3 Replies Latest reply on Dec 3, 2016 12:01 PM by ZebraTyme
    add page numbers via script
    hilukasz Level 1
      I want to try to add page numbers to artboard based on position of selected text. I saw someone had made a script similar to this, but I need to do it based on selected text. Here is my solution, but for some reason it is not adding it based on artboard coordinates. I ran into this a while ago, and setting the rule to artboards fixed it, here it does not seem to have same effect.
      #target illustrator
      // global variables
      // Set up varaibles
      var pageNumber = app.activeDocument.artboards.getActiveArtboardIndex() + 1,
          doc = app.activeDocument;
      //make sure only 1 item is selected
      if(selectedItems.length > 1 || selectedItems.length < 1) {
          alert('please select only one item'}
      else {
          var selectionTopPosition = doc.selection[0].top,
              selectionLeftPosition = doc.selection[0].left;
          doc.selection[0].remove();
          doc.selection = null;
          //remove selection
          //alert(selectionLeftPosition+" "+selectionTopPosition);
      //create page numbers layer
      var pageNumbersLayer = doc.layers.add();
      pageNumbersLayer.name = "page numbers";
      var pageNumbersLayerGroup = pageNumbersLayer.groupItems.add();
      // main loop
      //loop through artboards
      for(i = 0; i < app.activeDocument.artboards.length; i++){
          app.coordinateSystem = CoordinateSystem.ARTBOARDCOORDINATESYSTEM;
          doc.artboards.setActiveArtboardIndex(i);
          alert('active artboard is '+i);
          var pageNumber = doc.artboards.getActiveArtboardIndex() + 1;
          var pageCount = i + 1;
          var textRef = pageNumbersLayerGroup.textFrames.add();
          textRef.contents = pageCount.toString();
          textRef.top = selectionTopPosition;
          textRef.left = selectionLeftPosition;
          pageCount++;
