2 Replies Latest reply on Feb 26, 2008 1:10 AM by anirudhs
    Flex in Air
    ralph31
      If I create a file with Flex 3, then compile with Air will work?
        • 1. Re: Flex in Air
          SujitG Level 2
          You might have to create the application descriptor files and other stuff which the AIR application required. You should also make sure you are using WindowedApplication.
          Hope this helps.
          • 2. Re: Flex in Air
            anirudhs Level 2
            If you have flex builder, create a new AIR project, dump your flex 3 files there and it will work.
            Like SujitG said, you have to change the root tag of your main MXML file from <mx:Application> to <mx:WindowedApplication> if you want the native window chrome with maximize, minimize, etc to come around your application.
