5 Replies Latest reply on Sep 6, 2012 8:48 AM by rush_pawan
    Remove Default <br> tag in RichText
    CalyDev
      When I set the 'removeSingleParagraphContainer' property to true, the RichText editor inserts a <br> tag even if there is no text.  Is there a way to stop this?
        • 1. Re: Remove Default <br> tag in RichText
          smurfsky101
          Yup. Try adding this property
          'singleParagraphContainerReplacement' - 'div'
          That should use a div tag instead of a line break
          • 2. Re: Remove Default <br> tag in RichText
            CalyDev Level 1
            I've actually tried 'singleParagraphContainerReplacement' but for some reason it doesn't do anything.  I'm running CQ 5.4 btw.
            Here's the code:
            itemId                            : 'credit',
            xtype                             : 'richtext',
            fieldLabel                        : 'Photo Credit',
            width                             : '95%',
            height                            : 100,
            removeSingleParagraphContainer     : true,
            singleParagraphContainerReplacement: 'div',
            • 3. Re: Remove Default <br> tag in RichText
              smurfsky101 Level 1
              could you post the exact contents of dialog.xml?
              • 4. Re: Remove Default <br> tag in RichText
                CalyDev Level 1
                <?xml version="1.0" encoding="UTF-8"?>
                <jcr:root xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0"
                    jcr:primaryType="cq:TabPanel"
                    activeTab="0"
                    helpPath="en/cq/current/wcm/default_components.html#Text Image"
                    xtype="tabpanel">
                    <items jcr:primaryType="cq:WidgetCollection">
                        <tab2
                            jcr:primaryType="cq:Widget"
                            cropParameter="./imageCrop"
                            ddGroups="[media]"
                            fileNameParameter="./fileName"
                            fileReferenceParameter="./fileReference"
                            mapParameter="./imageMap"
                            name="./file"
                            requestSuffix=".img.png"
                            rotateParameter="./imageRotate"
                            sizeLimit="100"
                            title="Image"
                            uploadUrl="/tmp/upload/*"
                            xtype="smarterimage"/>
                       <tab3
                            prefix="."
                            title="Advanced Image Properties"
                            xtype="ImageProperties"/>
                        <tab4
                            xtype="configcomponentstyles"/>
                    </items>
                </jcr:root>
                The portion that actually declares the RichText fields is in a separate js file here:
                CN.Author.widgets.ImageProperties = CQ.Ext.extend(CQ.Ext.Panel, {
                    prefix             : './image',
                    renditionOptions   : [],
                    rendition          : null,
                    selectedRendition  : null,
                    componentPath      : null,
                    ORIGINAL           : "[0:0]",
                    USE_SIZE           : "[-1:-1]",
                    constructor: function(config) {
                        this.CN   = this.CN || {};
                        config    = config || {};
                        CN.Author.widgets.ImageProperties.superclass.constructor.call(this, config);
                    initComponent: function() {
                        var
                            me = this,
                            dialog,
                            tabPanel,
                             * Populates the panel's form fields.
                             * @param {Object} data An object containing metadata
                             * @private
                            populate = function(data) {
                                var
                                    fieldPanel = this.getComponent('imageProperties_panel');
                                fieldPanel.getComponent('imageProperties_title').setValue(data['dc:title']);
                                fieldPanel.getComponent('imageProperties_alt').setValue(data['dc:title']);
                                fieldPanel.getComponent('imageProperties_credit').setValue(data['dc:title']);
                                fieldPanel.getComponent('imageProperties_desc').setValue(data['dc:description']);
                             * Checkbox handler, which is called with every check.
                             * @param {CQ.Ext.form.Checkbox} checkbox The checkbox that has been checked/unchecked
                             * @param {Boolean} isChecked True if checked
                             * @private
                            checkHandler = function(checkbox, isChecked) {
                                if (isChecked) {
                                    populate.call(this, this.CN.imageMetaData);
                            damBox = new CQ.Ext.form.Checkbox({
                                disabled       : true,
                                fieldLabel     : 'Use DAM Meta'
                            saveRendition = new CQ.form.Selection({
                                fieldLabel     : 'Save this new rendition',
                                type           : "checkbox"
                            rendition = new CQ.form.Selection({
                                fieldLabel     : "Rendition:",
                                type           : "select",
                                listeners      : {
                                    selectionchanged     : function() {
                                        var
                                            newValue  = this.getValue(),
                                            sizeField = me.fieldPanel.get('imageProperties_size');
                                        if (newValue === me.ORIGINAL) {
                                             sizeField.reset();
                                             sizeField.setDisabled(true);
                                        else if (newValue === me.USE_SIZE) {
                                            sizeField.setDisabled(false);
                                            sizeField.reset();
                                        else {
                                            sizeField.reset();
                                    loadContent         : function(field,record,path){
                                        me.selectedRendition = record.data.rendition;
                            fieldPanel   = new CQ.Ext.Panel({
                                frame        : false,
                                border       : false,
                                layout       : 'form',
                                autoScroll   : true,
                                autoHeight   : true,
                                itemId       : 'imageProperties_panel',
                                cls          : 'imagePropertiesPanel',
                                items        : [
                                        itemId                            : 'imageProperties_title',
                                        name                                  : this.prefix + '/jcr:title',
                                        xtype                             : 'textfield',
                                        fieldLabel                        : 'Title',
                                        width                             : '95%'
                                        itemId                            : 'imageProperties_alt',
                                        name                              : this.prefix + '/alt',
                                        fieldLabel                        : 'Alt Text',
                                        width                             : '95%'
                                        itemId                            : 'imageProperties_link',
                                        name                              : this.prefix + '/linkURL',
                                        xtype                             : 'pathfield',
                                        fieldLabel                        : 'Link to',
                                        parBrowse                         : true,
                                        width                             : '95%'
                                        itemId                            : 'imageProperties_credit',
                                        name                              : this.prefix + '/photoCredit',
                                        xtype                             : 'richtext',
                                        width                             : '95%',
                                        height                            : 100,
                                        rtePlugins                        : {
                                            misctools: {
                                                features: ['specialchars', 'sourceedit'],
                                                specialCharsConfig: {
                                                    chars: {
                                                        "copyright": {
                                                            "entity": "&copy;"
                                                        "degree": {
                                                            "entity": "&deg;"
                                                        "elipses": {
                                                            "entity": "&#133;"
                                                        "latin": {
                                                            "rangeEnd": "255",
                                                            "rangeStart": "192"
                                                        "leftanglequote": {
                                                            "entity": "&laquo;"
                                                        "misc": {
                                                            "rangeEnd": "152",
                                                            "rangeStart": "145"
                                                        "morefractions": {
                                                            "rangeEnd": "8543",
                                                            "rangeStart": "8531"
                                                        "percentage": {
                                                            "rangeEnd": "47",
                                                            "rangeStart": "32"
                                                        "register": {
                                                            "entity": "&reg;"
                                                        "rightpointquote": {
                                                            "entity": "&raquo;"
                                                        "trademark": {
                                                            "entity": "&#153;"
                                                        "vulgarfractions": {
                                                            "rangeEnd": "190",
                                                            "rangeStart": "188"
                                        itemId                            : 'imageProperties_desc',
                                        name                              : this.prefix + '/jcr:description',
                                        xtype                             : 'richtext',
                                        fieldLabel                        : 'Caption',
                                        width                             : '95%',
                                        height                            : 100,
                                        rtePlugins                        : {
                                            misctools: {
                                                    chars: {
                                                        "copyright": {
                                                            "entity": "&copy;"
                                                        "degree": {
                                                            "entity": "&deg;"
                                                        "elipses": {
                                                            "entity": "&#133;"
                                                        "latin": {
                                                            "rangeEnd": "255",
                                                            "rangeStart": "192"
                                                        "leftanglequote": {
                                                            "entity": "&laquo;"
                                                        "misc": {
                                                            "rangeEnd": "152",
                                                            "rangeStart": "145"
                                                        "morefractions": {
                                                            "rangeEnd": "8543",
                                                        "percentage": {
                                                            "rangeEnd": "47",
                                                            "rangeStart": "32"
                                                        "register": {
                                                            "entity": "&reg;"
                                                            "entity": "&raquo;"
                                                        "trademark": {
                                                            "entity": "&#153;"
                                                            "rangeEnd": "190",
                                                            "rangeStart": "188"
                                        itemId            : 'imageProperties_size',
                                        widthParameter    : this.prefix + '/width',
                                        heightParameter   : this.prefix + '/height',
                                        xtype             : 'sizefield',
                                        fieldLabel        : 'Size',
                                        disabled          : true
                                    damBox,
                                    rendition,
                                    saveRendition
                        CN.Author.widgets.ImageProperties.superclass.initComponent.call(this);
                        this.rendition     = rendition;
                        this.fieldPanel    = fieldPanel;
                        this.add(fieldPanel);
                        this.CN.damBox     = damBox;
                        this.CN.damBox.on('check', checkHandler, this);
                        dialog             = this.findParentByType("dialog");
                        tabPanel           = this.ownerCt;
                        if (dialog) {
                            dialog.on("loadcontent", function() {
                                 this.onLoadContent(dialog.path);
                            }, this);
                        if(tabPanel) {
                            tabPanel.on("tabchange",function(tabPanel, tab) {
                                if(tab.xtype === 'ImageProperties') {
                                     this.onActivate(tab);
                            }, this);
                     * Overrides CQ.Ext.Panel.onRender.  Find the smarterimage component and register a callback onto
                     * the CN.customEvents.DAM.response event.
                    onRender: function (ct, pos) {
                        var
                            ownerCt          = this.ownerCt,
                            items            = null,
                            imgCmpt          = null,
                            i                = 0,
                            len              = 0;
                        if (typeof ownerCt !== "undefined") {
                            items = ownerCt.items.items;
                            len   = items.length;
                            for (i = 0; i < len; i++) {
                                imgCmpt = (imgCmpt === null) ? ((items[i].xtype === "smarterimage") ? items[i] : null) : imgCmpt;
                            if (imgCmpt !== null) {
                                // Let's know about all the images loading on the smarterimage widget
                                imgCmpt.on('CN.customEvents.DAM.response', this.onDamResponse, this);
                        CN.Author.widgets.ImageProperties.superclass.onRender.call(this, ct, pos);
                    onLoadContent: function(path) {
                        this.componentPath = path;
                    onActivate: function(tab) {
                        var
                            sizes,
                            rendition,
                            option;
                        if (this.renditionOptions.length === 0) {
                            sizes = CN.Author.Util.getConfiguration("dam/sizes");
                            this.renditionOptions.push({'text':'-Use size field-','value':this.USE_SIZE});
                            this.renditionOptions.push({'text':'Original Size','value':this.ORIGINAL});
                            for(rendition in sizes) {
                                if(sizes.hasOwnProperty(rendition)){
                                    option = {};
                                    if(!rendition.match(/jcr/g)) {
                                        option['text']  = rendition;
                                        option['value'] = sizes[rendition];
                                        this.renditionOptions.push(option);
                        if (this.renditionOptions.length > 0) {
                            this.rendition.setOptions(this.renditionOptions);
                            this.rendition.setValue(this.selectedRendition);
                     * CN.customEvents.DAM.response handler.
                     * @param {Object} metaData The metadata object from the HTTP response of smarterimage
                     * @public
                    onDamResponse: function(metaData) {
                        this.CN.damBox.enable();
                        this.CN.imageMetaData = metaData;
                CQ.Ext.reg('ImageProperties', CN.Author.widgets.ImageProperties);
                • 5. Re: Remove Default <br> tag in RichText
                  rush_pawan Level 4
                  I also tried using same configuration to replace <br> tag but its not working for me as well.
                  Pawan
