2 Replies Latest reply on Feb 21, 2008 7:44 AM by Russ Ward
    How to set the JavaHelp viewer
    Russ Ward Level 4
      Robohelp 7, Windows XP, installed with the TCS
      How do you point RoboHelp to a different JavaHelp viewer instance after it has been set initially? I was first using JavaHelp 1, but then installed JavaHelp 2, and I want to switch between the two for viewing, as I compile for the different versions. The only way I found to do it was to change the path to the active viewer which causes RoboHelp to lose it and to ask you again where it is.
      And by the way, I looked in the help for this and I got some whacked out non-scrollable window that seemed to search the Adobe website, rather than provide help. Am I doing something wrong? It didn't look like a help system at all.
      Russ
