0 Replies Latest reply on Sep 1, 2012 6:23 AM by muffinman2k
    FlashBuilder 4.7 project errors!
    muffinman2k Level 1
      Hello,
      when i imported my project into a new workspace created by FlashBuilder 4.7, it gives the following errors on compilation. Several minor projects are converted fine, but this bigger one gets the errors and unfortunately there is no real location given by the compiler.
      Anyone faced the same problems? I was so curious about trying flashbuilder x64 on a big project which is ram constrained...
      DescriptionResourcePathLocationType
      1017: The definition of base class BitmapAsset was not found.testFlex
      line 10Flex Problem
      line 10Flex Problem
      line 10Flex Problem
      1017: The definition of base class ByteArrayAsset was not found.testFlex
      line 10Flex Problem
      1017: The definition of base class MovieClipLoaderAsset was not found.testFlex
      line 6Flex Problem
      1017: The definition of base class SpriteAsset was not found.testFlex
      line 10Flex Problem
      line 10Flex Problem
      1020: Method marked override must override another method.testFlex
      line 16Flex Problem
      Ah, flex sdk remained 4.6; Imported from flash builder 4.6!
      Thanks!
