2 Replies Latest reply on Sep 1, 2012 9:08 PM by Noel Carboni
    Batch resizing
    Atreyu765
      I want to resize dozens of jpeg photos so they are all the same size.  Rather than doing them one at a time, is it possible to do them as a batch in PS CS5?
        • 1. Re: Batch resizing
          If all the image have the same aspect ratio that will be very easy use Menu File>Automate>Batch.  You need to create an action to do the resize use the Photoshop Plug-In Script Fit image.  When you record the single step action to use the Fit Image Dialog the set the size tou want the images to fit in. Set Both the width and height to the size you want the longest side to be. Fit image will constrain the resize so the images aspect ratio will not be chabges so Portrait and Landscape images can be processed in a single run. The Size you set in the Dialog will be recorded into the action step, This size will be set into the script whan the action is played the Scripts dialog will not be displayed. All image will be resized to fit.  Only if all image had the same aspect ratio like 3:2 or 2:3 will the resized image all be the same size.
          If Images do not have the same aspect ratio  you will need to crop all image into the same aspect ratio before doing the Fit Image to have all output images have the same size.
          • 2. Re: Batch resizing
            Noel Carboni Level 8
            Check the Image Processor script:  File - Scripts- Image Processor.
            If it doesn't quite get you there, check out the Image Processor Pro script that Russell Brown provides online.
            -Noel
