4 Replies Latest reply on Feb 23, 2008 11:32 AM by BeausMom
    BeausMom Level 1
      I've batch converted 300 .tif's to .jpg's. My client says the images now have an inaccurate pink hue. Is there something I don't know about here?
        • 1. Re: Color problem converting .tif to .jpg
          pixlor Level 4
          What settings did you use on your export? Can you post an example of each?
          • 2. Re: Color problem converting .tif to .jpg
            BeausMom Level 1
            I just used Fireworks' batch process. I converted the image size to fit area 800x800 pixels, and exported to better quality .jpg from .tif. I'm not sure the best way to present examples. Click the URL and go to page 11, lot 119. The thumbnail is a pure Fireworks conversion. But the detail image is a Photoshop conversion. Do I need to use Photoshop to achieve more accurate color? Scottsdale Art Auction
            • 3. Re: Color problem converting .tif to .jpg
              pixlor Level 4
              The Fireworks "better quality' setting corresponds to
              Quality: 80
              Smoothing: No Smoothing
              Sharpen color edges (checked)
              Remove unused colors (checked)
              If I open a 66k .jpg image I have previously saved at Quality in the high 90s, "better quality" will result in a .jpg at 16k file. I usually export with quality above 90; 80 seems extreme for all but the softest of images. If I was going to save .jpgs of artwork, I wouldn't use the "better quality" setting.
              What you need to do is understand what your setting are. I'm pretty sure you can set the parameters for your batch conversion to be whatever you want. Experiment with a few of the images you have to determine what is optimal for your images and define a new export preset (or more than one) to use. Images with higher contrast (either luminance or color) will need a higher quality setting to achieve the same relative faithfulness in reproduction.
              • 4. Re: Color problem converting .tif to .jpg
                BeausMom Level 1
                Thank you for your thorough response. I'll give it a try.
