1. Re: Adding a Kerning amount to the space between a digit and a quotation mark in GREP
P Spier Sep 6, 2012 8:08 AM (in response to iBabs2)I think you actually understand the problem, since it's exactly what you said -- you need to apply tracking to the pair (which I think you probably want to do as a character style that you can apply as a GREP style).
Should work if you change the query to \d\x{0022} I suspect.
2. Re: Adding a Kerning amount to the space between a digit and a quotation mark in GREP
[Jongware] Sep 6, 2012 8:37 AM (in response to P Spier)Almost right.
No, you cannot set kerning in a character style (easily -- I think there was a trick to work around it, but I cannot recall what it was). Yep, you must apply tracking with the GREP style to part of the string. If you set the tracking for both characters, it will also be applied to the second one, making this wider as well.
Set your GREP to this to prevent it:
\d(?=~")
(where the code ~" is equal to 'straight double quotes only').
3. Re: Adding a Kerning amount to the space between a digit and a quotation mark in GREP
iBabs2 Sep 6, 2012 9:11 AM (in response to [Jongware])HI Guys!
That was it.. I did know the problem but couldn't find the magical code to make it wortk...This did it Jongware.
Thanks so much!!!!
babs
4. Re: Adding a Kerning amount to the space between a digit and a quotation mark in GREP
johnmd13 Sep 6, 2012 3:52 PM (in response to iBabs2)Fortuitous you all posted this just today. I'm trying to change kerning between a digit and a letter, which I can find in GREP. What you didn't mention was whether you used a replace expression that inserted the kerning. If so, how did you do that? If not, bummer, but at least I can still find the spots where I need to do it manually. Thanks!
5. Re: Adding a Kerning amount to the space between a digit and a quotation mark in GREP
P Spier Sep 6, 2012 5:49 PM (in response to johnmd13)If you want to adjust the spacing wherever the pair appears, include the query as a GREP style in the paragraph style and define a character style that it applies to do the adjustment. Otherwise, all you need do for find/change would be to add the new formatting in the change format options.
