3 Replies Latest reply on Sep 7, 2012 7:49 AM by CarlosCanto
    Changing the color of a selection to HEX
    Olyas1
      Hi guys,
      i'm new to illustrator scripting (but not to javascript or programming).
      I have an AI file that has multiple layers. each layer has several items that are supposed to be of same color.
      I have an array of HEX values.
      I would like to loop over all items in a single layer, select them and change their color to some given HEX.
      Once that works, I will run on all HEX entries in array and save each variation in a separate PNG file.
      For the first part i wrote some script (see below), but i do not see any change in the file after i run the script. No errors and no change.
      I run the script once i select all items in a specific layer.
      Can you please advise what am i doing wrong?
      Thanks in advance!
      My code:
      function hexToRgb(hex) {
          var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
          return result ? {
              r: parseInt(result[1], 16),
              g: parseInt(result[2], 16),
              b: parseInt(result[3], 16)
          } : null;
      var fillRGBColor = function (pathItem, r, g, b){
          pathItem.fillColor.red = r;
          pathItem.fillColor.green = g;
          pathItem.fillColor.blue = b;
      var fillHexColor = function (pathItems, hex){
          var rgb = hexToRgb(hex);
          alert(rgb.r +","+rgb.g+","+rgb.b);
          fillRGBColor(pathItems, rgb.r, rgb.g, rgb.b);
      // check if a document is open in Illustrator.
      if( app.documents.length > 0)
                mySelection = app.activeDocument.selection;
                if (mySelection.length > 0)  {
                   for (var i=0; i<mySelection.length; i++) {
                        var currentObject = mySelection[i];
                        if(currentObject.typename != "CompoundPathItem" &&
        currentObject.typename != "GroupItem")  {
                               fillHexColor(currentObject, '#8F623B');
                } else {
                               alert("Nothing is selected.");
      } else {
                alert("No document Open.");
