4 Replies Latest reply on Sep 2, 2012 5:41 PM by vJnr
    Assistant required - Notallowederror: security settings prevent access to this property or method
    vJnr
      Hey guys
      Another Notallowederror quesiton, can you please assist? I'm very new to LiveCycle and coding in general, any assistant would greatly be appreciated.
      Within my form there's an 'Add attachement question', the following message pop up when the button is clicked
      Acrobat EScript Built-in Functions Version 10.0
      Acrobat SOAP 10.0
      NotAllowedError: Security settings prevent access to this property or method.
      Doc.importDataObject:13:XFA:Form[0]:supportingDocs_pg[0]:supportingDocs2_sf[0]:smallAttach s_sf[0]:BtnAdd[0]:click
      Form.supportingDocs_pg.supportingDocs2_sf.smallAttachs_sf.BtnAdd::click - (JavaScript, client)
      // Attach File
      var lodoc = event.target;
      var loattachs = lodoc.dataObjects;
      var lvattachsnum = 0;
           if (loattachs != null)
                lvattachsnum = loattachs.length;
      var lv_aname = "attach" + (lvattachsnum + 1); lodoc.importDataObject(lv_aname); var loattach = lodoc.getDataObject(lv_aname);
      var fileName = loattach.path;     // Check for file extension
      var FileExt = fileName.substring(fileName.lastIndexOf(".")).toUpperCase();
      var max_size = 2097152; //2mb      var size = loattach.size;
      //xfa.host.messageBox("size"+size);
            if (size > max_size)
                   xfa.host.messageBox("Use the large attachment option. Attachment larger than 2MB cannot be attached in this window. ");
                   lodoc.removeDataObject(lv_aname);
           else if (FileExt == null ||
                     FileExt == "" || (
                     FileExt != ".AVI" &&
                     FileExt != ".BMP" &&
                     FileExt != ".BPMN" &&
                     FileExt != ".DOC" &&
                     FileExt != ".DOT" &&
                     FileExt != ".DOCX" &&
                     FileExt != ".DOTX" &&
                     FileExt != ".DRW" &&
                     FileExt != ".EML" &&
                     FileExt != ".EPS" &&
                     FileExt != ".GIF" &&
                     FileExt != ".JPG" &&
                     FileExt != ".MP3" &&
                     FileExt != ".MP4" &&
                     FileExt != ".MPEG" &&
                     FileExt != ".MPG" &&
                     FileExt != ".MPP" &&
                     FileExt != ".MSG" &&
                     FileExt != ".NOTEBOOK" &&
                     FileExt != ".ODT" &&
                     FileExt != ".OTT" &&
                     FileExt != ".SXW" &&
                     FileExt != ".STW" &&
                     FileExt != ".PDF" &&
                     FileExt != ".XDP" &&
                     FileExt != ".CP" &&
                     FileExt != ".PNG" &&
                     FileExt != ".PPT" &&
                     FileExt != ".POT" &&
                     FileExt != ".PPTX" &&
                     FileExt != ".POTX" &&
                     FileExt != ".PUB" &&
                     FileExt != ".RTF" &&
                     FileExt != ".TIF" &&
                     FileExt != ".TIFF" &&
                     FileExt != ".TXT" &&
                     FileExt != ".URL" &&
                     FileExt != ".VSD" &&
                     FileExt != ".WAV" &&
                     FileExt != ".WMA" &&
                     FileExt != ".WMV" &&
                     FileExt != ".XLS" &&
                     FileExt != ".XLT" &&
                     FileExt != ".XLSX" &&
                     FileExt != ".XLTX"))
                    var lvmsg = "Attachments of this type are not accepted. File Type:" + FileExt;
                    app.alert(lvmsg);
         else
                var fileName2 = loattach.path;
                xfa.form.Form.supportingDocs_pg.supportingDocs2_sf.smallAttachs_sf.ListBox1.addItem(fileN ame2, lv_aname);
      Thanks guys
      Van
