • 1. Re: Sum one Field based on another's input
          George_Johnson MVP & Adobe Community Professional
          Sure it's possible. The custom Calculate script for the text field could be:
          (function () {
              // Get the field value, as a number
              var val = +getField("Text10").value;
              // Set this field's value
              if (val < 366) {
                  event.value = "F";
                  return;
              if (val < 393) {
                  event.value = "D";
                  return;
              if (val < 461) {
                  event.value = "C";
                  return;
              if (val < 501) {
                  event.value = "B";
                  return;
              if (val < 701) {
                  event.value = "A";
                  return;
              // Default
              event.value = "";
          • 2. Re: Sum one Field based on another's input
            rbyond Level 1
            Thanks George! That got me back on Track!! awesome
