5 Replies Latest reply on May 25, 2016 1:36 PM by peted44177588
    PDFA Complaince and convert existing PDF files to be PDFA compleint
    Manulak_Tech
      Hi All
      I am creating a PDF which is supposed to be complaint with PDF/A1-b and when I use online validators like PDF TOOLS Online Validator, it gives the following error saying that the PDF is not PDF/A complaint.
      dc:description/*[0] :: Missing language qualifier.
      dc:title/*[0] :: Missing language qualifier.
      The property 'pdf:keywords' is not defined in schema 'Adobe PDF Schema'.
      The XMP property 'dc:title' is not synchronized with the document information entry 'Title'.
      The XMP property 'dc:description' is not synchronized with the document information entry 'Subject'.
      The required XMP property 'pdf:Keywords' for the document information entry 'Keywords' is missing.
      I am using FOP for rendering my PDF and using iText (iText 2.1.6 by 1T3XT) for converting the PDF to be PDF/A complaint.
      public void convertToPdfA(File file1, File file2)
      PdfReader reader = null;
      Document document = null;
      PdfCopy copy;
             InputStream PROFILE = this.getClass().getClassLoader().getResourceAsStream("com/ini/vldt/config/sRGB Color Space Profile.icm");
      There I first read the PDF file to a PdfReader object, then get a copy as follows.
      reader = new PdfReader(new RandomAccessFileOrArray(file1.getPath()),null);
                    //Creating a new document that has the existing page size
                    document = new Document(reader.getPageSizeWithRotation(1));
                    //save the data in the 'document' to file2
                    copy = new PdfCopy(document, new FileOutputStream(file2));
      Then I try adding the Title, Author, Keywords, Creator, Subject, Creation Date and Producer as follows.
      try{
           document.addTitle(reader.getInfo().get("Title").toString());
      catch(Exception e){
           document.addTitle("TEST Title");
      try{
           document.addAuthor(reader.getInfo().get("Author").toString());
      catch(Exception e){
           document.addAuthor("TEST Author");
      try{
           document.addKeywords(reader.getInfo().get("Keywords").toString());
      catch(Exception e){
           document.addKeywords("TEST Keywords");
           document.addCreator("TEST Creator");
           document.addCreationDate();
           document.addProducer();
      try{
           document.addSubject(reader.getInfo().get("Subject").toString());
      catch(Exception e){
           document.addSubject("TEST Subject");
      Then I give the PDFA conformance values and then create the PDF as follows.
      copy.setPDFXConformance(PdfCopy.PDFA1B);
      copy.setPdfVersion(PdfCopy.VERSION_1_4);
      document.open();
      ICC_Profile icc = ICC_Profile.getInstance(PROFILE);
      copy.setOutputIntents("Custom", "", "http://www.color.org", "sRGB IEC61966-2.1", icc);
      for(int i=1;i<=reader.getNumberOfPages();i++){
      document.setPageSize(reader.getPageSizeWithRotation(i));
      copy.addPage(copy.getImportedPage(reader, i));
      copy.createXmpMetadata();
      copy.close();
      document.close();
      reader.close();
      I got another error report from SolidFrameowrk validations as follows.
      - <metadata>
      <problem severity="error" objectID="27" clause="6.7" standard="pdfa">Language qualifier missing for property 'dc:description'</problem>
      <problem severity="error" objectID="27" clause="6.7" standard="pdfa">Language qualifier missing for property 'dc:title'</problem>
      <problem severity="error" objectID="27" clause="TN0003" standard="pdfa">Property 'pdf:keywords' shall use a custom embedded schema</problem>
      <problem severity="error" objectID="27" clause="6.7.3" standard="pdfa">Document information entry 'Keywords' not synchronized with metadata property 'pdf:Keywords'</problem>
      </metadata>
      - <fonts>
      <problem severity="error" objectID="12" clause="6.3.5" standard="pdfa">Missing or incorrect CIDSet for CIDFont subset</problem>
      <problem severity="error" objectID="18" clause="6.3.5" standard="pdfa">Missing or incorrect CIDSet for CIDFont subset</problem>
      </fonts>
      What can be the issue? Any reply is highly appreciated. Does this issue related to this location at Adobe?
      Thank  you.
      -Manulak Dissanayake
