6 Replies Latest reply on Oct 26, 2009 11:59 AM by Playazls
    SWFLoader Flashpaper
    Playazls Level 1
      if(printVB.getChildByName("fpSendfax")){printVB.re moveChild(printVB.getChildByName("fpSendfax"));}
      var ldr:SWFLoader = new SWFLoader();
      ldr.name = "fpSendfax";
      var url:String = "flash/flashpaperloader.swf";
      ldr.load(url);
      ldr.addEventListener(Event.COMPLETE, function(event:Event):void {printVB.addChild(ldr)});
      I use the above code to load a flashpaper which is generated by coldfusion cfc. When I load the movie for the first time it works great.
      If i reload another movie I get a black screen and the flashpaper loads in the background.
      Here are the examples.
      Good image:
      Image when loaded properly (1st time)
      Bad image:
      Image with black screen (2st time +)
        • 1. Re: SWFLoader Flashpaper
          Novian
          Hi Ryan,
          Did you figure out a solution for this problem? I'm experiencing the same thing.
          Thanks.
          Novian
          • 2. Re: SWFLoader Flashpaper
            Juls1980
            Hi
            I'm having this same problem... did either of you find a solution??
            Juls
            • 3. Re: SWFLoader Flashpaper
              Flex harUI Adobe Employee
              Not sure what you mean by "reload"  Are you using the same SWFLoader instance or a new one?
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
              • 4. Re: SWFLoader Flashpaper
                Juls1980 Level 1
                I have tab navigator with a SWFloader on two of the tabs (ie two SWFLoaders), the first tab shows the Flash paper doc fine but when I view the second one which is showing a different flash paper doc it has a black screen on the SWFLoader and the flash paper loads in the background (it looks like it's completely outside of the SWFLoader).
                At first I thought it was possibly the 2nd document but if I switch the order of the documents around its still the 2nd SWFLoader that doesn't show the document correctly.
                Thanks for your help :-)
                • 5. Re: SWFLoader Flashpaper
                  Could be a bug in the player.  FlashPaper runs in AS2/AVM1 and there might still be some kinks with how it interacts with AS3/AVM2.
                  However, it is also known that SWFLoaders in TabNavigators can get sized incorrectly due to fact that when the TabNavigator asks for their size, the SWFLoader on page 2 may not have its content yet and thus reports a 0 size and the TabNavigator might not ask for size again.
                  I would run a test where you cut the screen in half and use two SWFLoaders to load the two pages so everything is visible at the same time.  Set the width/height of the SWFLoaders so they don't get asked for their size.
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 6. Re: SWFLoader Flashpaper
                    Playazls Level 1
                    Sorry for the VERY late response. I was able to resolve this issue by removing previous instance from stage then create a new SWFLoader();
