1 Reply Latest reply on Sep 21, 2012 3:12 AM by AndreasRuloffs
    validators and itemrenderers
    AndreasRuloffs
      I have a problem using ItemRenderer.
      I have a table implemented as DataGrid in which some cells are shown by a self written itemRenderer. Depending on the type of the cells data the cell will be also used by a validator. Executing the program everything looks fine, as long as the programs window is not too small. If you scroll in the table then really ugly things happen. The wrong cells get validated by wrong validators and I have even seen that a single cell is validated by several validators.
      I know that the ItemRenderer are recycled and I am pretty sure that this has dealing with the problem. But the validators should be activated and deactivated by databinding which should occure on every databinding. So I should work well? But why it doesn't?
      If I use a List, and set useVirtualLayout="false"then the problem occues no more (but it looks verry different).
      Thank you
      Andreas Ruloffs
      The main Application with the datagrid:
      ?xml version="1.0" encoding="utf-8"?>
       xmlns:mx="library://ns.adobe.com/flex/mx"
       initialize="application1_initializeHandler(event)">
       <fx:Script>
       <![CDATA[
       import mx.collections.ArrayCollection;
       import mx.events.FlexEvent;
       private var data:ArrayCollection = new ArrayCollection();
       protected function application1_initializeHandler(event:FlexEvent):void
       data.addItem(new MonoAttributeData("Text1", "Halloo", "String", true, true, 5 ));
       data.addItem(new MonoAttributeData("Dbl1", "1", "Double", false, true));
       data.addItem(new MonoAttributeData("Int1", "2", "Integer", false, true));
       data.addItem(new MonoAttributeData("Text2", "Welt", "String", true, true, 5 ));
       data.addItem(new MonoAttributeData("Dbl2", "", "Double", false, true));
       data.addItem(new MonoAttributeData("Int2", "54", "Integer", true, true));
       data.addItem(new MonoAttributeData("Text3", "Fix", "String", true, true, 5 ));
       data.addItem(new MonoAttributeData("Dbl3", "", "Double", false, true));
       data.addItem(new MonoAttributeData("Int3", "54", "Integer", true, true));
       dataGrid.dataProvider = data;
       </fx:Script>
       <mx:AdvancedDataGrid id="dataGrid"
       verticalScrollPolicy="on"
       horizontalScrollPolicy="off"
       alternatingItemColors="[#969696,#787878]"
       headerColors="[#969696,#787878]"
       width="100%"
       height="100%"
       sortableColumns="false"
       sortItemRenderer="{null}">
       <mx:columns>
       <mx:AdvancedDataGridColumn dataField="fieldname" headerText="Name" />
       <mx:AdvancedDataGridColumn dataField="value"    headerText="Value"/>
       </mx:columns>
       <mx:rendererProviders>
       <mx:AdvancedDataGridRendererProvider
       dataField="value"
       renderer="MonoLangValueItemRenderer"
       columnIndex="1"/>
       </mx:rendererProviders>
       </mx:AdvancedDataGrid>
      </s:Application>
      The data model for the ItemRenderer:
      package
       import mx.collections.ArrayList;
       public class MonoAttributeData
       private var _value:String;
       private var _changeable:Boolean;
       private var _changed:Boolean;
       private var _valid: Boolean = true;
       private var _validationMessage: String;
       private var _fieldType:String;                    //Double, Integer oder String
       private var _fieldLength:int;
       private var _fieldAllowNull:Boolean
       private var _fieldname:String;
       public function MonoAttributeData(fieldname:String, value:String, fieldType:String, fieldAllowNull:Boolean, changeable:Boolean, fieldLength:int = 0)
       _value = value;
       _changeable = changeable;
       _changed = false;
       _valid = true;
       _validationMessage = "";
       _fieldType = fieldType;
       _fieldLength = fieldLength;
       _fieldAllowNull = fieldAllowNull;
       _fieldname = fieldname;
       public function get fieldname():String
       return _fieldname;
       public function set fieldname(value:String):void
       _fieldname = value;
       public function get validationMessage():String
       return _validationMessage;
       public function set validationMessage(value:String):void
       _validationMessage = value;
       public function get valid():Boolean
       return _valid;
       public function set valid(value:Boolean):void
       _valid = value;
       [Bindable]
       public function get changeable():Boolean
       return _changeable;
       public function set changeable(value:Boolean):void
       _changeable = value;
       [Bindable]
       public function get changed():Boolean
       return _changed;
       public function set changed(value:Boolean):void
       _changed = value;
       [Bindable]
       public function get value():String
       return _value;
       public function set value(value:String):void
       _value = value;
       [Bindable]
       public function get fieldType():String
       return _fieldType;
       public function set fieldType(value:String):void
       _fieldType = value;
       [Bindable]
       public function get fieldLength():int
       return _fieldLength;
       public function set fieldLength(value:int):void
       _fieldLength = value;
       [Bindable]
       public function get fieldAllowNull():Boolean
       return _fieldAllowNull;
       public function set fieldAllowNull(value:Boolean):void
       _fieldAllowNull = value;
      and the ItemRenderer:
      <s:MXAdvancedDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
       width="100%" height="100%" >
       <fx:Declarations>
       <!-- value Commit keine Auswirkung
       dataChange von Anfang an
       Platzieren Sie nichtvisuelle Elemente (z.*B. Dienste, Wertobjekte) hier -->
       <mx:NumberValidator id="validatorDouble"  source="{textInput}"
       property="text"
       valid="validatorDouble_validHandler(event)"
       invalid="validatorDouble_invalidHandler(event)"
       required="{!MonoAttributeData(data).fieldAllowNull}"
       domain="real"
       enabled="{ MonoAttributeData(data).fieldType == 'Double'}"/>
       <mx:NumberValidator id="validatorInt" source="{textInput}"
       property="text"
       valid="numbervalidatorInt_validHandler(event)"
       invalid="numbervalidatorInt_invalidHandler(event)"
       domain="int"
       enabled="{ ( MonoAttributeData(data).fieldType == 'Integer')}"/>
       <mx:StringValidator id="validatorStr" source="{textInput}"
       property="text"
       valid="validatorStr_validHandler(event)"
       invalid="validatorStr_invalidHandler(event)"
       minLength="NaN"
       maxLength="{MonoAttributeData(data).fieldLength}"
       enabled="{MonoAttributeData(data).fieldType == 'String'}"/>
       </fx:Declarations>
       <fx:Script>
       <![CDATA[
       import mx.core.UIComponent;
       import mx.events.ValidationResultEvent;
       private function dataChanged():void
       if(data.value != textInput.text)
       var newValue:String = textInput.text;
       MonoAttributeData(data).changed = true;
       MonoAttributeData(data).value = newValue;
       protected function validatorDouble_validHandler(event:ValidationResultEvent):void
       data.valid = true;
       MonoAttributeData(data).validationMessage = "";
       protected function validatorDouble_invalidHandler(event:ValidationResultEvent):void
       data.valid = false;
       MonoAttributeData(data).validationMessage =  MonoAttributeData(data).fieldname + ": " + event.message + "\n";
       protected function numbervalidatorInt_validHandler(event:ValidationResultEvent):void
       data.valid = true;
       protected function numbervalidatorInt_invalidHandler(event:ValidationResultEvent):void
       data.valid = false;
       protected function validatorStr_validHandler(event:ValidationResultEvent):void
       data.valid = true;
       protected function validatorStr_invalidHandler(event:ValidationResultEvent):void
       data.valid = false;
       </fx:Script>
       <s:Group width="100%" height="100%">
       <s:TextInput  id="textInput"
       change="dataChanged()"
       color="{data.changed?0x666666:0x000000}"
       enabled="{data.changeable}"
       text="{data.value}"
       textAlign="center"
       width="100%" height="100%"/>
       </s:Group>
      </s:MXAdvancedDataGridItemRenderer>
        • 1. Re: validators and itemrenderers
          AndreasRuloffs Level 1
          Hello,
          I have solved the problem myself.
          The problem was not the validators. As I proposed were they activated and deactivated correctly by databinding on each recycling.
          But the textfield in the itemrenderer got a property called ‘errorText’ which was not reseted on recycling. This caused my problem. This little enhancement finally solved my problem:
          private function resetValidation():void
               textInput.errorString = "";
               textInput.toolTip = "";
               validatorDouble.validate();
               validatorInt.validate();
               validatorStr.validate();
          override public function set data(value:Object):void
               super.data = value;
               resetValidation();
          Best regards,
          Andreas Ruloffs
