2 Replies Latest reply on Aug 29, 2012 5:41 AM by vDeepak
    How select text range
    Bill joy Level 1
      Hi
      I want to select some text in a textframe.
      I am using this method
      textFrame.characters.itemByRange(n,m).select();
      but characters.ItemByRange();
      give error member not found if I am using long Integer as a parameter in this.
      for example my text is AdobeIndesign and i want to select Indesign in AdobeIndesign.
      characters.ItemByRange(6,13);
      How use characters.ItemByRange() to select text.
      or there is another method to select a text range.
      How use character or String type parameter in characters.ItemByRange()
      Thanks.
        • 1. Re: How select text range
          @Bill – with the "select()" method you can work in two ways:
          1. Use it with the app object like that:
          var whatToSelect = textFrame.characters.itemByRange(6,13);
          app.select(whatToSelect);
          2. Work from the object you want to select and replace any selected object with that object:
          whatToSelect.select(SelectionOptions.REPLACE_WITH);
          OR:
          You can address the object directly with a variable without selecting anything and instead do something with it (in this case assigning a fill color):
          var whatToAddress = textFrame.characters.itemByRange(6,13);
          whatToAddress.fillColor = "Yellow";
          Also see InDesign JavaScript Reference Guides at:
          http://www.jongware.com/idjshelp.html
          Uwe
          • 2. Re: How select text range
            vDeepak Level 1
            Hi Bill,
            1. You need to refer to first item of the result of ItemByRange. and
            2. Use character objects(startCharacter, endCharacter) as parameter for itemByRange function.
            Try this...
            var startCh = tframe.paragraphs[0].characters[5];
            var endCh = tframe.paragraphs[0].characters[12];
            tframe.paragraphs[0].characters.itemByRange(startCh,endCh).select();
            Thanks.
