7 Replies Latest reply on Sep 6, 2012 10:51 AM by Noel Carboni
    Runtime Error! R6034
    RAMWolff44 Level 1
      I've read through the archives before anyone points me there.
      I've done all I can to correct this issue including going into the reistry and removing the lines pointing to the old plugins folder.  I'm still getting this Runtime error and now all my new plugins CRASH Photoshop CS6 Extended.  This is horrible.  I just bought Alien's bundle and can't even run it without Photoshop crashing out.  NONE of the plugins that are new and built for 64 bit apps is crashing.  So I'm stuck until I can get this resolved.
      Please don't tell me I need to uninstall and start from scratch.
      IS there another folder / directory with the paths that I can delete since the registry edit didn't seem to do the trick?  I've unchecked the box that points to this directory and yet Photoshop still has it recorded since when I start the program and get to that Preference page shows it, grayed out, but it's still recorded.  Why are there two areas for this information to be kept in the first place?  Makes for a mess like this very issue.
      Please direct me as to what to do.
      Richard McCormick
        • 1. Re: Runtime Error! R6034
          Noel Carboni Level 8
          If the Extra plug-ins folder box is unchecked, the extra plug-ins folder is not enumerated, so you need not worry about anything that's grayed out there, though I wonder what you might have damaged in the registry trying to eliminate that.
          Did you ever copy any plug-ins from your old version of Photoshop to the new one?  What's in your Photoshop plug-ins folder and subfolders?  In a CMD window, do the following command and post the info here:
          DIR "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins" /s
          It's clear you have Windows, and apparently an x64 version, so I'll assume it's Windows 7 x64, and you're talking about crashes of the 64 bit Photoshop.
          You're saying that running a plug-in from AlienWare is crashing Photoshop...  Is that the only time it crashes?
          Besides the DIR requested above, please also go into your Help - System Info dialog, copy all of what's there, and post it here (redact the serial number info if you like).  It's long, but that's okay, the forum software can handle it.
          Have you tried clearing Photoshop's preferences to defaults by pressing and holding Control - Shift - Alt immediately upon cold-starting Photoshop?  It will prompt you to clear all your preference settings if you get the keys down quickly enough.
          -Noel
          • 2. Re: Runtime Error! R6034
            RAMWolff44 Level 1
            Just home from work.  Sorry for the late reply.
            Yes, I did copy over some older plugins that WORK with CS5 but perhaps something changed in how PSCS6 looks and works with older plugins?  Not sure but all I care about at this point is getting things back to running.  As stated the plugins I JUST bought are now causing PS to crash so there is something not kosher.
            Yes, I do run Win 7, 64 bit.  i7, 16 gigs of DDR3 RAM, Seagate HD's, NVIDIA card with 2 gigs of DDR5 RAM on board.  Nice system overall
            The Alienware plugins were JUST purchased but no, the system crashed out using other plugins too some I think the Runtime Library issue is making the 64 bit version of PS crash out when trying to use plugins.  This is not happening with the 32 bit version.
            Here is the rest of the info you requested:
            Adobe Photoshop Version: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x64
            Operating System: Windows 7 64-bit
            Version: 6.1
            System architecture: Intel CPU Family:6, Model:10, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 2798 MHz
            Built-in memory: 16382 MB
            Free memory: 12896 MB
            Memory available to Photoshop: 14748 MB
            Memory used by Photoshop: 59 %
            Image tile size: 128K
            Image cache levels: 4
            OpenGL Drawing: Enabled.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            OpenGL Allow Old GPUs: Not Detected.
            Video Card Vendor: NVIDIA Corporation
            Video Card Renderer: GeForce GTX 560/PCIe/SSE2
            Display: 2
            Display Bounds:=  top: 0, left: 1920, bottom: 900, right: 3520
            Display: 1
            Display Bounds:=  top: 0, left: 0, bottom: 1200, right: 1920
            Video Card Number: 1
            Video Card: NVIDIA GeForce GTX 560
            OpenCL Unavailable
            Driver Version: 8.17.12.9573
            Driver Date: 20120209000000.000000-000
            Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
            Video Mode: 1920 x 1200 x 4294967296 colors
            Video Card Caption: NVIDIA GeForce GTX 560
            Video Card Memory: 2048 MB
            Video Rect Texture Size: 16384
            Serial number: 92628390171839431935
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
            Temporary file path: C:\Users\RAMWorks\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              C:\, 465.7G, 77.6G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
            Additional Plug-ins folder: C:\Users\RAMWorks\Documents\!2D & 3D Program Files\2D Apps & Viewers\- Filters Plug-ins\Plugins for ALL\
            Installed components:
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2012/06/05-15:16:32   66.507768   66.507768
               adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
               AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
               AdobeOwl.dll   Adobe Owl 2012/06/26-12:17:19   4.0.95   66.510504
               AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
               AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
               AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
               AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
               AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
               adobe_caps.dll   Adobe CAPS   6,0,29,0
               AGM.dll   AGM 2012/06/05-15:16:32   66.507768   66.507768
               ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
               aif_core.dll   AIF   3.0   62.490293
               aif_ocl.dll   AIF   3.0   62.490293
               aif_ogl.dll   AIF   3.0   62.490293
               amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
               ARE.dll   ARE 2012/06/05-15:16:32   66.507768   66.507768
               AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
               AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
               Bib.dll   BIB 2012/06/05-15:16:32   66.507768   66.507768
               BIBUtils.dll   BIBUtils 2012/06/05-15:16:32   66.507768   66.507768
               boost_date_time.dll   DVA Product   6.0.0
               boost_signals.dll   DVA Product   6.0.0
               boost_system.dll   DVA Product   6.0.0
               boost_threads.dll   DVA Product   6.0.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
               CoolType.dll   CoolType 2012/06/05-15:16:32   66.507768   66.507768
               data_flow.dll   AIF   3.0   62.490293
               dvaaudiodevice.dll   DVA Product   6.0.0
               dvacore.dll   DVA Product   6.0.0
               dvamarshal.dll   DVA Product   6.0.0
               dvamediatypes.dll   DVA Product   6.0.0
               dvaplayer.dll   DVA Product   6.0.0
               dvatransport.dll   DVA Product   6.0.0
               dvaunittesting.dll   DVA Product   6.0.0
               dynamiclink.dll   DVA Product   6.0.0
               ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
               FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
               filter_graph.dll   AIF   3.0   62.490293
               hydra_filters.dll   AIF   3.0   62.490293
               icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
               icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
               image_compiler.dll   AIF   3.0   62.490293
               image_flow.dll   AIF   3.0   62.490293
               image_runtime.dll   AIF   3.0   62.490293
               JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
               LogSession.dll   LogSession   2.1.2.1640
               mediacoreif.dll   DVA Product   6.0.0
               MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
               msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
               msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
               msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CS6   CS6
               Plugin.dll   Adobe Photoshop CS6   CS6
               PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
               PSArt.dll   Adobe Photoshop CS6   CS6
               PSViews.dll   Adobe Photoshop CS6   CS6
               SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
               ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
               tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
               WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
               wu3d.dll   U3D Writer   9.3.0.113
            Required plug-ins:
               3D Studio 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Accented Edges 13.0
               Adaptive Wide Angle 13.0
               ADM 3.11x01
               Angled Strokes 13.0
               Average 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Bas Relief 13.0
               BMP 13.0
               Camera Raw 7.1
               Chalk & Charcoal 13.0
               Charcoal 13.0
               Chrome 13.0
               Cineon 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Collada 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Color Halftone 13.0
               Colored Pencil 13.0
               CompuServe GIF 13.0
               Conté Crayon 13.0
               Craquelure 13.0
               Crop and Straighten Photos 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Crop and Straighten Photos Filter 13.0
               Crosshatch 13.0
               Crystallize 13.0
               Cutout 13.0
               Dark Strokes 13.0
               De-Interlace 13.0
               Dicom 13.0
               Difference Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Diffuse Glow 13.0
               Displace 13.0
               Dry Brush 13.0
               Eazel Acquire 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Embed Watermark 4.0
               Entropy 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Extrude 13.0
               FastCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Fibers 13.0
               Film Grain 13.0
               Filter Gallery 13.0
               Flash 3D 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Fresco 13.0
               Glass 13.0
               Glowing Edges 13.0
               Google Earth 4 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Grain 13.0
               Graphic Pen 13.0
               Halftone Pattern 13.0
               HDRMergeUI 13.0
               IFF Format 13.0
               Ink Outlines 13.0
               JPEG 2000 13.0
               Kurtosis 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Lens Blur 13.0
               Lens Correction 13.0
               Lens Flare 13.0
               Liquify 13.0
               Matlab Operation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Maximum 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Mean 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Measurement Core 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Median 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Mezzotint 13.0
               Minimum 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               MMXCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Mosaic Tiles 13.0
               Multiprocessor Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Neon Glow 13.0
               Note Paper 13.0
               NTSC Colors 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Ocean Ripple 13.0
               Oil Paint 13.0
               OpenEXR 13.0
               Paint Daubs 13.0
               Palette Knife 13.0
               Patchwork 13.0
               Paths to Illustrator 13.0
               PCX 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Photocopy 13.0
               Photoshop 3D Engine 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Picture Package Filter 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Pinch 13.0
               Pixar 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Plaster 13.0
               Plastic Wrap 13.0
               PNG 13.0
               Pointillize 13.0
               Polar Coordinates 13.0
               Portable Bit Map 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Poster Edges 13.0
               Radial Blur 13.0
               Radiance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Range 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Read Watermark 4.0
               Reticulation 13.0
               Ripple 13.0
               Rough Pastels 13.0
               Save for Web 13.0
               ScriptingSupport 13.0.1
               Shear 13.0
               Skewness 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Smart Blur 13.0
               Smudge Stick 13.0
               Solarize 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Spatter 13.0
               Spherize 13.0
               Sponge 13.0
               Sprayed Strokes 13.0
               Stained Glass 13.0
               Stamp 13.0
               Standard Deviation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Sumi-e 13.0
               Summation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Targa 13.0
               Texturizer 13.0
               Tiles 13.0
               Torn Edges 13.0
               Twirl 13.0
               U3D 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Underpainting 13.0
               Vanishing Point 13.0
               Variance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Variations 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Water Paper 13.0
               Watercolor 13.0
               Wave 13.0
               Wavefront|OBJ 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               WIA Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               Wind 13.0
               Wireless Bitmap 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
               ZigZag 13.0
            Optional and third party plug-ins:
               Alien Skin Autolayer 3 3.0.0 20463 2012-03-23 12:39
               Alien Skin Autolayer 4 4.0.0
               Alien Skin Blow Up 3 3.0.0
               Blemish Concealer 2.1.1
               Blow Up 3.0.0
               Bokeh 2.0.1
               DAZ Studio 3D Bridge 12.0
               DazUpdateScene 12.0
               Dilation NO VERSION
               Dust and Scratch Remover 2.1.1
               Exposure 4 4.0.0
               Height2Normals NO VERSION
               Height2Occlusion NO VERSION
               JPEG Repair 2.1.1
               Normalize normal map NO VERSION
               Normals2Cavity NO VERSION
               PostworkShop NO VERSION
               Skin Softener 2.1.1
               Smart Fill 2.1.1
               Snap Art 3 3.0.0
               Topaz Adjust 5 10.0
               Topaz Clean 3 10.0
               Topaz DeJpeg 4 10.0
               Topaz DeNoise 5 10.0
               Topaz photoFXlab 10.0
               Topaz ReMask 3 10.0
               TopazRemaskAutomate NO VERSION
            Plug-ins that failed to load: NONE
            Flash:
               Gallery Wrapper
               Mini Bridge
               Kuler
            Installed TWAIN devices: NONE
            Thanks so much for the help!
            Richard
            • 3. Re: Runtime Error! R6034
              RAMWolff44 Level 1
              Here is the plugin info from the CMD:
              09/04/2012  10:40 AM<DIR>      .
              09/04/2012  10:40 AM<DIR>      ..
              09/04/2012  10:42 AM<DIR>      Alien Skin
              09/03/2012  08:23 AM<DIR>      DAZ 3D
              09/03/2012  10:17 AM<DIR>      Filters
              09/03/2012  08:03 AM<DIR>      Measurements
              09/04/2012  10:40 AM<DIR>      Panels
              09/03/2012  08:03 AM<DIR>      PostworkShop
              09/03/2012  10:27 AM<DIR>      topazadjust5_x64
              09/03/2012  10:28 AM           864 topazclean3_x64.lnk
              09/03/2012  10:29 AM           870 topazdejpeg4_x64.lnk
              09/03/2012  10:29 AM           874 topazdenoise5_x64.lnk
              09/03/2012  10:30 AM         1,348 TopazLabs.lnk
              09/03/2012  10:30 AM           870 topazremask3_x64.lnk
                         5 File(s)      4,826 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Alien
              Skin
              09/04/2012  10:42 AM<DIR>      .
              09/04/2012  10:42 AM<DIR>      ..
              03/26/2012  12:00 PM     5,800,960 Alien Skin Autolayer 3 x64.8li
              03/29/2012  10:39 AM        56,832 Alien Skin Autolayer 4 x64.8li
              09/04/2012  10:40 AM<DIR>      Blow Up 3
              09/04/2012  10:41 AM<DIR>      Bokeh 2
              09/04/2012  10:42 AM<DIR>      Exposure 4
              09/04/2012  10:42 AM<DIR>      Image Doctor 2
              09/04/2012  10:42 AM<DIR>      Snap Art 3
                         2 File(s)  5,857,792 bytes
              Skin\Blow Up 3
              04/18/2012  06:02 AM       195,072 Alien Skin Blow Up 3 Automation x64.8li
              04/18/2012  06:02 AM       423,424 Alien Skin Blow Up 3 Photoshop x64.8bf
                         2 File(s)    618,496 bytes
              Skin\Bokeh 2
              09/04/2012  10:41 AM<DIR>      .
              09/04/2012  10:41 AM<DIR>      ..
              06/12/2012  10:32 AM    17,556,480 Alien Skin Bokeh 2 x64.8bf
              05/05/2011  02:34 PM           417 Configuration.ini
              06/12/2012  10:32 AM     6,115,448 License Activation Tool.exe
              05/05/2011  02:35 PM     2,238,464 QtCore4.dll
              05/05/2011  02:35 PM     7,944,192 QtGui4.dll
              05/05/2011  02:35 PM       912,896 QtNetwork4.dll
              05/05/2011  02:35 PM    10,836,992 QtWebKit4.dll
              05/05/2011  02:35 PM       339,968 QtXml4.dll
                         8 File(s) 45,944,857 bytes
              Skin\Exposure 4
              08/09/2012  09:48 AM       436,736 Alien Skin Exposure 4 Photoshop x64.8bf
                         1 File(s)    436,736 bytes
              Skin\Image Doctor 2
              12/17/2010  02:18 PM           439 Configuration.ini
              09/04/2012  10:42 AM<DIR>      help
              03/27/2012  11:41 AM     4,290,560 Image Doctor 2 English x64.8bf
              10/14/2010  03:45 PM     3,828,276 Image Doctor 2 Manual.pdf
              03/27/2012  11:41 AM       545,912 License Activation Tool.exe
              10/14/2010  03:45 PM     2,233,856 QtCore4.dll
              10/14/2010  03:45 PM     7,927,296 QtGui4.dll
              10/14/2010  03:45 PM       773,120 QtNetwork4.dll
              10/14/2010  03:45 PM       339,456 QtXml4.dll
              09/04/2012  10:42 AM<DIR>      Settings
                         8 File(s) 19,938,915 bytes
              Skin\Image Doctor 2\help
              11/07/2007  10:42 AM         5,345 BlemishConcealer.html
              11/07/2007  11:01 AM         2,405 contents.html
              11/06/2007  07:52 PM         3,195 copyright.html
              11/06/2007  08:46 PM         7,975 DustAndScratchRemover.html
              11/07/2007  02:35 PM         2,713 errors.html
              11/07/2007  02:35 PM        16,338 gettingstarted.html
              11/06/2007  09:34 PM         2,039 imagedoctor2.css
              09/04/2012  10:42 AM<DIR>      images
              11/07/2007  09:48 AM        24,079 interface.html
              11/06/2007  08:49 PM         5,610 JPEGRepair.html
              11/07/2007  09:51 AM         7,965 makingselections.html
              11/06/2007  08:31 PM         4,250 preferenceshelp.html
              11/06/2007  08:45 PM         4,763 SkinSoftener.html
              11/06/2007  08:54 PM         8,320 SmartFill.html
                        13 File(s)     94,997 bytes
              Skin\Image Doctor 2\help\images
              11/06/2007  07:46 PM         6,148 .DS_Store
              11/06/2007  08:53 PM        11,264 Adjustment-Tool-Flattened.jpg
              09/11/2007  03:20 PM         2,396 ***_logo.gif
              09/11/2007  04:23 PM           818 Compare-Tool.jpg
              11/06/2007  08:07 PM           153 ctrl-mac.gif
              11/06/2007  08:33 PM        46,807 dust-scratch-example.jpg
              09/11/2007  04:23 PM           507 Folder-Icon.jpg
              11/07/2007  11:00 AM        12,313 Image-Doc2-Logo.jpg
              11/07/2007  10:36 AM        86,254 jpeg-repair-example.jpg
              11/06/2007  09:17 PM        61,514 lasso-selection.jpg
              09/11/2007  04:23 PM           767 Move-Tool.jpg
              11/06/2007  08:03 PM        47,327 Preferences-Dialog.jpg
              11/06/2007  09:18 PM        87,574 Quick-Mask-Selection.jpg
              09/11/2007  04:23 PM        13,148 Save-Dialog-Screenshot.jpg
              11/06/2007  08:34 PM        23,460 Scratch-Tutorial-Before-1.jpg
              11/06/2007  08:34 PM        23,034 Scratch-Tutorial-Finished-1.jpg
              11/06/2007  08:34 PM        25,243 Scratch-Tutorial-Selections-1.jpg
              09/11/2007  04:22 PM           464 Setting-Icon.jpg
              11/06/2007  08:45 PM        45,979 skin-softener-example.jpg
              11/06/2007  08:53 PM        99,904 smart-fill-example.jpg
              11/06/2007  08:54 PM         5,145 Smart-Fill-Texture-Source-Box.jpg
              11/06/2007  08:40 PM        39,237 spot-remover-example.jpg
              11/06/2007  08:10 PM        82,935 UI.gif
              09/11/2007  04:22 PM           692 Zoom-Tool.jpg
                        24 File(s)    723,083 bytes
              Skin\Image Doctor 2\Settings
              09/04/2012  10:42 AM<DIR>      BlemishConcealer
              09/04/2012  10:42 AM<DIR>      DustAndScratchRemover
              09/04/2012  10:42 AM<DIR>      JPEGRepair
              09/04/2012  10:42 AM<DIR>      SkinSoftener
              09/04/2012  10:42 AM<DIR>      SmartFill
                         0 File(s)          0 bytes
              Skin\Image Doctor 2\Settings\BlemishConcealer
              10/11/2007  06:34 AM           566 Factory Default.f1s
              10/11/2007  06:35 AM           634 Mole.f1s
              10/11/2007  06:36 AM           638 Pimple.f1s
              10/11/2007  06:36 AM           576 Stain.f1s
              10/11/2007  06:35 AM           614 Wrinkles.f1s
                         5 File(s)      3,028 bytes
              Skin\Image Doctor 2\Settings\DustAndScratchRemover
              10/11/2007  06:11 AM           888 Dust.f1s
              10/11/2007  06:04 AM           858 Factory Default.f1s
              10/11/2007  06:10 AM         1,004 Remove object - large features.f1s
              10/11/2007  06:10 AM           772 Remove object - small features.f1s
              10/11/2007  06:05 AM           888 Scratch on complex background.f1s
              10/11/2007  06:07 AM           884 Scratch on simple background.f1s
              10/11/2007  06:07 AM           854 Small scratch.f1s
                         7 File(s)      6,148 bytes
              Skin\Image Doctor 2\Settings\JPEGRepair
              10/10/2007  01:00 PM           644 Add grain.f1s
              10/10/2007  01:00 PM           658 Factory Default.f1s
              10/10/2007  01:00 PM           656 Remove Texture.f1s
              10/10/2007  01:00 PM           682 Repair blocks, no smoothing.f1s
              10/10/2007  01:01 PM           692 Repair JPEG! high quality setting.f1s
              10/10/2007  01:01 PM           694 Repair JPEG! low quality setting.f1s
              10/10/2007  01:01 PM           700 Repair JPEG! medium quality setting.f1s
                         7 File(s)      4,726 bytes
              Skin\Image Doctor 2\Settings\SkinSoftener
              10/10/2007  11:27 AM           552 Factory Default.f1s
              10/10/2007  11:27 AM           562 Soften deep wrinkles.f1s
              10/10/2007  11:27 AM           564 Soften light wrinkles.f1s
              10/10/2007  11:28 AM           554 Soften oily skin.f1s
                         4 File(s)      2,232 bytes
              Skin\Image Doctor 2\Settings\SmartFill
              10/11/2007  06:23 AM         1,218 Auto - complex background.f1s
              10/11/2007  06:23 AM         1,178 Auto - large features.f1s
              10/11/2007  06:24 AM         1,214 Auto - simple background.f1s
              10/11/2007  06:25 AM         1,208 Auto - small features.f1s
              10/11/2007  06:24 AM         1,190 Factory Default.f1s
              10/11/2007  06:25 AM         1,192 Manual - complex background.f1s
              10/11/2007  06:25 AM         1,182 Manual - large features.f1s
              10/11/2007  06:25 AM         1,188 Manual - simple background.f1s
              10/11/2007  06:26 AM         1,182 Manual - small features.f1s
                         9 File(s)     10,752 bytes
              Skin\Snap Art 3
              04/11/2012  07:33 AM       419,328 Alien Skin Snap Art 3 Photoshop x64.8bf
                         1 File(s)    419,328 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\DAZ 3
              D
              09/03/2012  08:23 AM<DIR>      .
              09/03/2012  08:23 AM<DIR>      ..
              08/14/2012  04:19 PM       103,424 PsDzBridge.8li
              08/14/2012  04:19 PM       912,384 PsDzBridge.pdb
              08/14/2012  04:20 PM       105,472 PsDzUpdateScene.8BA
              08/14/2012  04:20 PM       920,576 PsDzUpdateScene.pdb
                         4 File(s)  2,041,856 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Filte
              rs
              09/03/2012  10:17 AM<DIR>      .
              09/03/2012  10:17 AM<DIR>      ..
              02/26/2012  09:32 AM       134,048 xNormal_PSFilter_Dilation_x64.8BF
              02/26/2012  09:32 AM       170,432 xNormal_PSFilter_HM2NM_x64.8BF
              02/26/2012  09:32 AM       166,856 xNormal_PSFilter_HM2OM_x64.8BF
              02/26/2012  09:32 AM       163,776 xNormal_PSFilter_NM2CM_x64.8BF
              02/26/2012  09:31 AM       139,184 xNormal_PSFilter_NMNormalizer_x64.8BF
                         5 File(s)    774,296 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Measu
              rements
              09/03/2012  08:03 AM<DIR>      .
              09/03/2012  08:03 AM<DIR>      ..
              04/07/2011  04:07 AM        88,232 MeasurementCore.8ME
                         1 File(s)     88,232 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Panel
              s
              09/04/2012  10:40 AM<DIR>      Gallery Wrapper
                         0 File(s)          0 bytes
              s\Gallery Wrapper
              09/04/2012  10:40 AM<DIR>      content
                         0 File(s)          0 bytes
              s\Gallery Wrapper\content
              07/20/2009  12:29 PM           343 alienskinsoftware.html
              07/24/2009  07:56 AM        41,098 Gallery Wrapper.jsx
              09/22/2010  10:01 AM       766,440 Gallery Wrapper.swf
              07/22/2009  11:37 AM         1,336 Gallery WrapperNormal.png
              07/22/2009  11:40 AM         3,501 Gallery WrapperRollover.png
              07/23/2009  07:59 AM        26,025 Help.pdf
              07/21/2009  08:34 AM           374 index.html
                         7 File(s)    839,117 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Postw
              orkShop
              03/31/2011  01:52 AM     2,255,360 PostworkShop.8bf
                         1 File(s)  2,255,360 bytes
              Directory of C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\topaz
              adjust5_x64
              09/03/2012  10:27 AM<DIR>      .
              09/03/2012  10:27 AM<DIR>      ..
              12/20/2011  09:39 AM       181,760 tladjust5ps_x64.8bf
                         1 File(s)    181,760 bytes
              Total Files Listed:
                       115 File(s) 80,246,537 bytes
                        68 Dir(s)  82,709,741,568 bytes free
              • 4. Re: Runtime Error! R6034
                RAMWolff44 Level 1
                WOW... I do as I'm told and then forgotten.  Thanks!
                Anyway, I went through the plugins folder and removed them all, restarted the program until I added one that caused the Runtime Error to pop up again.  It was one in a folder called Measurements.  Not sure what it goes to but yes, it was for CS5 and has an .8ME file extension on it.  So issue is solved....
                • 5. Re: Runtime Error! R6034
                  I'm sorry, I somehow missed your response.  But it's a bit forward to complain that your free help was late, no?
                  Please note that I had already given you the information to solve your problem back in post number 1, a scant 12 minutes after you asked:
                  I could almost be forgiven for asking "what have you done for me lately?"
                  -Noel
                  • 6. Re: Runtime Error! R6034
                    RAMWolff44 Level 1
                    Thanks for the help!
                    • 7. Re: Runtime Error! R6034
                      No worries, I was being a bit cheeky.  You're welcome.
                      -Noel
