1 Reply Latest reply on Aug 30, 2012 1:30 PM by kglad
    How to set duration?
    Adrtghhjj Level 1
      I want a frame of an animation to show for some seconds.
      I know that by CTRL-dragging to the right I can increase its duration- however:
      If the (single) frame in question is followed by other frames (on the same layer, blank frames or not) then CTRL-dragging doesn't work.
      What is the usual way of solving this problem- so that the frame becomes longer and subsequent frames are "pushed" to the right, not overwritten?
      Thanks.
        • 1. Re: How to set duration?
          right click and click insert frame.  you can also select a span of frame and copy and paste those to add many more frames if adding one at a time is too slow.  and there are other ways to extend your timeline (like using f5 if you haven't customized that keyboard input).
