This content has been marked as final.
Show 5 replies
1. Re: Volume in fav folder doesn`t work
JSS1138 Sep 2, 2012 5:15 PM (in response to frogmike)I'm confused. The Volume effect is attached to every clip by default. Why are you needing to add it manually?
2. Re: Volume in fav folder doesn`t work
frogmike Sep 2, 2012 6:18 PM (in response to JSS1138)To add more volume when I need it.
3. Re: Volume in fav folder doesn`t work
JSS1138 Sep 2, 2012 6:28 PM (in response to frogmike)Try Gain instead. (Right click the clip in the sequence.) You can add all you want.
4. Re: Volume in fav folder doesn`t work
frogmike Sep 2, 2012 7:06 PM (in response to JSS1138)True, I can do that as well, thanks.
I still feel bothered by the bug though, each way has its pros of working, like copy-pasting the effect.
Mike
5. Re: Volume in fav folder doesn`t work
JSS1138 Sep 3, 2012 12:02 AM (in response to frogmike)You can select multiple clips and adjust them all at once.
