11 Replies Latest reply on Aug 30, 2012 11:59 AM by kglad
    Remove duplicate movieclips problem
    learner102
      I have a shooter game where i duplicate bullet holes in the wall.  Works nicely though i have to use Version: Flash Player 6 for the code to work.  Here is the simple code:
      hit1.onPress=function(){
           i++;
           _root.bullet.duplicateMovieClip("bulletNew", i);
      I have a Reset Button that i would like to use to remove all the duplicate "bulletNew" movieclips at once.  This is what i have so far but it only removes one duplicate at a time:
      reset_mc.onRelease=function(){
           removeMovieClip("bulletNew");
      Please be clear with instructions because I have never grasped AS too well.
      Thanks.
        • 1. Re: Remove duplicate movieclips problem
          to publish for later fp versions, initialize your variables (like i) and check upper/lower case of all code.
          var i:Number=0;
          var tl:MovieClip=this;
               i++;
               _root.bullet.duplicateMovieClip("bulletNew"+i, i);
             for(var j:Number=0;j<i;j++){
          if(tl["bulletNew"+i]){
          tl["bulletNew"+i].removeMovieClip();
          p.s.  if that's the only place you create bullet holes, you can make that code more efficient by only looping through movieclips that exist.  for example:
          var i:Number=0;
          var bulletNewA:Array=[];
          bulletNewA.push(_root.bullet.duplicateMovieClip("whatever",i));
          for(var j:Number=bulletNewA.length-1;j>=0;j--){
          var mc:MovieClip=bulletNewA.splice(j,1)[0];
          mc.removeMovieClip();
          • 2. Re: Remove duplicate movieclips problem
            learner102 Level 1
            I attached your code but it only removes the last mc created.  So I don't know what's going on.
            • 3. Re: Remove duplicate movieclips problem
              copy and paste the code you're using.
              • 4. Re: Remove duplicate movieclips problem
                learner102 Level 1
                Adjusted code to duplicate bullet holes when clicking bulletHit_mc:
                var i:Number=0;
                Mouse.hide();
                startDrag(target_mc,true);
                bulletHit_mc.tabEnabled=false;
                bulletHit_mc.onPress=function(){
                i++;
                spark_mc.gotoAndPlay(2);
                Adjusted code for reset movieclip (to remove all duplicated mcs):
                reset_mc.tabEnabled=false;
                Its pretty much what you have given me but only removes one of the duplicated mcs
                Thanks for looking.
                • 5. Re: Remove duplicate movieclips problem
                  oops, my fault.  use:
                  var i:Number=0;
                  var tl:MovieClip=_root.bullet;
                  Mouse.hide();
                  i++;
                  if(tl["bulletNew"+j]){
                  tl["bulletNew"+j].removeMovieClip();
                  • 6. Re: Remove duplicate movieclips problem
                    learner102 Level 1
                    Well, I'm sorry to say it had no effect on any of the duplicated MCs this time.  Is there any other information you need from me to attempt another try?  I appreciate your time looking into this.
                    • 7. Re: Remove duplicate movieclips problem
                      one more try:
                      var i:Number=0;
                      var tl:MovieClip=_root;
                      Mouse.hide();
                      i++;
                      • 8. Re: Remove duplicate movieclips problem
                        learner102 Level 1
                        I tried re-inserting the code thismorning and it appears to have WORKED!  But it still leaves behind the very last duplicate created.  Its not a big deal but if you could help me with this last hurdle....Thanks again for your time!
                        • 9. Re: Remove duplicate movieclips problem
                          use:
                          var i:Number=0;
                          Mouse.hide();
                          i++;
                          for(var j:Number=0;j<=i;j++){
                          p.s.  please mark helpful/correct responses.
                          • 10. Re: Remove duplicate movieclips problem
                            learner102 Level 1
                            Thank you so much, kglad.  You are awesome!  Marked as correct!  I may ask one more question related to this later if i can't figure it out myself.
                            • 11. Re: Remove duplicate movieclips problem
                              you're welcome.
