3 Replies Latest reply on Sep 8, 2012 12:51 AM by Jon-M-Spear
    GTX 680: Screen dips to black
    Jon-M-Spear Level 4
      Does anyone have a similar exsperience with the GTX 680, 4Gb card:
      1. When scrubbing, the image in the composition windows will frequently dip to black  momentarily - leaving only the layer wireframe placeholders - as though it's having difficulty keeping up with the demands made upon it.
      2.  When adding/removing nodes to a mask using the pen tool, the image dips to black for a second or so after each node is added/deleted - leaving visible only the mask path.
      This was not a feature of the recently removed Quadro FX3800, 1GB card.
      I have tried various preview modes - but to no avail.
      It's irritating to say the lease!
      Thanks.
        • 1. Re: GTX 680: Screen dips to black
          Dave LaRonde Level 6
          I presume you're well aware of the Live Update switch at the top of the timeline.  And that you have a fully-updated NVidia driver for your card.
          • 2. Re: GTX 680: Screen dips to black
            Jon-M-Spear Level 4
            Yes I am, Dave, thanks, and no it's not that.
            Preview mode is set to adaptive resolution and the timeline updates as I scrub, but intermittently the content across all layers will cut out visually for a second or so - showing only the coloured inverted "V" image place markers.  The image returns the moment I stop scrubbing.
            I would expect the image to pixellate to a lower resolution whilst scrubbing - if it can't update fast enough - but it doesn't appear to do so.
            Also, this doesn't explain the behaviour when using the pen tool (oultined above)....
            As I said, this was not a Quadro FX3800 issue.
            As an aside, In Adobe Forums, the text entry panel on my PC has started to display in Times Roman all of a sudden, but changes to the correct display font when posted. It's fine on my Laptop and iPad.
            Am I having another senior moment?
            • 3. Re: GTX 680: Screen dips to black
              Jon-M-Spear Level 4
              I can only put this down to the vagaries of the GTX680.
              When I preview out to a third monitor via a BM intensity, I have continuity of output on the third monitor whilst scrubbing.
              Conclusion:  I'm not sure of the technicalities of memory flushing, but superficially, it appears that the 1Gb  FX3800 is more capable than the 4Gb GTX 680.
