3 Replies Latest reply on Aug 31, 2012 7:53 AM by beh_gras_beh
    XML to textframe
    beh_gras_beh Level 1
      Dear people,
      I have a XML structure like this.
      <item01>
           <item02>data</item02>
           <item03>data</item03>
           <item04>data</item04>
      </item01>
      When I drag "item01" to Indesign from the XML structure everthing is beeing placed incide the <item01> frame.
      Is it possible trough scripting that <item02>, <item03>, <item04> is beeing cut and paste in to new textframes inside <item01>?
      Greetings!
        • 1. Re: XML to textframe
          vDeepak
          Hi beh_gras_beh,
          If the textFrames you are using are linked frames, then you can just use SpecialCharacters.FRAME_BREAK after each xml elements.
          otherwise use.....
          var rootElement = app.activeDocument.xmlElements.item(0);
          for(var cnt=0; cnt<rootElement.xmlElements.length; cnt++) {
                  var childElement = rootElement.xmlElements.item(cnt);
                  var tFrame = app.activeDocument.textFrames.add();
                  if(tFrame==null)
                      break;
                  tFrame.placeXML(childElement);
          Deepak.
          • 2. Re: XML to textframe
            Yeah!
            That's going the right direction!
            Only the script is creating a textframe of the root element <item01>.
            <item02>, <item03> and <item04> are not in a textframe is that possible too?
            I thought textframes inside textframes are called inline textrames right? (native language is not English )
            Thank you very, very much for the help!
            • 3. Re: XML to textframe
              Solved!
              var mydoc = app.activeDocument;
              var rootElement = mydoc.xmlElements.item(0);
              var linkElementList = rootElement.evaluateXPathExpression("//item01/item02");
              for(var lp=linkElementList.length-1; lp>=0; lp--){
                      var myElement = linkElementList[lp];
                              var myTextframe = myElement.placeIntoInlineFrame(["21p9","5p"]);
              var linkElementList = rootElement.evaluateXPathExpression("//item01/item03");
              alert("Proces Completed");
