4 Replies Latest reply on Sep 6, 2012 10:35 PM by Bill joy
    Applescript to Javascript
    Bill joy
      I have an Applescript that I need to convert it into  Javascript.
      To create Indesign instancs in applescript i use
      tell application "Adobe InDesign CS5" statement
      How create Indesign instancs in JavaScript
      or what is equivelent statement of ( tell application "Adobe InDesign CS5" ) in Java Script
      Using COM I create Indesign Instance like
      #include "indesign.h"
      INDESIGN::_Application oApplication;
      if(oApplication.CreateDispatch(L"InDesign.Application") ==0)
          AfxMessageBox(L"Dispatch is not created");
      How create Indesign instance using java Script ?
      Thanks.
        • 1. Re: Applescript to Javascript
          MrTIFF Level 3
          In JavaScript (ExtendScript), "app" (InDesign) is always available.  See the Sample scripts in your InDesign Scripts Panel folder.
          • 2. Re: Applescript to Javascript
            Bill joy Level 1
            Thanks Stephen0218 for reply
            Yes
            "app" (InDesign) is always available In JavaScript (ExtendScript).
            These script run sucessfully when i put these script in C:\Program Files\Adobe\Adobe InDesign CS5.5\Scripts
            and to run these script use Scripts panel (choose Window > Utilities > Scripts), then double-click the script name in the Scripts panel in indesign application.But In this case first i start indesign application and then choose Window > Utilities > Scripts then double-click the script name in the Scripts panel.
            If I run (or debug) these script in any java script editor like ExtendScript ToolKit 3.6 then it give error undefined "app".
            But I want to creat such java script.When I run or (debug) my JavaScript in any javaScript tool like ExtendScript ToolKit 3.6 then Indesign application should start, like in Apple Script when i run my apple script
            tell application "Adobe InDesign CS5.5"
            set myDocument to make document with properties
            end tell
            in apple script editor, Indesign Application start(create) sucessfully.
            So I need to creat application object (or instance) say "app".
            • 3. Re: Applescript to Javascript
              CarlosCanto Adobe Community Professional & MVP
              you were given an answer in your previous (duplicate) thread
              http://forums.adobe.com/thread/1061428?tstart=0
              follow that or, in the ESTK select InDesign as your target application. Click on the down arrow you see next to ExtendScript Toolkit CS4.
              • 4. Re: Applescript to Javascript
                Bill joy Level 1
                Thanks CarlosCanto for reply
                I am a new developer and want to create indesign application.
                First I explane you, What i want to do?
                I want to create an Indesign application for both mac and window os.
                First I use COM and crate indesign application
                     // Dispatch is not created;
                But COM is not supported on mac so i want to use JavaScript
                I am using Qt to develop my application and i want to create a java script .
                When I run my JavaScript on window  then Indesign application should start .
                In my post I write about ExtendScript ToolKit 3.6, but i do not want to use this tool.
                For example on mac in Apple Script when i run my apple script
                end tell
                in apple script editor which is inbuild with mac, Indesign Application start(create) sucessfully.
                I want to use javaScript editor inbuild with window.
                Like in applescript there is no need to put the script in  /Users/<username>/Library/Preferences
                /Adobe InDesign/Version 7.5/<locale>/Scripts
                Simply when i run apple script application create. I want to such using java script.
                I do not want to put my script C:\Documents and Settings\<username>\Application Data
                \Adobe\InDesign\Version 7.0\<locale>\Scripts
                to start indesign application
                http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/devnet/indesign/cs55-docs/In DesignScripting/InDesign-ScriptingTutorial.pdf
                Establish communication with the InDesign application object:
                AppleScript :   tell application "Adobe InDesign CS5"
                VBScript     :    Set myInDesign = CreateObject("InDesign.Application")
                JavaScript   :    Refer to the application as app.
                plz give a simple java script (.js) file example which create Indesign Application (instance) , when i run my java script in any java script editor, No need to put script /Users/<username>/Library/Preferences/Adobe InDesign/Version 7.5/<locale>/Scripts and run script after run indesign.
                Like in VB to create indesign object we use CreateObject("InDesign.Application"). In javascript how create object of InDesign Application.
