0 Replies Latest reply on Aug 30, 2012 2:12 AM by LauriNaalisvaara
    BorderContainer and percentWidth
    LauriNaalisvaara
      Hi
      Im trying to create a simple image carousel. Here is the source code:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  import spark.core.SpriteVisualElement;
                  private var timer : Timer;
                  private var i : int = 0;
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                      timer = new Timer(200,30);
                      timer.addEventListener(TimerEvent.TIMER,timerHandler);
                      timer.start();
                  private function timerHandler(e : TimerEvent) : void {
                      var img : SpriteVisualElement = new SpriteVisualElement();
                      img.graphics.beginFill(0x00FF00,1);
                      img.graphics.drawRect(0,0,100,30);
                      img.graphics.endFill();
                      img.x = i * 105;
                      i++;
                      slave1.addElement(img);
                      trace("master width : " + master.width.toString() + " slave1 width : " + slave1.width.toString() + " slave2 width : " + slave2.width.toString());
          </fx:Script>
          <s:BorderContainer id="master" y="100" left="400" right="400" height="200">
              <s:Group id="slave1" />
              <s:BorderContainer id="slave2" y="100" height="100" width="75%" backgroundColor="0xFF0000"/>
          </s:BorderContainer>
      </s:Application>
      Point of this is that slave2 is supposed to be masking slave1. Width of slave2 is supposed to be 75% of the master container ( the background im using) but as the width of slave1 grows when im loading the images so does the width of slave2. What i understand is that the percentWidth property is supposed to set the width as % of the parent containers width ( in this case 75% of master containers width). So how come the size of slave1 does affect to the size of slave2 even though the width of the master container stays the same?
      I want to use percentWidht because the size of the master container changes and i want slave2(the mask) to be resized with it.
      Cheers.
