4 Replies Latest reply on Sep 6, 2012 12:59 PM by jason itb
    Compiling with compc.exe works but fails with compc.jar
    jason itb
      Using flex_sdk_4.1.0.16076A and compiled with compc.exe using following command line and works.
      compc +flexlib="%FLEX_HOME%\frameworks" -output=target/model.swc -load-config=generated/lib2ant-flex-config.xml -source-path=flex_src,generated/flex/src,"%FLEX_HOME%/frameworks/locale/en_US" -library-path="%FLEX_HOME%/frameworks/libs/datavisualization.swc","%FLEX_HOME%/frameworks /libs/flash-integration.swc","%FLEX_HOME%/frameworks/libs/utilities.swc","%FLEX_HOME%/fram eworks/locale/en_US","C:/repos/itbrepo/trunk/clear4/target/clear4.swc" -external-library-path="%FLEX_HOME%/frameworks/libs/player/10.0/playerglobal.swc","%FLEX_ HOME%/frameworks/libs/textLayout.swc","%FLEX_HOME%/frameworks/libs/osmf.swc","%FLEX_HOME%/ frameworks/libs/framework.swc","%FLEX_HOME%/frameworks/libs/spark.swc","%FLEX_HOME%/framew orks/libs/sparkskins.swc","%FLEX_HOME%/frameworks/libs/rpc.swc"
      output:
      Loading configuration file C:\repos\itbrepo\trunk\model\generated\lib2ant-flex-config.xml
      C:\repos\itbrepo\trunk\model\target\model.swc (540634 bytes)
      Using flex_sdk_4.1.0.16076A and compiled with compc.jar using following command line and fails.
      java -jar "%FLEX_HOME%\lib\compc.jar" +flexlib="%FLEX_HOME%\frameworks" -output=target/model.swc -load-config=generated/lib2ant-flex-config.xml -source-path=flex_src,generated/flex/src,"%FLEX_HOME%/frameworks/locale/en_US" -library-path="%FLEX_HOME%/frameworks/libs/datavisualization.swc","%FLEX_HOME%/frameworks /libs/flash-integration.swc","%FLEX_HOME%/frameworks/libs/utilities.swc","%FLEX_HOME%/fram eworks/locale/en_US","C:/repos/itbrepo/trunk/clear4/target/clear4.swc" -external-library-path="%FLEX_HOME%/frameworks/libs/player/10.0/playerglobal.swc","%FLEX_ HOME%/frameworks/libs/textLayout.swc","%FLEX_HOME%/frameworks/libs/osmf.swc","%FLEX_HOME%/ frameworks/libs/framework.swc","%FLEX_HOME%/frameworks/libs/spark.swc","%FLEX_HOME%/framew orks/libs/sparkskins.swc","%FLEX_HOME%/frameworks/libs/rpc.swc"
      output:
      Error: null
      The command line args are all the same and from what I understand compc.exe calls compc.jar internally anyway.  Can someone point me in the right direction?  I tried all sorts of options to output more info but none worked.
        • 1. Re: Compiling with compc.exe works but fails with compc.jar
          Flex harUI Adobe Employee
          In the bin folder next to compc.exe is a unix shellscript call compc.  Open it in a text editor.  It might be setting up some JVM params you need.
          • 2. Re: Compiling with compc.exe works but fails with compc.jar
            jason itb Level 1
            Thanks for the reply.  I looked in there and have not noticed anything as I have set FLEX_HOME in my env vars.  I also tried the jvm args in the shell script without any success.  Btw I'm using Windows 7 so I am using compc.exe instead of the shell script but that was a good place to check.  I want to do the same check on compc.exe to see if there is anything getting set there as well... Is there a place where I can get the source code for compc.exe?  Thanks.
            compc shell source code below:
            #!/bin/sh
            ##  ADOBE SYSTEMS INCORPORATED
            ##  Copyright 2007 Adobe Systems Incorporated
            ##  All Rights Reserved.
            ##  NOTICE: Adobe permits you to use, modify, and distribute this file
            ##  in accordance with the terms of the license agreement accompanying it.
            # compc launch script for unix.  On windows, compc.exe is used and
            # java settings are managed in jvm.config in this directory.
            case `uname` in
                                CYGWIN*)
                                          OS="Windows"
                                          OS=Unix
            esac
            D32=''
            if [ $OS = "Windows" ]; then
                      # set FLEX_HOME relative to compc if not set
                      test "$FLEX_HOME" = "" && {
                      FLEX_HOME=`dirname $0`/..
                          FLEX_HOME=`cygpath -m $FLEX_HOME`
            elif [ $OS = "Unix" ]; then
                      FLEX_HOME=`dirname "$0"`/..
                      check64="`java -version 2>&1 | grep -i 64-Bit`"
                      isOSX="`uname | grep -i Darwin`"
                      if [ "$isOSX" != "" -a "$HOSTTYPE" = "x86_64" -a "$check64" != "" ]; then
                                D32='-d32'
                      fi
            fi
            # don't use $FLEX_HOME in this variable because it may contain spaces,
            # instead put it on the java args directly, with double-quotes around it
            VMARGS="-Xmx384m -Dsun.io.useCanonCaches=false  "
            java $VMARGS $D32 $SETUP_SH_VMARGS -jar "$FLEX_HOME/lib/compc.jar" +flexlib="$FLEX_HOME/frameworks" "$@"
            • 3. Re: Compiling with compc.exe works but fails with compc.jar
              I’m not sure the source for the .exe if publicly available.  I’ll look again, but I didn’t find it on the first search.  Another option you have is to look at how compc is used in the ant scripts.
              • 4. Re: Compiling with compc.exe works but fails with compc.jar
                jason itb Level 1
                Ok thanks for the help.  Will look at some ant scripts, but if you can find the source for compc.exe that would be awesome.
