2 Replies Latest reply on Aug 30, 2012 3:55 AM by l33tian
    Data binding will not be able to detect....
    fsoender
      I need some help with my code.
      I got this error: Data binding will not be able to detect assignment to "chartData".
      Marked with "HERE"
      Code:
                              xmlns:s="library://ns.adobe.com/flex/spark" applicationDPI="160"
                              xmlns:mx="library://ns.adobe.com/flex/mx"
                              applicationComplete="applicationCompleteHandler(event)">
             <fx:Script>
                    <![CDATA[
                           import be.aboutme.nativeExtensions.udp.UDPSocket;
                           import mx.events.FlexEvent;
                           private var udpSocket:UDPSocket;
                           public var NewValue:Object;
                           public var Value:String;
                           [Bindable]
                           private var chartIndex:int = 0;
                           private var chartData:ArrayCollection = new ArrayCollection;
                           import mx.collections.ArrayCollection;
                           protected function applicationCompleteHandler(event:FlexEvent):void
                                 udpSocket = new UDPSocket();
                                 udpSocket.addEventListener(DatagramSocketDataEvent.DATA, udpDataHandler);
                                 udpSocket.bind(1000);
                                 udpSocket.receive();
                           protected function udpDataHandler(event:DatagramSocketDataEvent):void
                                 var Value:String = event.data.readUTFBytes(event.data.bytesAvailable);
                                 if(Value)
                                        NewValue = Value;
                                        Test.appendText(Value);
                                        chartData.source[chartIndex] = NewValue;
                                 else
                                        NewValue = 0;
             </fx:Script>
             <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                    <mx:SolidColorStroke id="s3" color="0x33F400" weight="1"/>
             </fx:Declarations>
             <s:layout>
                    <s:VerticalLayout paddingBottom="10" paddingLeft="10" paddingRight="10" paddingTop="10" />
             </s:layout>
             <s:Scroller width="100%" height="100%">
                    <s:VGroup width="100%">
                           <s:TextArea id="Test" width="100%" height="49" editable="false"/>
                           <s:HGroup width="100%">
                           </s:HGroup>
                    </s:VGroup>
             </s:Scroller>
             <mx:CartesianChart id="linechart" width="100%" height="207" cacheAsBitmap="true"
                                           cachePolicy="on" paddingLeft="5" paddingRight="5">
                    <mx:verticalAxis>
                           <mx:LinearAxis id="vAxis" alignLabelsToInterval="true" autoAdjust="false"
                                                  baseAtZero="false" interval="16" maximum="256" minimum="0" padding="1"/>
                    </mx:verticalAxis>
                    <mx:verticalAxisRenderers>
                           <mx:AxisRenderer axis="{vAxis}" canDropLabels="true" color="0xF8F8F6" fontSize="8"/>
                    </mx:verticalAxisRenderers>
                    <mx:horizontalAxis>
                           <mx:LinearAxis id="hAxis" alignLabelsToInterval="true" autoAdjust="false"
                                                  baseAtZero="false" interval="25"/>
                    </mx:horizontalAxis>
                    <mx:horizontalAxisRenderers>
                           <mx:AxisRenderer axis="{hAxis}" canDropLabels="true" color="0xF8F8F6" fontSize="8"/>
                    </mx:horizontalAxisRenderers>
                    <mx:fill>
                           <mx:SolidColor color="0x231F20"/>
                    </mx:fill>
                    <mx:backgroundElements>
                           <mx:GridLines cacheAsBitmap="true" cachePolicy="on" gridDirection="horizontal">
                                 <mx:horizontalStroke>
                                        <s:SolidColorStroke alpha="0.2" color="0xD4D4D3" weight="0"/>
                                 </mx:horizontalStroke>
                           </mx:GridLines>
                    </mx:backgroundElements>
                    <mx:series>
        HERE --------->                   <mx:LineSeries id="recordGraph" cacheAsBitmap="true" cachePolicy="on"
                                                  dataProvider="{chartData}" form="curve" lineStroke="{s3}"
                                                  sortOnXField="false"/>
                    </mx:series>
             </mx:CartesianChart>
      </s:Application>
