16 Replies Latest reply on Aug 31, 2012 11:16 PM by josephs51576386
    What settings for exporting 1080p videos for Youtube recorded from FRAPS?
    Cjc_1992 Level 1
      Hello,
      I've tried a custom setting of mine which took an hour or so to render but came out blurry:
      Video:
      H264
      1920 x 1080
      Bitrate: 15
      VBR, 1 PASS
      29.97 FPS
      PAL
      And audio is just on default with 160 bitrate.
      The quality from FRAPS is perfect but as said before when inported in Premiere and then rendered its outputted blurry and jumpy.
      Any ideas?
      Thanks.
      EDIT: Just for reference I followed this tutorial: http://www.youtube.com/watch?v=FL9JULY8IkU
        • 1. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
          I don't use fraps, so I have NO idea if these previous discussions will help... or not... but free to read
          Fraps http://forums.adobe.com/thread/871095 -and http://forums.adobe.com/thread/943772
          • 2. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
            Cjc_1992 Level 1
            Unfortunately it didn't really help, I've even tried this guide: http://www.youtube.com/watch?v=6tODFGwRpMI
            But it's still outputting jumpy blury video :/
            Thanks.
            • 3. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
              josephs51576386 Level 3
              I'm assuming your source is actually 1920x1080 to begin with correct? Or are you saying you tried to simply use 1920x1080 with a bitrate of 15? I just want to make sure I'm following you.
              Please tell me what your source footage stats are. Please include all stats like aspect ratio etc. to do this you can use a program like media info
              • 4. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                Cjc_1992 Level 1
                Yeah I'm recording in 1920x1080. I just played around with some settings and managed to render perfectly on a 30 second vid, which is just for trial it didn't have blurriness which is good .  I've now tried the same with the full 15 min vid so hopefully it'll work too.
                • 5. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                  Glad to hear that hopefully you've solved your own issue then.
                  • 6. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                    Paul Mc Bride Level 1
                    I haven't used FRAPS myself  but you did say ( may be a typo ) you had a custom setting which stated 29.97 fps PAL.
                    PAL is 25fps.
                    Maybe part of your problem.
                    • 7. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                      Cjc_1992 Level 1
                      Well it's finished encoding and this is what it looks like:
                      http://gyazo.com/56ddb547a5260519af05ac449585ed2d
                      Hideous. Haha, any ideas?
                      Source file:
                      http://gyazo.com/f7f453efe601eac87173cbcd1ed52b60
                      Really don't quite get it.
                      Thanks.
                      • 8. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                        Please list the exact source specs along with the exact ouput specs you used. Or if you upload a test clip I can attempt to try to get good results on my own. I recommend using the program media info to get all the necessary source specs/output results if you want to go that route.
                        Also please let me know what sequence settings you used inside of Premiere as well. I want to be able to see aspect ratio along with field order etc although I'm assuming it's most likely progressive I just want to be sure so I can help you better.
                        • 9. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                          Cjc_1992 Level 1
                          Thanks for your time. Ill be able to answer your questions in around 8ish hours but for now I better head of to bed, work :(
                          Thanks!
                          • 10. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                            Cjc_1992 Level 1
                            Output file info:
                            General
                            Complete name                            : C:\Users\Charlie\Documents\Adobe\Premiere Pro\5.5\TF2.mp4
                            Format                                   : MPEG-4
                            Format profile                           : Base Media / Version 2
                            Codec ID                                 : mp42
                            File size                                : 1.91 GiB
                            Duration                                 : 15mn 3s
                            Overall bit rate mode                    : Variable
                            Overall bit rate                         : 18.2 Mbps
                            Encoded date                             : UTC 2012-08-31 01:10:24
                            Tagged date                              : UTC 2012-08-31 01:10:24
                            ©TIM                                     : 00:00:00:00
                            ©TSC                                     : 50
                            ©TSZ                                     : 1
                            Video
                            Format                                   : AVC
                            Format/Info                              : Advanced Video Codec
                            Format profile                           : High@L5.1
                            Format settings, CABAC                   : Yes
                            Format settings, ReFrames                : 3 frames
                            Codec ID                                 : avc1
                            Codec ID/Info                            : Advanced Video Coding
                            Duration                                 : 15mn 3s
                            Bit rate                                 : 18.0 Mbps
                            Width                                    : 1 920 pixels
                            Height                                   : 1 080 pixels
                            Display aspect ratio                     : 16:9
                            Frame rate mode                          : Constant
                            Frame rate                               : 50.000 fps
                            Standard                                 : PAL
                            Color space                              : YUV
                            Chroma subsampling                       : 4:2:0
                            Bit depth                                : 8 bits
                            Scan type                                : Progressive
                            Bits/(Pixel*Frame)                       : 0.173
                            Stream size                              : 1.89 GiB (99%)
                            Language                                 : English
                            Color primaries                          : BT.709
                            Transfer characteristics                 : BT.709
                            Matrix coefficients                      : BT.709
                            Audio
                            Format                                   : AAC
                            Format/Info                              : Advanced Audio Codec
                            Format profile                           : LC
                            Codec ID                                 : 40
                            Duration                                 : 15mn 3s
                            Source duration                          : 15mn 4s
                            Bit rate mode                            : Variable
                            Bit rate                                 : 192 Kbps
                            Maximum bit rate                         : 292 Kbps
                            Channel(s)                               : 2 channels
                            Channel positions                        : Front: L R
                            Sampling rate                            : 48.0 KHz
                            Compression mode                         : Lossy
                            Stream size                              : 20.4 MiB (1%)
                            Source stream size                       : 20.4 MiB (1%)
                            Language                                 : English
                            Part of the source file info(FRAPS makes serveral files):
                            General
                            Complete name                            : E:\Fraps Vids\TF2MvM\hl2 2012-08-26 16-14-55-35.avi
                            Format                                   : AVI
                            Format/Info                              : Audio Video Interleave
                            File size                                : 3.95 GiB
                            Duration                                 : 1mn 53s
                            Overall bit rate                         : 298 Mbps
                            Video
                            Format                                   : Fraps
                            Codec ID                                 : FPS1
                            Duration                                 : 1mn 53s
                            Bit rate                                 : 280 Mbps
                            Color space                              : YUV
                            Bit depth                                : 8 bits
                            Bits/(Pixel*Frame)                       : 2.698
                            Stream size                              : 3.71 GiB (94%)
                            Audio
                            Format                                   : PCM
                            Format settings, Endianness              : Little
                            Format settings, Sign                    : Signed
                            Codec ID                                 : 00001000-0000-0100-8000-00AA00389B71
                            Duration                                 : 1mn 53s
                            Bit rate mode                            : Constant
                            Bit rate                                 : 18.4 Mbps
                            Channel(s)                               : 6 channels
                            Channel positions                        : Front: L C R, Back: L R, LFE
                            Sampling rate                            : 192 KHz
                            Bit depth                                : 16 bits
                            Stream size                              : 250 MiB (6%)
                            Interleave, duration                     : 999 ms (49.94 video frames)
                            Sequence settings:
                            General
                            Editing mode: AVCHD 1080p square pixel
                            Timebase: 29.97fps
                            Video Settings
                            Frame size: 1920h 1080v (1.0000)
                            Frame rate: 29.97 frames/second
                            Pixel Aspect Ratio: Square Pixels (1.0)
                            Fields: No Fields (Progressive Scan)
                            Audio Settings
                            Sample rate: 48000 samples/second
                            Default Sequence
                            Total video tracks: 3
                            Master track type: Stereo
                            Mono tracks: 0
                            Stereo tracks: 3
                            5.1 tracks: 3
                            Submix mono tracks: 0
                            Submix stereo tracks: 0
                            Submix 5.1 tracks: 0
                            Thanks for your help.
                            • 11. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                              One suggestion I can think of is to raise your bitrate to like 20 or something, Also though when you pull the footage into Premiere you need to use the bin function of modify>interpet then change the frame rate so it will match your destination/sequence frame rate. You can get to the modify>interpet by right clicking the source file inside your project bin.
                              I noticed is that the footage is 50fps so I noticed you said that you had exported to 29.97 which might have caused some issues too although I doubt it will cause it too look like your example turned out.
                              The only thing I can think of other than what I've already said is if you could possibly upload a very short test clip so I could just personally play with the footage and see what it will take to make it turn out correct.
                              • 12. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                                Cjc_1992 Level 1
                                Hey thanks for the suggestions. If you like I can upload a test clip which will be around 2 mins long. Where would you like me to upload this?
                                Thanks.
                                • 13. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                                  Cjc_1992 Level 1
                                  I just rendered a 2 min clip and it came out great? But when I do the 15 min clip it ends up with that poor quality. Strange.
                                  • 14. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                                    Any free file upload site will work. I'd personally recommend you just create a free adrive account and upload it there. Because they give 50Gb of free storage and all you have to provide is a email. The two min vs. 15 min scenario is strange though to say the least. Try changing it to either a 20Mbps CBR or make it a 2 pass vbr.
                                    • 15. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                                      Cjc_1992 Level 1
                                      There we go again just finished the 12 min video and it came out terrible again. I really don't get this :/
                                      Huge difference:
                                      http://gyazo.com/bfbc1b51442fd5f4c50034ec91b21364
                                      • 16. Re: What settings for exporting 1080p videos for Youtube recorded from FRAPS?
                                        The only thing I can think of at this point is to have you upload a test file so I can just attempt to play with it myself and see if I can figure out what is going on here. I sent you a private message with my email address.
                                        So if you want to use adrive and email me a link to a 2min original HQ test clip I'll try to figure out what is going wrong.
                                        Honestly though if you have enough Hard disk space I'd really recommend you trying to use a lossless codec like Lagarith or something visually lossless like DNxHD and see how it comes out looking.
