1 Reply Latest reply on Sep 1, 2012 4:05 AM by -hans-
    Applescript: Create Grep Style in a Paragraph style
    TheKrayframe
      Hi All
      I'm using the following script to create a grep style within a paragraph style.
      However, the I can't get it to apply my character style? I'm using the applied character style:"GREP_No Break-Text" but no luck!
      Here the script:
      tell application "Adobe InDesign CS6"
        activate
                tell active document
        -- MAKE SWATCHES ************************************************************************************
        -- make "**No Break-Text**" swatch
                          try
                                    set myColourSwatch to swatch "**No Break-Text**"
                          on error
                                    make new color with properties {model:process, space:CMYK, color value:{0, 100, 0, 0}, name:"**No Break-Text**"}
                          end try
        -- MAKE CHARACTER STYLES ************************************************************************************
        --no style by that name already exists.
                          try
                                    set myCharacterStyle to character style "GREP_No Break-Text"
                          on error
        --The style did not exist, so create it.
                                    set myCharacterStyle to make character style with properties {name:"GREP_No Break-Text"}
                          end try
        --At this point, the variable myCharacterStyle contains a reference to a character
        --style object, which you can now use to specify formatting.
                          set no break of myCharacterStyle to true
                          set fill color of myCharacterStyle to "**No Break-Text**"
        -- MAKE PARA STYLES  ************************************************************************************
                          try
                                    set myParagraphStyle to paragraph style "Body - Master"
                          on error
                                    set myParagraphStyle to make paragraph style with properties {name:"Body - Master"}
                          end try
                          tell paragraph style "Body - Master"
        make new nested grep style with properties {grep expression:"GREP EXPRESSION HERE"} -- this works
        --make new nested grep style with properties {grep expression:"GREP EXPRESSION HERE", applied character style:"GREP_No Break-Text"} -- This dosen't work
                          end tell
                end tell
      end tell
