4 Replies Latest reply on Sep 1, 2012 6:50 AM by rob day
    Spot color to Process color conversion
    sperry1975 Level 1
      I have a book that my boss is wanting printed. This book is filled with RGB / Spot colors. I've discovered that if I go to the "ink manager" I can check the box "All Spots to Process", but the strange thing is after doing that I check in my swatches pannel and discover that nothing was converted. What's up with that? I also found a handy script for converting all RGB colors to CMYK, but I have yet to locate a script to convert all spot to process colors in the swatches pannel. Anyone know where I can get a script for that?
        • 1. Re: Spot color to Process color conversion
          BobLevine MVP & Adobe Community Professional
          It will still output as process. You can confirm that by using the separations preview panel.
          Bob
          • 2. Re: Spot color to Process color conversion
            sperry1975 Level 1
            Okey, that's great but I would still like to convert all the spots to process in the swatches pannel all at once like I can with the script for rgb to cmyk. Any ideas on that?
            • 3. Re: Spot color to Process color conversion
              You really don't want to do that, you just think you do. Redining the spots as process means they would need to be redifined again if you ever need to output them as spot. Using the ink manager is "effectively" doing the redfinition, and if you check the Use Lab Valus box it will even convert them to better mixes for whatever CMYK profile you choose for output, increasing the chances of a good match (since most spots don't convert will to CMYK). The built-in CMYK values are for some unknown profile that most likely is not the same as the one you will be using.
              • 4. Re: Spot color to Process color conversion
                If you are using OSX try this AppleScript:
                tell application "Adobe InDesign CS6"
                    tell document 1
                        set accurate LAB spots to true
                        repeat with a from 1 to count of every color
                            try
                                set model of color a to process
                                set space of color a to CMYK
                            end try
                        end repeat
                    end tell
                end tell
