4 Replies Latest reply on Sep 7, 2012 9:52 AM by Evan_victruss
    PDF/A View Mode
    Evan_victruss Level 1
      Acrobat Pro 9
      Win 7 Pro
      Domain user account
           -administrator privileges
      We deal with PDF/A mode from another part of the company, and often need to add more annotations to documents.
      The setting View documents in PDF/A mode - Never is a perfect solution for us.
      The setting continually reverts to "only for PDF/A documents".
      Any one know what can be done to stop it reverting? (I have tried changing it in the registery as well, it still switched itself back)
      Thanks in advance.
        • 1. Re: PDF/A View Mode
          Bill@VT Level 7
          Are you saying the PDFs are in PDF/A mode. You can turn that off, which is needed if you want to add annotations. While the document is in that mode, it can not be changed. Generally this is not a viewing option, but the way the PDF was created and it would have to be changed. For conversion to PDF/A, you can use preflight. I am not sure about conversion back.
          • 2. Re: PDF/A View Mode
            The PDF's are already PDF/A..dont want to do any conversion, already know how to do that...  it's a setting in acrobat pro 9 that is switching back on me. i want it to stay at never.Capture.PNG
            BTW, Thank you for the reply
            • 3. Re: PDF/A View Mode
              Bill@VT Level 7
              I would think that the never would stay checked. There are others here that deal with PDF/A files and hopefully they will drop by. I think you have given enough info for some of them to give a reasonable answer. Good luck.
              • 4. Re: PDF/A View Mode
                Update.. it seems to do the switch back when opening a PDF from outlook..
                May be at other times as well.. it happens often and i just turn it off again.. annoying..
                Ideas?
