A new version of Muse is available
Corey@Adobe Sep 5, 2012 11:21 AMThe next time you launch Muse you will be prompted to update your installed version. This latest update includes major fixes for improved application stability. To ensure your app is running smoothly, install the update today. The latest Muse update includes the following bug fixes:
Build 2.1.974
FTP Upload
- The new "Upload to FTP Host" feature would generate errors if the target site was not located at the root of the hosting provider and the full path to upload was not provided. FTP Upload now works correctly without requiring the full path be entered.
- Fixed bug that would generate errors if the target directory included a trailing slash "/".
- Fixed bug where FTP upload could fail when uploading to Mac or Linux based servers.
Text
- Fixed a bug that resulted in a crash shortly after launch for some users who are running Windows XP.
- Fixed a bug on that could result in a crash when using the Russian input method (or those for other languages) on the Mac.
Widgets
- Fixed a bug where an outer glow effect would be applied incorrectly when applied to the hero image in a slideshow if the image was smaller than the hero image frame.
- Fixed a bug that could result in corrupt menus as a result of undo and/or redo of actions involving the adding or deleting of pages. This corruption was resulting in errors/crashes when attempting to alter the page organization in Plan view.
- Clicking on the next/previous button or a thumbnail in a Slideshow or Composition while in the browser now halts autoplay.
- An Accordion widget set to export with all panels initially closed was incorrectly drawing one of the accordion tabs in the active state.
- Fixed a bug with the handling of text attributes across states that could prevent text attributes from being properly set in states.
- Fixed a bug where slideshow and composition widget thumbnails would fail to work in preview and browser if particular combinations of attributes were set across states.
- Fixed a bug where the submit button in forms would draw incorrectly when previewed/exported if a System font was applied.
Other
- The Publish Complete confirmation dialog always referred to "Your temporary site…" regardless of whether the site published to was a temporary site or a paid site. The text has been corrected.
- Fixed issue where graphic attributes were incorrectly exported in cases where rasterized images were shared between multiple objects.
- Fixed a bug to allow placement of an Adobe Edge .oam file that either has non-ASCII characters in its name, or which was created while Edge was running on a non-English operating system (e.g. Mac OSX in French). This feature has been changed to use a different library that doesn't have this limitation.
- Fixed a bug that resulted in "http://" sometimes being incorrectly added to links entered in the Hyperlink control (i.e. mailto:foo@bar.org, tel:2065551212, etc.).
- Corrected date format used in generated sitemap.xml file.
Information about bug fixes and features included in updates to Adobe Muse can be found in the Adobe Muse Release Notes.
Best regards,
Corey
