3 Replies Latest reply on Sep 4, 2012 5:07 PM by groove25
    Basic Layers panel
    web.boards Level 1
      1. What does the small + in the thumbnail for a layer indicate? Is it just indicating a filter was used?
      2. What about the small square? Is it just indicating a shape?
      Thanks.
        • 1. Re: Basic Layers panel
          groove25 Level 4
          Following are some of the thumbnail icons found in the Layers panel:
          The "square" icon indicates a Rectangle, which is a unique, grouped vector object. The "+" sign indicates a Symbol.
          • 2. Re: Basic Layers panel
            web.boards Level 1
            How does the Rectangle shape differ fro the other type of Group?
            Thanks for your response.
            • 3. Re: Basic Layers panel
              groove25 Level 4
              Unlike a standard vector object, a Rectangle can be resized on the canvas using the Pointer tool. It can also be given rounded corners, using the Properties panel.
              Sometimes, a rectangle will need to be "ungrouped" to perform certain path operations. Selecting the rectangle and applying the Modify > Ungroup command will convert it into a standard path. Within the Layers panel, this will change its thumbnail icon to a standard vector path (Pen tool) icon.
